Panko 2,481 Posted April 22, 2018 23 minutes ago, SPArKy_Dave said: Did you take pics of the inside of the solenoid? I didn't think anyone did 'stanced' cars these days... due to them being pretty much un-driveable. not yet i havent taken photos of the inside. but its pretty obvious, it has a broken wire, that is pretty much impossible to fix given the way they are made Share this post Link to post Share on other sites
Panko 2,481 Posted April 29, 2018 well Houston, we have a problem. yep, the diff in the escort is crying for help its had an interesting knock for a while now, progressively getting worse. well, i got dad to have a listen while i went back and forth in the drive today, and it appears to the be the diff centre making this god awful knock. i was warned these diffs were pretty weak, that even a 1300 can kill them. i suppose i should stop doing the occasional burnout lol @SPArKy_Dave until i find a replacement. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,882 Posted April 29, 2018 Driveway exit single pegger's FTW... They're only a BW75 diff arent they? ie, basically the same as even FG ute diffs? Share this post Link to post Share on other sites
Panko 2,481 Posted April 29, 2018 31 minutes ago, SPArKy_Dave said: Driveway exit single pegger's FTW... They're only a BW75 diff arent they? ie, basically the same as even FG ute diffs? and dropping U turns at the T intersection near the factory when i missed the driveway lol *facepalm* no i think they are smaller. they are smaller than a falcon diff. any much much much shorter in the length lol 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
deankxf 20,298 Posted April 29, 2018 is it back lash in the pinion and ring? or slop in the axels splines, i've had falcon ones with massive backlash that woudn't die.. My gemini has a constant whine and metal in the oil, it's shiney.. it's got me more concerned than any other diff issue i've had(blown at least 6 up in various ways 1 Panko reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted April 29, 2018 it has backlash, but then it has a knock when i stop and go. so as i come to a stop, i hear it go clunk, then as i take of i hear it clunk a few times. never makes noise getting along, other than a bit of a knock with back lash. it sounds like the planetary gears knocking. Share this post Link to post Share on other sites
deankxf 20,298 Posted April 29, 2018 sure it's not a bush? if its one of the pins inside, it could be welded up like a CIG locker to get you by for a while.. (tempted to do that with mine before i change it.... just for FUN ) https://zippy.gfycat.com/WarmheartedColossalImpala.webm Share this post Link to post Share on other sites
Panko 2,481 Posted April 29, 2018 nah not a bush, well i dont think. it sounds like an LSD jamming and unjamming. that sort of knock. its a distinct noise when it goes Share this post Link to post Share on other sites
deankxf 20,298 Posted April 29, 2018 weld it before it breaks... its probably the pins holding the spider gears .. if so.. bang any moment from My experience Share this post Link to post Share on other sites
Panko 2,481 Posted April 29, 2018 7 minutes ago, deankdx said: weld it before it breaks... its probably the pins holding the spider gears .. if so.. bang any moment from My experience this is why I am NOT doing the RSOCV/TACCV join motorsport weekend next weekend. i was going to enter in the motorkhana and hill climb, but i dare say the diff is on its last legs. im still going to take a look though Share this post Link to post Share on other sites
deankxf 20,298 Posted April 29, 2018 got a wanted ad on the group yet? could get one and fit it before then? be good to watch anyway.. i'm sure the waiting to run would kill some of the fun (calder drags, waiting is SOOO painful) 1 Panko reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted April 30, 2018 I ran the car up Arthur's Seat yesterday, pushed it pretty hard. I was surprised, for the little 1300, how well it went on such a steep and windy road, essentially a hill climb with the way i was driving it, did really well. but yeah with the diff like it is, not so keen. I have one lined up, whenever i want it. Michael's car has a diff i can have. he has a stronger diff to go in. But, his car is auto, so it will either be 3.9 or 3.77 ratio. 3.9 will be ok step down, but 3.77 might be too far for the 1300. Share this post Link to post Share on other sites
deankxf 20,298 Posted April 30, 2018 if it's 3.77 it will fix that in between gears issue you had on Marysville drive? 2nd was too low, and 3rd too gutless? now 2nd will be fine... its less than 5% different, which is less than going 2.77 to 2.92 or vice versa.. in saying that.. more torque and power will fix it.. = headwork 2 Outback Jack and Panko reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted April 30, 2018 1 minute ago, deankdx said: if it's 3.77 it will fix that in between gears issue you had on Marysville drive? 2nd was too low, and 3rd too gutless? now 2nd will be fine... its less than 5% different, which is less than going 2.77 to 2.92 or vice versa.. in saying that.. more torque and power will fix it.. = headwork my concern would be getting off the line, and labouring the engine too much, but yes more power would be ideal. Yesterday when i went down to the peninsula, i was pushing it out through the RPM, and if i keep it pegged all the way to 100km/h, it will do 100km/h in 3rd, but it hits 5500-5700rpm, and surprisingly smooth up there too, although it starts to really run out there. if i went down to a 3.77, it might have a bit more legs up there so if im accelerating hard etc, im not having to do 3 gear changes to get up to highway speeds. i really need to do a leak down test on the engine. I know its low on compression, would be nice to know if its head or cylinders. Share this post Link to post Share on other sites
deankxf 20,298 Posted April 30, 2018 considering how easy a diff is to swap, i'd try a 3.77 diff regardless.. on a 4 speed (no overdrive) it would make me feel better knowing it's cruising at a closer to overdrive range.. i've never messed with diff ratio's in 4cyls, but in Falcons, it makes very little difference going 5% one way or the other.. tuning can make more of a difference. 2 Outback Jack and Panko reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted April 30, 2018 1 hour ago, deankdx said: considering how easy a diff is to swap, i'd try a 3.77 diff regardless.. on a 4 speed (no overdrive) it would make me feel better knowing it's cruising at a closer to overdrive range.. i've never messed with diff ratio's in 4cyls, but in Falcons, it makes very little difference going 5% one way or the other.. tuning can make more of a difference. yeah it is pretty easy to swap them. even though the 2.92 in the XF only brought the RPM up by 100rpm (or thereabouts), it made a world of difference to the way it drove. i just dont want going the opposite way i did in the XF, in the escort, make it harder or annoying to drive it will be one of those jobs where i do it properly. so while im at it, rebush the rear suspension and paint all the suspension components etc. Share this post Link to post Share on other sites
2redrovers 21,400 Posted April 30, 2018 I ran the car up Arthur's Seat yesterday, pushed it pretty hard. I was surprised, for the little 1300, how well it went on such a steep and windy road, essentially a hill climb with the way i was driving it, did really well. but yeah with the diff like it is, not so keen. I have one lined up, whenever i want it. Michael's car has a diff i can have. he has a stronger diff to go in. But, his car is auto, so it will either be 3.9 or 3.77 ratio. 3.9 will be ok step down, but 3.77 might be too far for the 1300. I used to live at the top of the hill, just past the lookout cafe. Up and down the hill was usually fun even in the mirage, although the rover sounded better hehe. Up is more fun than down although when you live there you learn not to over do it because the local cops LOVE that hill. Lycra clad wankers can get stuffed though 1 BGDAV reacted to this Share this post Link to post Share on other sites
deankxf 20,298 Posted April 30, 2018 4 hours ago, Panko said: yeah it is pretty easy to swap them. even though the 2.92 in the XF only brought the RPM up by 100rpm (or thereabouts), it made a world of difference to the way it drove. i just dont want going the opposite way i did in the XF, in the escort, make it harder or annoying to drive it will be one of those jobs where i do it properly. so while im at it, rebush the rear suspension and paint all the suspension components etc. but if the carby was tuned properly and it made more power.. it may be better all round.. that said, you'd expect ford should have got it right the first time too.. or close.. (i just booked the gemini in for dyno tuning at a carby specialist shop will let you know how that goes and costs) 2 Panko and Outback Jack reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted May 1, 2018 BIG step forward today with the RS wheels. I finally got around to polishing the last of the 4 wheels. These 2 photos show the difference in the wheel just from sitting in the shade and sitting in the sun. the last wheel hasnt come up nearly as good as i had hoped, and clearly needs a lot more, abrasive work done to it, but im happy with it for now. so this is in the shade and this is in the sun (also this is before i hit the wheel with the polish, just been sanded) This last wheel, is the only 1 of the 4 that I have soda blasted the paint off of, so I am 1 step ahead with this wheel than the others. I got i all masked up, ready for paint tomorrow I can not wait to see it with some fresh black paint on there (oh and you can see in this how much better the lip and dish looks just from being polished, over the last pic where it was just sanded before polish) 1 2redrovers reacted to this Share this post Link to post Share on other sites
2redrovers 21,400 Posted May 1, 2018 Shiny Although that last shot with the masking just highlights how hideous that kind of wheel looks when you attempt to colour code them ...bleh 1 Panko reacted to this Share this post Link to post Share on other sites
Panko 2,481 Posted May 1, 2018 1 minute ago, 2redrovers said: Shiny Although that last shot with the masking just highlights how hideous that kind of wheel looks when you attempt to colour code them ...bleh haha i know right. could you imagine if i colour coded the infills to the colour of the car? metallic green? haha Share this post Link to post Share on other sites
Panko 2,481 Posted May 1, 2018 ok so who is free this saturday and feels like coming for a drive in the Escort? @deankdx @SPArKy_Dave @2redrovers RSOCV have their vs TCCA motorsport weekend at Terry Baker motorsport park. As I said in an earlier post yesterday, I am not competing in the hill climb or motorkahna, but I am doing the road tour event on the saturday. Its on public roads, so all road rules apply, but there will be clues and notes I have to right down as im getting along. teams work as a car. so 1 car = 1 team, no matter how many people in the car. so, if anyone is up for a decent day as co-driver in the escort let me know. will need to be at my house by 730 at the latest on saturday morning otherwise ill go solo, and try my best to get answers down 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
deankxf 20,298 Posted May 1, 2018 usual answer for Me, (that's a no for anyone wondering) any time i have between now and Wednesday morning must be spent getting the gemini ready for dyno tune. good luck with the diff.. sounds like a gamble even still. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,298 Posted May 1, 2018 as for the wheels... hurry up and paint one Share this post Link to post Share on other sites
Panko 2,481 Posted May 1, 2018 3 hours ago, deankdx said: usual answer for Me, (that's a no for anyone wondering) any time i have between now and Wednesday morning must be spent getting the gemini ready for dyno tune. good luck with the diff.. sounds like a gamble even still. the tour event will be fine. normal driving conditions ill be right. Share this post Link to post Share on other sites
