CHESTNUTXE 7,311 Posted July 9, 2021 I can see a couple of Scoobies in the ashtray, mate.... Im rippin thru it heads r soaking atm while valves only need a light degreaseSent from my SM-G610Y using Tapatalk 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 9, 2021 Im rippin thru it heads r soaking atm while valves only need a light degreaseSent from my SM-G610Y using TapatalkBy sundown had both heads finished ,these heads were actually in vgc just needed a tidy upSent from my SM-G610Y using Tapatalk 1 1 gerg and bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 9, 2021 By sundown had both heads finished ,these heads were actually in vgc just needed a tidy upSent from my SM-G610Y using TapatalkYou're getting old mate to skim them though, right? That gasket face looks like the surface of the moonSent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 9, 2021 You're getting old mate to skim them though, right? That gasket face looks like the surface of the moonSent from my CPH1920 using TapatalkIts the camera on the fone that actually makes it look worse but yeah i might Sent from my SM-G610Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 9, 2021 Its the camera on the fone that actually makes it look worse but yeah i might Sent from my SM-G610Y using TapatalkMaybe gerg can identify these heads i think they could be xd heads casting number is i4j1 but i cant find any info on thatSent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted July 10, 2021 Maybe gerg can identify these heads i think they could be xd heads casting number is i4j1 but i cant find any info on thatSent from my SM-G610Y using TapatalkI think you're right there Action Man, but I think that first "letter" is just an upside-down 1. They don't use "I" in their codes to avoid this confusion.I reckon it was stamped wrongly ie: backwards, meaning it should read "1J14"1 = 81J = October14 = 14th dayThat's the only way I can see it lining up with the usual layout.Sent from my CPH1920 using Tapatalk 2 CHESTNUTXE and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 10, 2021 I think you're right there Action Man, but I think that first "letter" is just an upside-down 1. They don't use "I" in their codes to avoid this confusion.I reckon it was stamped wrongly ie: backwards, meaning it should read "1J14"1 = 81J = October14 = 14th dayThat's the only way I can see it lining up with the usual layout.Sent from my CPH1920 using TapatalkA guy down the road swears by using black open or closed xd xe heads he reckons they outflow older ones by heaps Sent from my SM-G610Y using Tapatalk 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 10, 2021 Interesting........... like to see the test bench flow results. 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 10, 2021 Interesting........... like to see the test bench flow results.They apparently have half the size of that exhaust heater thing and the short turn radius is opend up or something he was telling me i had a look at these heads and they are a tiny bit different to the xb ones i did last weekSent from my SM-G610Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 10, 2021 A guy down the road swears by using black open or closed xd xe heads he reckons they outflow older ones by heaps Sent from my SM-G610Y using TapatalkI would be interested in seeing down the throat of one as I clearly remember how bad my blue 2Vs were before I gave them some love Interesting........... like to see the test bench flow results.Yeah me too. I have a feeling that early Aussie 2Vs were shockers, for the size of the ports they don't deliver ... They're only marginally better than a 351 Wheezor. I remember reading something like 180cfm on them whereas US 2Vs go up around 200. That's around 40hp difference when calculated out.I think it's just in the way the throat is cut in them, and the short turn is horrible. Also the casting roughness and daggy parting lines were shitty down the port.Sent from my CPH1920 using Tapatalk 2 CHESTNUTXE and bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 10, 2021 They apparently have half the size of that exhaust heater thing and the short turn radius is opend up or something he was telling me i had a look at these heads and they are a tiny bit different to the xb ones i did last weekSent from my SM-G610Y using TapatalkYeah I remember the exhaust crossover port being huge. It's about the size of a Windsor exhaust port. Not needed in Aussie climate.Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 10, 2021 i took these exact pictures yesterday while valves were out,and didnt think last night you guys would be interested so i deleted them already 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 10, 2021 i took these exact pictures yesterday while valves were out,and didnt think last night you guys would be interested so i deleted them alreadyJust took these but ? The exhaust dont look to different but the intake looks like niagra falls compard to older headsSent from my SM-G610Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 10, 2021 Quality may have been the issue, back then. No way a major company would spend thousands of hours port shaping, just put on a bigger carby..LMAO... 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted July 11, 2021 I have blue & black closed chamber heads, some time might see if neighbor still has his flow bench & compare, but I'd say wound be minimal flow stock. Sean/Clevo120Y flowed a 2V closed chamber few years back On 8/29/2014 at 3:15 PM, Clevo120Y said: Stock 2V closed chamber heads IN EX 050 30.91 17.82 100 62.69 48.32 150 90.54 74.63 200 120.97 87.25 250 149.8 100.63 300 171.91 113.32 350 179.75 125.35 400 189.08 134.06 450 191.84 144.45 500 199.01 153.8 550 201.46 160.72 600 204.22 162.47 650 204.37 160.52 700 202.93 161.37 Tested at 28in depression I was looking at 351C or 400M vs 393/408C awhile ago figured similar, may as well go stroker, 3 bear351c, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 11, 2021 I have blue & black closed chamber heads, some time might see if neighbor still has his flow bench & compare, but I'd say wound be minimal flow stock. Sean/Clevo120Y flowed a 2V closed chamber few years back I was looking at 351C or 400M vs 393/408C awhile ago figured similar, may as well go stroker,Interesting note the 351m/400 was the last ford pushrod engine designed Sent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted July 11, 2021 Umm no it wasn't look up the (petrol) 7.3lt ''Godzilla" used in US F trucks, thats a engine I'd like in my XE ute, Harrop recently made 1000hp at Dandy engines with a stock engine, GT350 throttle body & a supercharger kit they're developing, also seen 750hp N/A, ?1340hp? can't remember turbo/supercharged. stock is 450ft/lb 430hp, add turbo 2 1 bear351c, gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 11, 2021 Umm no it wasn't look up the (petrol) 7.3lt ''Godzilla" used in US F trucks, thats a engine I'd like in my XE ute, Harrop recently made 1000hp at Dandy engines with a stock engine, GT350 throttle body & a supercharger kit they're developing, also seen 750hp N/A, ?1340hp? can't remember turbo/supercharged. stock is 450ft/lb 430hp, add turbo I was going off bubbas 400 website and yeah that info is almost 20 years oldSent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted July 11, 2021 Philthy Builds on Youtube (SA,Aus) is getting one for his '67 F100 swb, https://www.youtube.com/channel/UCfB9gU7BNw4XtJ9X_jmmboA Share this post Link to post Share on other sites
gerg 10,871 Posted July 11, 2021 7.3 Zilla.. yes please. If they're around the same price as a coyote, I know which one I'd choose.Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 12, 2021 7.3 Zilla.. yes please. If they're around the same price as a coyote, I know which one I'd choose.Sent from my CPH1920 using TapatalkI just sold those xd heads i bought for $50 cleaned em up and got $300 for em plus he gave me a set of genuine late last xe casting 82 black heads i gave him $50 trade inSent from my SM-G610Y using Tapatalk 1 1 gerg and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 12, 2021 I just sold those xd heads i bought for $50 cleaned em up and got $300 for em plus he gave me a set of genuine late last xe casting 82 black heads i gave him $50 trade inSent from my SM-G610Y using TapatalkYep 2202 cast date so i guess 20/02/82?Sent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted July 12, 2021 Some crunchy bits in there?Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 12, 2021 yup crunchie valve stem seal bits,these heads have never been touched and so far look vg,action man went into full boost mode and stripped both heads already and soon go to the machine shop to tank them up,and take it from there i think these late black heads will be a good starting point for my 400 build . 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 12, 2021 yup crunchie valve stem seal bits,these heads have never been touched and so far look vg,action man went into full boost mode and stripped both heads already and soon go to the machine shop to tank them up,and take it from there i think these late black heads will be a good starting point for my 400 build .I worked out the casting dates its 1 day apart from each other 22D2 and 21D2 now lets get olm8 to tank emSent from my SM-G610Y using Tapatalk 1 1 gerg and deankxf reacted to this Share this post Link to post Share on other sites
