Trent250 21 Posted February 18, 2015 Hi guys, this has probably been discussed before but I can't find much info on it.. I have a TFI dizzy that I need to fit along with the msd 6al-2 programmable box.. Has anyone done this before? Is so how u wired it up would be great... I'm going to be trying to do it in a few weeks so need to see what I have to do.. Cheers.. Share this post Link to post Share on other sites
slydog 7,873 Posted February 18, 2015 1 3 gerg, Jonathan Mark Davidson and Thom reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted February 18, 2015 and if you happen to find a high volume oil pump lying around - then subject it the same treatment as the said module. 3 Thom, gerg and slydog reacted to this Share this post Link to post Share on other sites
XFGHIA747 76 Posted February 19, 2015 Question with this ? Im guessing the timing will be locked or does the tfi advance? Would this work with just a normal msd 6al? Share this post Link to post Share on other sites
XFGHIA747 76 Posted February 19, 2015 Ahh yes cheers rob, so im guessing this would be the best way of ignition because you could alter the way the advance comes in and where? Share this post Link to post Share on other sites
slydog 7,873 Posted February 19, 2015 1 1 wagoon reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted February 19, 2015 That's just cause mine isn't built yet. bahahahahahahaha 1 wagoon reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 19, 2015 Ahh yes cheers rob, so im guessing this would be the best way of ignition because you could alter the way the advance comes in and where? Â That's the entire reason for going programmable, you eliminate all factory advance weights/vac advance by locking the dizzy and dialing in your own curve to whatever your engine wants. This is great for street/performance engines but race engines such as the ones Sly mentioned like straight-timed (or "locked") dizzys because of the burn characteristics of a big cam, big comp engine. Â That said, even a race donk can take a bit of a curve if you want to fine-tune the lower rpm band. Share this post Link to post Share on other sites
Trent250 21 Posted March 6, 2015 I've been talking to a local guy who races 250 crossflow and he said the TFI dizzy isn't worth the hassle as the module dies very quickly... So my question is, what's the difference between a TFI dizzy with the module removed so 3 wires and the dizzy with 2 wires coming out of it? There both electronic so is there any difference between the dizzy it's self? Cheers Share this post Link to post Share on other sites
ando76 4,354 Posted March 6, 2015 Trent 250 - time to start listening to the people on this forum that actually know what they are talking about like Rob and dare I say me.  READ the thread "need help, missing high performance crossflow". The author of that thread is no newbie wantabe and has been racing for a damn long time. I spoke with him personally so I know his credentials. He tried everything to make the XE style dizzy work - as most people - including me, have done. Put simply - THEY ARE USELESS IN ANYTHING BUT A STANDARD APPLICATION.  He went to TFI and guess what - problem solved. Notice how he is no longer contributing to the thread - That is because he fixed the issue. He is not a big forum person and only joined as he had tried everything to make the XE style dizzy work and in desperation he turned to this very forum and LISTENED and TOOK the advice of those in the know and look - No more problems.  I know its hard knowing who to trust sometimes BUT mate you need to TRUST the people on here. We are here to help and we HAVE some of the toughest x-flow in the country under our belts.     1 Trent250 reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted March 6, 2015 power to weight - power to weight. Plug 200hp and 650kg into the moroso calculator. That's the BIL's mini Share this post Link to post Share on other sites
Trent250 21 Posted March 7, 2015 Trent 250 - time to start listening to the people on this forum that actually know what they are talking about like Rob and dare I say me.  READ the thread "need help, missing high performance crossflow". The author of that thread is no newbie wantabe and has been racing for a damn long time. I spoke with him personally so I know his credentials. He tried everything to make the XE style dizzy work - as most people - including me, have done. Put simply - THEY ARE USELESS IN ANYTHING BUT A STANDARD APPLICATION.  He went to TFI and guess what - problem solved. Notice how he is no longer contributing to the thread - That is because he fixed the issue. He is not a big forum person and only joined as he had tried everything to make the XE style dizzy work and in desperation he turned to this very forum and LISTENED and TOOK the advice of those in the know and look - No more problems.  I know its hard knowing who to trust sometimes BUT mate you need to TRUST the people on here. We are here to help and we HAVE some of the toughest x-flow in the country under our belts.  It makes sence and thanks for explaining it...I think I have the est dizzy atm so do u guys reckon I should look for a TFI dizzy and remove the module and hook it up from there? Cheers Share this post Link to post Share on other sites
ando76 4,354 Posted March 7, 2015 The EST will work well - use it unless you find an issue. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Trent250 21 Posted March 9, 2015 If I'm running the est atm, what has to be done to change it over to TFI? I'm not running msd yet so just which wires go where... I might do that first if it's not too much trouble then msd.. Share this post Link to post Share on other sites
Trent250 21 Posted March 14, 2015 I've decided to go the TFI dizzy and rip the module of the side and just have the 3 wire... How have u guys connected it, like a plug or something? Also how do I water proof it... Cheers Share this post Link to post Share on other sites
Trent250 21 Posted March 17, 2015 ok, I've decided to go TFI, just wondering if people have had trouble with it fitting under the manifold.. Looks like it would be very tight.. Share this post Link to post Share on other sites
