bear351c 10,273 Posted October 2, 2014 Hi all, Got some B45's in the shed, offset is shallow to suit EF/EL ? Falcon, would like to change offset to suit deep dish on an XA Sedan. Anyone wearing these, who could measure back space/offset for me? Need to troll around the auction sites for the correct offset for 16" rims. Any ideas on max width tyre/rim combo? Share this post Link to post Share on other sites
gerg 10,871 Posted October 2, 2014 I thought all Falcs up to but not including AU were the same offset (not including hub centre diameter). I've got EA snowies on my XE and they seem right. I reckon they're AU-onwards 1 bear351c reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted October 2, 2014 Looking at those rims they have a front wheel drive offset which is +35 or more ie AU onwards. E series is +6 which would put the mounting surface a lot closer to the centre of the rim. I'll go out on a limb and say the ones in your pics are 16x8 with +42 offset 1 bear351c reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted October 2, 2014 Yeah they don't look right for pre AU. 1 bear351c reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted October 2, 2014 I bought a set of simmons with an offset like yours mate. Definitely didn't fit on xf as they were more like au offset of +35mm. With basically no dish on them they are going to hit on top and bottom ball joints. Share this post Link to post Share on other sites
Ando81 2,949 Posted October 2, 2014 So a simple way to measure offset is to lay the wheel on a piece of carpet, face down and put a straight edge across the tyre on the dirty side. Measure through the spokes from the carpet to the bottom of the straight edge which should be roughly say 240mm then half that measurement =120mm then measure from the bottom of the straight edge to where the stud holes are on the dirty side. This will prob be roughly 155mm. The 120mm is the measurement halfway across the width of the rim and if your measurement from the rim to where the rim mounts to the studs is 155mm then your offset is +35mm get it? 155mm-120mm = 35mm sorry but it's hard to explain without pics and I'm not a genius so hopefully you can make sence of it. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted October 2, 2014 Thanks guys, perhaps my original post was misleading. I dont want this offset, but, want to know which offset will fit on my XA sedan. So, I can go searching for some Simmons inner and outer rings. Will be keeping the B45 centres. Share this post Link to post Share on other sites
wagoon 2,429 Posted October 3, 2014 Sorry mate. Yeah the only difference between wheels from xy to ef was the centre bore size. I do believe your xa will be small bore and these wheels being for Au onwards it will have the big hole which will require using a locating ring which can be had at any good tyre place. Offset was all the same from xy to ef at +6mm (although Im sure someone will correct me as I believe xy had +5.5mm as its actually an imperial measurement or something like that) so on an 8 inch rim there should be around 4 1/4 inches from mounting surface to rear of rim. Then measure how far the mounting surface is from the face where the centre attaches to the ring and that will tell you how wide the rear ring needs to be. Maybe send Ants a pm as he has them on his xe and he might measure the rings for you. 2 Ando81 and bear351c reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted October 6, 2014 depends how wide you want the wheels. usually on simmons, i see the back half with .5" extra width ex: 16x7 inners of 3.75" outers of 3.25" on a 225/50/16 tyre that works perfect on the front end. i know that combo works first hand. you can go down to a .25" difference with ease (thats 6.35mm) with good clearance of front guards. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted October 7, 2014 Thanks, mate. Just looking for nice deep dish on the back, driveable on the front. 265 or so on the rear tyre, and 215-225 on the fronts. Daily driver, no track work, etc..... (PM sent to Ants.) Share this post Link to post Share on other sites
Ants 6,370 Posted October 7, 2014 Sorry man haven't been home in daylight after work and the xe isn't in the shed. Should be right for tomorrow night. 265/16s can prove very hard to find, I'd have a hunt for tyres before you decide on size. Share this post Link to post Share on other sites
bear351c 10,273 Posted October 7, 2014 Wasn't pushing mate, haven't even got the XA rego'ed yet>!! No rush at all. Yeah, tyres may be an issue, which is why I'm looking at rims/tyres/sizes now. Just happened to have the B45's, and love the deep dish look (as on your XE). Want to start looking around, for correct offsets, whether I should sell the Simmons and buy whole different set, all that sort of stuff. Share this post Link to post Share on other sites
Ants 6,370 Posted October 7, 2014 All good mate. I'd go a little smaller on the front on another xdef, but they might be ok on xa because i think from memory they have more room. Measuring them up on my xb might be a good excuse to see how they suit it Share this post Link to post Share on other sites
bear351c 10,273 Posted October 7, 2014 Oooooh yeah............don't foget photos.! Love your XB. Share this post Link to post Share on other sites
Ants 6,370 Posted October 8, 2014 Front are roughly 4" inner and outer, rear roughly 4.5" inner and outer. So 8's and 9's. 1 bear351c reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted October 8, 2014 Ants do the fronts rub on anything? Share this post Link to post Share on other sites
Ants 6,370 Posted October 8, 2014 Yeah the guards like mad. They are fine on the inside. 1 wagoon reacted to this Share this post Link to post Share on other sites
Farkin351 201 Posted October 11, 2014 If your gonna order new inner and outer rings maybe step them up to 17" to give ya a better range of tyre. Been thinking of doing the same with my 15" B45s. Just a thought. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted October 11, 2014 Yeah, hadn't thought of that. Thanks. Share this post Link to post Share on other sites
Farkin351 201 Posted October 13, 2014 http://www.metalspinnersaust.com.au/metal-spun-wheels.html I had emailed these guys, they said they can do it. But just recently i noticed Simmons Wheels Australia facebook page advertised about changing wheels out to 17" or more. 2 bear351c and Trev Vaa reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted October 13, 2014 Thanks Farkin, will look into that. Share this post Link to post Share on other sites
