CHESTNUTXE 7,311 Posted April 10, 2016 The compressor i have was working ok in the 4.1L crossy i took out ,but im trying to keep the look of the new clevo as factory as possible,so today i cleaned it up and found its stamped 02/82 so its the original york type,on the crossy it sits upsidedown and on the clevo the oposite,so i just flipped it over and every thing looks like it will bolt straight on,i have the correct pulleys and tensioners,the big boxy york type commpressors are not popular with performance looks,but are great for the factory look or for a numbers ghia or whatever to put on,there seems to be 3 different pulley types ,the one i have is a 2 row for a crossy ,i have also seen a 1 row on a genuine xe esp,and the more common 1 row with the huge alloy backing on it,see pictures,if anyone has an old v8 type pulley ,please can i buy it to put on mine as the factory v8,s had em,also its dam hard to find the belt tensioners that work cause most of em are stuffed,and no one does re-po ones unless you want to change the bearings on them which is a fookin time labour job. Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted April 10, 2016 Hey mate have you got a picture of the one your after or is the one in the pic already posted the one your looking for? Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted April 10, 2016 The pulley i am after is a 1 row with a large counterweight on the rear,they are very common,the one in the picture is my 6cyl 2 row pulley which will still work fine but its not a factory v8 one,i will try and put a picture up of the one im after ,thanks for your reply 351XD-FAIRMONT. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted April 10, 2016 This is the factory v8 one with the large back. Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted April 10, 2016 No problem mate I'll keep an eye out for one Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted April 11, 2016 Motorcraft tag Share this post Link to post Share on other sites
FOMOCOHO 882 Posted April 16, 2016 York compressors don't like sitting unused for long periods of time. Leaking at the head gasket seal is common as it dries out. Â Good luck with it though... there may be better sealing kits for them now. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted April 16, 2016 Mine is good,it was working fine,I will need some new hoses tho Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted October 20, 2016 nope the crossflow pulley misses out by about 6mm  Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted October 20, 2016 i have looked at shimming the compressor bracket that's the easy part, but if you do that the other tensioner's will be to close to the waterpump pulley,once they are also brought forward to line up,please does someone have a v8 pulley. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted October 20, 2016 i just found a place that does them ,2 different styles,std clutch and flywheel clutch,on page 24 of the PDF. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted October 20, 2016 The big sucker on the right is no longer available,but the one in the middle is,list retail price is $350 but get your local auto electrical place to get it wholesale and it will be much cheaper. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 9, 2016 i painted it and bolted it all up just need the belt and either shim the old compressor or get the new pulley. Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted November 20, 2016 Did I read that you're using the 6cyl compressor on the Clevo? Remember that the compressor Suction and Discharge ports can be opposite on the V8's, compared to the 6cyl's.  I have an account at Cooldrive Distribution (aircon wholesaler) In the catalogue, there are two separate listings.  XA-XE 6cyl - CM1924 - RH Suction port XD-XE V8 - CM1237 - LH Suction port  Interestingly though, the catalogue lists CM1924 as suitable for ZH/ZK and FD LTD V8's, but also states RH Suction.  In the Adrad Catalogue I have, the part numbers are as follows -  PYOR014 (ref CM1924) York Compressor 169cc capacity PYOR004 (ref CM1237) York Compressor 169cc capacity 1 stockesp reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 20, 2016 the lines went in the same way as a v8,just with the 6 they snake around the crossy ,with the v8 they are shorter on the passenger side,but hold the phone i will check what you are saying dave,but it could be like a c4 cooler lines where it doesnt matter which way they bolt up as long as it is circulating. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted November 21, 2016 Compressors have a vacuum (suction) port, and a pressure (discharge) port. The hoses definitely need to be around the right way. Share this post Link to post Share on other sites
deankxf 20,288 Posted November 21, 2016 Compressors have a vacuum (suction) port, and a pressure (discharge) port. The hoses definitely need to be around the right way. would it work as a heater if backwards Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 21, 2016 the thing is gunna turn the same direction Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 21, 2016 hey your right i just looked up the air con cattledog and the er 210r is the righthand suction and er210L is the left hand crossy one ? Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 22, 2016 my suction is on the bottom,can someone else with a v8 system like this confirm there suction and discharge levels please,i have seen many pictures of york air con systems and the top one goes to the firewall which would be the discharge right ? if thats correct then this compressor is compatable . Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 22, 2016 82 compressor still works well. Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted November 22, 2016 Suction goes to the firewall, and discharge goes to the condensor, in front of the radiator. 1 stockesp reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 22, 2016 ok cheers Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted November 28, 2016 looks like a special tool is needed to take the old clutch off Share this post Link to post Share on other sites
