dizzy616 183 Posted August 26, 2014 okay so it appears my new block is a hybrid motor.so it looks like i can get away with a dizzy in the block.i was wondering are these blocks non vct?would it be more cost effective in the long run to use the au head? are the au heads actually any better?mine appears to have a steel sump. so if im correct. i should still be able to stick it in a xf with no sump mods?what are things i need to worry about with this motor? as i want to just do a straight swap.run it all on xf wiring loom. like im doing with the current sohc. put the old manifold on the block and old exhaust system. and run my gas system. distributor. coil etcso basicly everything i am using at the moment. to run my 3.9 in the xf. swapped over to run the hybrid motorwill it work? 1 xm-221 reacted to this Share this post Link to post Share on other sites
Stevemack 122 Posted August 26, 2014 The crank is girdled, EF-EL head flows better stock than AU. I relocate the coil pack from an EF on top of the rocker cover and ditch the dizzy. They are non VCT. The way you want to run it will work though. Share this post Link to post Share on other sites
dizzy616 183 Posted August 26, 2014 cool as. Fark wish i didn't put all that money into a head and stick it on my 3.9 now. might see if i can do a swap with someone.aren't they a au style crank and rods.would a coilpack work with msd? as i got 6al2 on the waybut yeh i stuck a dizzy in the block. its got the hole and cog all looks like it should work. just needed to make sure. Share this post Link to post Share on other sites
Menice 331 Posted August 26, 2014 early au crank, el rods and pistons, au head... thats basically all a hybrid is, got one in my eb atm dizzy is fine, thats what i'm running with log manifold and eb loom 1 dizzy616 reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted August 26, 2014 sweet. cheers mate Share this post Link to post Share on other sites
SPArKy_Dave 8,885 Posted August 26, 2014 Just did a rocker cover gasket, on the Hybrid Motor in my Dad's EL. it's an August 98 build from memory. It has a 96DA head, with the beehive springs, smaller 7mm valve stems and AU spec 1.7:1 rocker ratio / cam. We've had it since new.......the engine had never been opened, before I did the rocker cover gasket. 2 Outback Jack and dizzy616 reacted to this Share this post Link to post Share on other sites
