CHESTNUTXE 7,317 Posted December 19, 2016 Guy's i need to no is this going to work or do i just go the t5 gearbox,i have 3 single rails 1 x xf,2 x xe 4.1 carby,i assume they have around the 3.50 first gear,is this going to work with a mild 351c or should i look for a earlier single rail with the 3.08 or 2.82 first gear ?,i can get my hands on a t5 from a xg that has 3.25 first,i still have to buy a aftermarket bellhousing for the conversion,and want to get it right,i have 2.92 gears and both the banana crossmember and the std one,so can anyone help with info is it ok to run the 6 cyl single rail box behind a v8. Share this post Link to post Share on other sites
Butcha 111 Posted December 19, 2016 Single rails fine. The v8 has a wider ratio in 1st n second all finish up 1:1. In 4th. Just dont go flat changin through the gears and they live alright. Get new nylon/alluminium bushing for shifter. You can use the single rail bellhousing on a t5. Get the input shaft snout thing spun down to fit. Drill and tap 3 holes and drill n nut n bolt the 4th on the webbing. Go t5 if you can get one else single rail will do. Sent from my SM-G928I using Tapatalk 2 CHESTNUTXE and deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 19, 2016 My single rail clevo bellhousing couldn't take a t5 as the lower bolt holes on the box were below the face of the bell. I used a top loader one and even that needed a bit of work. In box Falcons, the shortest ratio single rails were 3.47:1 first (carby 6), then taller 3.06:1 (302/250 EFI), and ultra-tall 2.46:1 (351). Taller gears, higher torque capacity. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 19, 2016 guys im asking what will happen if i put the 3.47 1st gear with the clevo thats all ,not what you did with your t5,i will buy the correct bell when needed,will the 3.47 be to short ? Share this post Link to post Share on other sites
NZXD 2,328 Posted December 19, 2016 guys im asking what will happen if i put the 3.47 1st gear with the clevo thats all ,not what you did with your t5,i will buy the correct bell when needed,will the 3.47 be to short ? I believe I have the short ratio in 1st in my XD, not that I have driven it much but when I have it's not issue, the lumpy Windsor just chugs off the line with ease. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 20, 2016 Whe I spoke to mal wood some years ago about the t5's as opposed to single rail behind a healthy x flow he said stick with th single rail. It will eat t5's if pushed. I would think that first gear ratio will be fine. 1 stockesp reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 20, 2016 guys im asking what will happen if i put the 3.47 1st gear with the clevo thats all ,not what you did with your t5 I was just giving a response to butcha's advice on bellhousing compatibility. You can take it or leave it. i will buy the correct bell when needed,will the 3.47 be to short ? In my opinion, behind a big torquey V8, yes. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 there must be someone who has done this,i will take a few pictures of the boxes ,one is missing a tag,im hoping one of them might be a 3.08 first. Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 gerg in your t5 thread you put your running a early t5 with 3.27's is that right ,what if its 2.92 would that make a huge difference or am i swapping deck chairs on the titanic. Share this post Link to post Share on other sites
gerg 10,871 Posted December 20, 2016 Top speed in 1st would be about 5 km/h difference between the two diff ratios, but it does actually feel a lot different when driving. Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 is there anyway of putting a wider 1st gear in a single rail ? Share this post Link to post Share on other sites
deankxf 20,294 Posted December 20, 2016 i mentioned in one of your other threads i ran a 6cyl cortina single rail box behind a clevo with standard cam, 2.92 diff.. its fine. make sure your single rail or T5 is rebuilt or very good or it will die without much effort Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 i did some research a alloy bellhousing for a single rail is about $350 and the dellow t5 one is $700 not cheap. Share this post Link to post Share on other sites
deankxf 20,294 Posted December 20, 2016 if the dellow one is as crap as the one BGDAV had from dellows on his T56 you dont want it.. (fucked his box up in less than 500km and they didn't even acknowledge the issue... Mal Wood rectified it) i'd use a single rail bell as mentioned or a CRS one personally (or top loader as Gerg said perhaps.)heres one tutorial, on the single rail mods , there will be more with googlehttp://www.xfalcon.com/forums/index.php?/topic/18759-how-to-fit-a-t5-gearbox-to-a-v8-single-rail-bellhousing/ Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 ok thanks,but i like the weight saved by the aftermarket single rail bellhousing,im going out to the garage and taking a look at the tags on the rails. Share this post Link to post Share on other sites
deankxf 20,294 Posted December 20, 2016 ok thanks,but i like the weight saved by the aftermarket single rail bellhousing,im going out to the garage and taking a look at the tags on the rails. i like the cast iron bell and gearbox survival rather than broken boxes due to misalignment issues when using Dellow bells.. i understand the 10kg weight saving though,. put 10 litres less in the fuel tank Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 bahhhaaaaaaaaaaa im talking about the single rail bell in alloy,not sure who makes em but all the gt shops sell em Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 the one in the garage is 0503-039 which i guess is the 3.47 1st,the tag is missing off the other 1,and i just learnt that the efi xe 4.1 has the 3.06 first gear,and possibly 84-85 pre unleaded xf's. Share this post Link to post Share on other sites
NZXD 2,328 Posted December 20, 2016 bahhhaaaaaaaaaaa im talking about the single rail bell in alloy,not sure who makes em but all the gt shops sell em I used an alloy one from one of the GT shops, has the top loader and single rail bolt patterns and is quite light. No fitment issues to date. Sent from my iPad using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted December 20, 2016 i might put an add for wanted- a wide ratio single rail either 2.82 or 3.08 1st gear ,or maybe have my one modded ? Share this post Link to post Share on other sites
