deankxf 20,314 Posted March 21, 2017 here is the correct tool.. you can buy them somewhere..you can also do the chisel method, which is basically just hit one of the flat sides of the big nut with a sharp blow on the undo side(its reverse thread) and it usually comes undone. tightening by the same method suffices also..(i have done this about 5 times when My brother or Dad had the tool in the past) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 yup thats right the wrecker got it off for me as i didnt have a big enough spanner,he also reckons this is a factory waterpump. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 one thing that bugs me is why does a xe with no air-con or power steer have a fan this big ? anyway ol'm8 got the bolt out charged me accoringly,quite dished pistons in this engine. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 head is unmarked model and if ol'm8 gives it the ok will spend some bucks on it. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 rods are out Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 block looks ok condition,is std bore but will need a rebore if the new owner everdoes anything with it,ando is dropping off a crossy block tomorrow for me to start with. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 sorry wrong picture Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted March 21, 2017 84DA block should have a 92mm single piece rear main seal, 83 2piece rear main, rest should be same. 3 or 4 bolt balancer is for P/S pulley (xc-xe 3 xf4) Looks to be factory water pump after market would be GMB with pressed plate impalar rather then cast impalar. Timing chains stretch is common, If using a melling oil pump use base plate from stock pump. What's the plans for the build 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 well unsure about turbo or the small weiand supercharger kit from aussiespeed or just a beefy n/a or efi i picked up a efi intake during the week didnt pay much for it so maybe that too ,if lowering the comp i think i have read somewhere that instead of using a de-comp plate you can use the unleaded xf dish piston with the xe head which i am about to look at the compression calcuator,factory booklet says xe 8.81 factory comp,will check with 26cc piston should maybe get around 8 to 1 ? Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 21, 2017 hypertec do a 29 cc dish piston for about $280 a set. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 23, 2017 ando just dropped the new block off Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted March 24, 2017 My advice, would be to keep that engine complete, for the new owner of the car. Especially if it's all matching numbers - block/head/bolt-on's. Getting an EFI head, would be much better and more efficient, IMO. (use a very late casting if possible, or even a very late Carby head casting) Then send the head to Sean Burns in SA, to be ported/flowed, etc. http://www.ozfalcon.com.au/index.php?/topic/1868-crossflow-porting-results/ For every day driveability, I'd recommend a turbo personally. Hot NA, means a big cam, which lowers the around-town and in-traffic driveability. A supercharger sucks a fair lot of power, just to turn itself IMO. I'd run thermo's maybe, rather than a mechanical fan, and yeah that pump is the factory fitted one, or at least an OEM Aussie made one. (cast impeller) 2 XTREME KARTS XF and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted March 24, 2017 aparently ando said this 84 da has a 1 piece rear seal,so the crank i took out of the 83 aint gunna fit,so i will pull this fella down and take the block to the machine shop and see what ol'm8 says about it,the bores look std and good with hardly any lip or ware. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 16, 2017 i was just reading xrglens old thread ,14650 crow cam he swears by,might check it out. Share this post Link to post Share on other sites
Grimmy 312 Posted May 16, 2017 Noooooooooooooooooooooooo lol the camtech 528 is much better imo . Also , I'd go the short first gear singlerail . 2 CHESTNUTXE and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 16, 2017 which single rail the factory 6 box or the xc/xd box with 3.06 ? first Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 16, 2017 ct-142 -528 hyd you mean Share this post Link to post Share on other sites
Grimmy 312 Posted May 16, 2017 Yep the ct142-528 and the v8 3.06 first , I think it's what I have . Good to 'idle' about car parks with the lumpy cam 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 17, 2017 hey i was checking how much down the hole the old pistons were but this looks like its been zero b4. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 21, 2017 ok i have stripped the block down and found the rod bearings were 010 so i guess its had a reco b4,all good i will send it down tomorrow to the machine shop to get ol'm8 to tank it up and we will go from there 1 Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 21, 2017 piston choice is only the real thing bugging me,using the 83 head with roughly 57cc odd chamber there is the 20.5cc dishy at std compression height ,with near zero deck you are gunna get around just over 9.1 comp,but if i use the 5.7 cc dish it will get 10.5 comp which is what i want,but that piston has a lower compression height so i will ask ol.m8 if we can take even more off the block,there is the std compression height flat top but its gunna get 11.1 or more and i think thats getting a bit high,many questions to ask tomorrow,also balancers the powerbond or romac ? 4 bolt one to suit 84 onwards. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 22, 2017 ol'm8 says first we are doing the head to see where we are at with cc and the rest follows,i also orderd a aussie speed big 4 barrel manifold he needs it to match port the head. 1 deankxf reacted to this Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted May 22, 2017 That's a great looking spring compressor, much better than those pain in the arse g-clamp style ones Share this post Link to post Share on other sites
