Mustardxf 29 Posted May 24, 2015 Hey guys I have a freshly rebuilt crossflow with 0hrs run time. I also have a MSD street fire ignition box, Blaster 3 coil and using a vac advanced dizzy from 85 model xf. To bed the cam in should I just run it using the standard ignition system? then install the aftermarket system once the motor is run in and running? I ask this because I don't want to have any problems on the initial start up and would like it to start straight up and not have it sitting there cranking because something isn't going right with the MSD. cheer. Share this post Link to post Share on other sites
PRO250 1,506 Posted May 24, 2015 Sounds like a good idea to me Share this post Link to post Share on other sites
slydog 7,873 Posted May 24, 2015 More importantly prime oil pump till oil is coming out of the push rods,then re-fit dizzy. Share this post Link to post Share on other sites
Mustardxf 29 Posted May 24, 2015 Before I got the engine back they did quickly prime the engine with oil. I presume that they were priming the oil pump. Share this post Link to post Share on other sites
slydog 7,873 Posted May 24, 2015 Annnnnnnnnd 1min the oil is already running back down. Don't take any ones word for doing anything on a fresh engine and prime the oil pump before you start it. Don't be lazy just do it right or run the risk. 2 PRO250 and wagoon reacted to this Share this post Link to post Share on other sites
Mustardxf 29 Posted May 24, 2015 Yeah will prime it again to be safe.Anything else I should do? Share this post Link to post Share on other sites
slydog 7,873 Posted May 24, 2015 Get someone to help you,have a timing light ready,hose or watering can ready. Have the engine full of fresh run in oil like joe gibbs stuff and a quality ph for time keeping and video to post up. Share this post Link to post Share on other sites
Mustardxf 29 Posted May 24, 2015 Cheers sly, Will post a video of first start up in about 2 weeks! Share this post Link to post Share on other sites
bear351c 10,270 Posted May 24, 2015 Yep agree +1. Doesn't matter what engine, oil prime is KING.! Good luck with it. 1 slydog reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted May 24, 2015 Yep as above. Prime that sucker the day that you are going to fire it. turn the engine by hand and make sure oil flows from every pushrod BEFORE you try and fire it. as for ignition systems - I think the street fire will be fine. lock the timing at 25 odd and away you go. just don't let that sucker idle. there is nothing wrong with firing it - checking timing and shutting it down and re-adjust. check timing and fire again and run at 2500. the main thing is don't let that sucker idle during camshaft run it. That and get some camshaft break in lube - comp cams of lucas is fine. make sure the cooling system is up to it and have a fan to blow some air through the radiator - just to help shit out. Good luck 1 Mustardxf reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted May 24, 2015 I like every post in this thread Share this post Link to post Share on other sites
Mustardxf 29 Posted May 24, 2015 Yep as above. Prime that sucker the day that you are going to fire it. turn the engine by hand and make sure oil flows from every pushrod BEFORE you try and fire it. as for ignition systems - I think the street fire will be fine. lock the timing at 25 odd and away you go. just don't let that sucker idle. there is nothing wrong with firing it - checking timing and shutting it down and re-adjust. check timing and fire again and run at 2500. the main thing is don't let that sucker idle during camshaft run it. That and get some camshaft break in lube - comp cams of lucas is fine. make sure the cooling system is up to it and have a fan to blow some air through the radiator - just to help shit out. Good luck Always great post by you Ando. With the ignition I just thought it would be easier to use the standard ignition just for the run in, incase the street fire doesn't want to work with me on the day. and the thought of just having it sit there cranking doesn't make me feel right aha. just don't want to damage the fresh engine. Share this post Link to post Share on other sites
ando76 4,354 Posted May 24, 2015 Go with the standard ignition then if you are worried but really MSD systems either work or they don't in my experience. 100 times out of 100 it is a dizzy or coil issue that usually gets blamed on the poor old MSD. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
