CHESTNUTXE 7,363 Posted October 28, 2016 I scored another clevo today,i fluked it,just went to the local wreckers and up on the rack there has been this 302c that has been sitting there for some time ,everybody including myself was convinced it was a 040 unusable block and even the owner told me it came out of his ute or van,so just for nowing what it actualy was blew me away when i measured the bore at just under 4.000,the reason everyone thought it was 040 was on the piston it is stamped with a 4 ,my pillowblock also came with pistons like this,so i offerd the yard just a couple of bucks for it and he said its yours,so the xg was launched into loading positon,and the forklift dropped it straight in and i was out of there b4 anyone clicked on it was actualy a gem,it also has the lip for the 4v valves and is a D2AE cast will put more pictures tomorrow. 3 2redrovers, deankxf and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 28, 2016 Lol... Chestnut engine factory Share this post Link to post Share on other sites
Free.51 2,746 Posted October 28, 2016 So this block is 26 aug '77. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 28, 2016 Yes and the other one I'm rebuilding is a 77 also ,only a month difference I think. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 28, 2016 I made a mistake the gasket corner looked a bit like the lip on the block so its just a normal bore. Share this post Link to post Share on other sites
Thom 6,655 Posted October 29, 2016 What are you so worried about having the valve reliefs for 4v valves? Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 29, 2016 i was going to build a 393 or 408 with some CHI OR AFD ALLOYS and the larger valves,but i no the blocks can be lipped at a machine shop,but yeah just thought i had a good score,is it only nescersary to have the lip with large camshaft lift and or size of the valve thom ? Share this post Link to post Share on other sites
Thom 6,655 Posted October 29, 2016 The bore is clearanced for valve size not cam size as the valves travel further toward the center of the cylinder the further they open, most stroker kits use a .030" bore and the valve reliefs will usuall be gone with any more than a 020" over bore, 4v valves are just too big and you end up reducing air flow because the bore wall shrouds the valve, you'll find most aftermarket heads run a valve size between standard and 4v 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 29, 2016 ok good info ,so thats why i see the notch in std bore blocks (well some of them),i have quite a stash of parts atm so im just gunna keep this block as is until the 302 is finished. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 31, 2016 yep she is in good nick,was std bearings as well. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 31, 2016 i cleaned it up really good today and took out the plugs as well and the oil gallery plugs 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted October 31, 2016 wd40 1 bear351c reacted to this Share this post Link to post Share on other sites
