CHESTNUTXE 7,311 Posted July 2, 2021 The beefy 400Sent from my SM-G610Y using TapatalkI picked up my 302 clevo heads after getting hot tanked and put em back together with new stem sealsSent from my SM-G610Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 2, 2021 I hate those umbrella seals. Mine crumbled to bits after only a couple of years. When I got my heads done up, I got them to machine the guides to suit press-on Viton seals. Never had to think about them since.Sent from my CPH1920 using Tapatalk 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 2, 2021 10 hours ago, gerg said: I hate those umbrella seals. Mine crumbled to bits after only a couple of years. When I got my heads done up, I got them to machine the guides to suit press-on Viton seals. Never had to think about them since. Sent from my CPH1920 using Tapatalk Yeah, they're sh!t. Wish I had done mine on the XB. Can't believe companies like Felpro still hock that stuff. 3 gerg, CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 Yeah, they're sh!t. Wish I had done mine on the XB. Can't believe companies like Felpro still hock that stuff.But these are mahle maybe better and look at the difference between 400 rod and 351cSent from my SM-G610Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 Like a 302 rod on roidsSent from my CPH1920 using TapatalkAction man had a pipe dream last night about using 302 rods on 400 and 351m piston cheap mans 11.1 but nope i did the calculations and its still 0.317 down the hole lol 5.51.1 compSent from my SM-G610Y using Tapatalk 1 1 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 3, 2021 Machine the heads and find shorter valves..?? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 Machine the heads and find shorter valves..?? There is no way around it ya have to buy the expensive forged flat tops 1.700 comp heightSent from my SM-G610Y using Tapatalk 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 3, 2021 There is no way around it ya have to buy the expensive forged flat tops 1.700 comp heightSent from my SM-G610Y using TapatalkI think it pays off in the end... If I had my time over I would've yoinked the hypatec rebuilder pistons for a decent set of zero deck flat tops. 17 down the hole is a lot on a little 302Sent from my CPH1920 using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 I think it pays off in the end... If I had my time over I would've yoinked the hypatec rebuilder pistons for a decent set of zero deck flat tops. 17 down the hole is a lot on a little 302Sent from my CPH1920 using TapatalkThe normal 400 is 69 thou down the hole Sent from my SM-G610Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 That and an open chamber... Compression on them is total poo. No wonder they were considered a slug. I wish I'd gotten on the bandwagon a long time ago and built up a good healthy streeter... I like nothing more than to see an orphan engine punching above its weight.Sent from my CPH1920 using TapatalkYou can also bush the 400 rod and use clevo pistons as say a set of sealed power aussie flat tops have 1.645 comp height normal 400 piston is around 1.630 so your 15 thou up the hole already then shove the aussie 02 heads on it and bam around just over 10.1 Sent from my SM-G610Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 3, 2021 But being that far down the hole still, the closed chambers act as opens. Not the end of the world but you lose the advantage of actual open chambers with their unshrouded valves, yet don't have quench action like a proper closed chamber does. Sent from my CPH1920 using TapatalkThe latest 400 forged pistons come in many cc for juggling your comp but they are very nice and pricy too by the time you land them cheapest is about $800 auSent from my SM-G610Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted July 3, 2021 1 hour ago, CHESTNUTXE said: but they are very nice and pricy too by the time you land them cheapest is about $800 au don't forget the flow on cost.. baked set of tyres from a 60kmh roll on etc 1 gerg reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted July 4, 2021 Quote Silvolite part No. 3330, Australian Ford Cleveland. Comp height 1.720", bore 4.000", 0.912 pin, unsure of dish CC's tho, may work with bushed 400M conrods https://uempistons.com/series-4280-silv-o-lite-australian-ford-351-5-7-3330.html @CHESTNUTXE there was also the possibility at these pistons (above) with 400M rods bushed, just saw a STD set on US ebay at $133.55usd From memory THOM also had EFi on his Customline's Clevo with downdraft ITB's. & Back when I was looking at Holley's Terminator X EFi Kit for 5.0 Windsor, I figured it would run a Clevo if you used a Holley Dual Sync dissy & had a intake modified to fit injectors. 3 gerg, CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 4, 2021 Silvolite part No. 3330, Australian Ford Cleveland. Comp height 1.720", bore 4.000", 0.912 pin, unsure of dish CC's tho, may work with bushed 400M conrods https://uempistons.com/series-4280-silv-o-lite-australian-ford-351-5-7-3330.html [mention=7196]CHESTNUTXE[/mention] there was also the possibility at these pistons (above) with 400M rods bushed, just saw a STD set on US ebay at $133.55usd From memory THOM also had EFi on his Customline's Clevo with downdraft ITB's. & Back when I was looking at Holley's Terminator X EFi Kit for 5.0 Windsor, I figured it would run a Clevo if you used a Holley Dual Sync dissy & had a intake modified to fit injectors. Im gunna check that out laterSent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 4, 2021 ok those silverlite pistons are dish ,and i dont know where you saw that add for the 400 rods bushed i cant find it on usa e bay maybe you can send a link bro. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 5, 2021 Price was for a set of STD 3330 pistonsThe 400 is back and look how beefy its stance is,olm8 did a good job on the 1 piece rear main seal Sent from my SM-G610Y using Tapatalk 3 bear351c, Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 8, 2021 The 400 is back and look how beefy its stance is,olm8 did a good job on the 1 piece rear main seal Sent from my SM-G610Y using TapatalkWork has ground to a halt as i havent found another 400 block to build the stock engine and sell it,and i dont have a 351c crank to start building the std bore clevo,i have all new parts to go on them ,351c crank is very hard to find lately i even considerd vuying a $1800 393 stroker kit from usa cause it comes with new crank rods n pistons by the time ya find a crank and have it machined there goes $500 then buy new pistons n rings $500 then buy and get rods reco probly 300 and ya already around 1500 Sent from my SM-G610Y using Tapatalk 1 2 bear351c, Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 8, 2021 Work has ground to a halt as i havent found another 400 block to build the stock engine and sell it,and i dont have a 351c crank to start building the std bore clevo,i have all new parts to go on them ,351c crank is very hard to find lately i even considerd vuying a $1800 393 stroker kit from usa cause it comes with new crank rods n pistons by the time ya find a crank and have it machined there goes $500 then buy new pistons n rings $500 then buy and get rods reco probly 300 and ya already around 1500 Sent from my SM-G610Y using TapatalkFound these closed chamber heads on marketplace and original price of $100 was dropped to $50 the description in picture looks pretty rust so i guess thats why no one wanted them but when i get there i see the rust was just gold metalic paint lol $50 bargin ,someone reco these some time ago and only need the action man clean upSent from my SM-G610Y using Tapatalk 2 2 Outback Jack, bear351c, gerg and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 8, 2021 Found these closed chamber heads on marketplace and original price of $100 was dropped to $50 the description in picture looks pretty rust so i guess thats why no one wanted them but when i get there i see the rust was just gold metalic paint lol $50 bargin ,someone reco these some time ago and only need the action man clean upSent from my SM-G610Y using TapatalkValves ect came out easy and rubber seals were like new i doubt these heads have seen much work at all Sent from my SM-G610Y using Tapatalk 1 2 bear351c, Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 9, 2021 I can see a couple of Scoobies in the ashtray, mate.... 3 Outback Jack, gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
