xwroo 349 Posted August 11, 2016 Is there any physical size difference between the to engines? Will the roller engine slide straight in to replace the flat tap motor? Share this post Link to post Share on other sites
Thom 6,710 Posted August 11, 2016 Same bellhousing pattern same engine mounts same physical size, just make sure your harmonic balancer and flywheel/ flexplate match the engine as roller windsors use a 56ounce balance and early use a 46 ounce balance 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Thanks for that so no real difference. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Thom 6,710 Posted August 11, 2016 No not really 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Looks like an easy swap then. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted August 11, 2016 Same bellhousing pattern same engine mounts same physical size, just make sure your harmonic balancer and flywheel/ flexplate match the engine as roller windsors use a 56ounce balance and early use a 46 ounce balance 50oz for roller and 28oz for the old school. Sent from my iPad using Tapatalk 1 xwroo reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted August 11, 2016 Same bellhousing pattern same engine mounts same physical size, just make sure your harmonic balancer and flywheel/ flexplate match the engine as roller windsors use a 56ounce balance and early use a 46 ounce balance 50oz for roller and 28oz for the old school. Sent from my iPad using Tapatalk My bad brain is not in gear tonight 1 xwroo reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted August 11, 2016 Same bellhousing pattern same engine mounts same physical size, just make sure your harmonic balancer and flywheel/ flexplate match the engine as roller windsors use a 56ounce balance and early use a 46 ounce balance 50oz for roller and 28oz for the old school. Sent from my iPad using Tapatalk My bad brain is not in gear tonight I was thinking it may have been fat fingers on a cell phone. Sent from my iPad using Tapatalk 1 xwroo reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted August 11, 2016 Same bellhousing pattern same engine mounts same physical size, just make sure your harmonic balancer and flywheel/ flexplate match the engine as roller windsors use a 56ounce balance and early use a 46 ounce balance 50oz for roller and 28oz for the old school. Sent from my iPad using Tapatalk My bad brain is not in gear tonight I was thinking it may have been fat fingers on a cell phone. Sent from my iPad using Tapatalk That's could also have something to do with it 1 xwroo reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted August 11, 2016 How are you going to set the front of the engine up and are you running a carb or efi? Sent from my iPad using Tapatalk 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Set up??? How are you meaning? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Running carb mate Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 11, 2016 what happend to your weiand underbonnett blower Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Newborn baby and brought a house. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Still will happen down the track. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 11, 2016 cool,i got a new baby too, a xg ute. 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 How are you going to set the front of the engine up and are you running a carb or efi? Sent from my iPad using Tapatalk Is there something I should keep in mind? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted August 11, 2016 How are you going to set the front of the engine up and are you running a carb or efi? Sent from my iPad using Tapatalk Is there something I should keep in mind? Sent from my iPhone using Tapatalk Electric or mechanical fuel pump? 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 Hoping Mechanical, to keep it simple. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 How are you going to set the front of the engine up and are you running a carb or efi? Sent from my iPad using Tapatalk Is there something I should keep in mind? Sent from my iPhone using Tapatalk Electric or mechanical fuel pump? Hoping mechanical to keep it simple. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
judgetread 761 Posted August 11, 2016 few things to keep in mind.. The roller may not have a fuel pump cam installed, and even may not have the slot in the timing cover for the mech fuel pump. Depending on the setup, water pump rotation could be a issue so make sure you get the all sorted too.. Unless its a retro fit roller 1 xwroo reacted to this Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 few things to keep in mind.. The roller may not have a fuel pump cam installed, and even may not have the slot in the timing cover for the mech fuel pump. Depending on the setup, water pump rotation could be a issue so make sure you get the all sorted too.. Unless its a retro fit roller Thanks for that very helpful!!! I've just started looking so I'll suss all that out. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
xwroo 349 Posted August 11, 2016 It wouldn't bother me if I had to run an electric fuel pump. But what's this about the water pump rotation? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,875 Posted August 11, 2016 Later 5.0s use a serpentine belt which in this case drives the water pump off the back of the belt spinning it backwards when compared to the v-belt setup.<br /><br />One thing that all these 5.0 serpentine examples have in common is water pump rotation Share this post Link to post Share on other sites
NZXD 2,328 Posted August 11, 2016 I have a roller motor that has been converted to carb and has mechanical pump, it's all easy to do, just have to source all the bits. Share this post Link to post Share on other sites
