xfish 20 Posted August 19, 2014 Hey Guys, Is there anywhere in Australia the sells the XG Colum lock, where the barrel goes into.? I found plenty of new replacement barrels, but cant locate the Colum lock. I find the tibbe key works better than the standard XF key, and barrel. I phoned all local ford shops here in WA, and they are no longer stocked. Any idea's anyone? Share this post Link to post Share on other sites
slydog 7,873 Posted August 19, 2014 Local Locksmiths... Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted August 19, 2014 They were originally made by Bosch Australia. You may find that an autoparts place could order one in for you maybe? An XG/XH tibbe lock barrel, should fit in the XF ignition lock assy - or doesn't it fit? Share this post Link to post Share on other sites
Gaz 1,085 Posted August 19, 2014 Doesn't fit Dave. How much do you want to pay for a good second hand one with barrel and key? Share this post Link to post Share on other sites
xfish 20 Posted August 19, 2014 Sorry, but it dose fit perfectly, but only the XG......I have both my XF's with them in. Share this post Link to post Share on other sites
Gaz 1,085 Posted August 19, 2014 Sorry but it doesn't fit perfectly. The whole assembly will fit an XF perfectly but Daves question was will the Tibbe barrel fit the XF assembly. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 20, 2014 Sorry but it doesn't fit perfectly. The whole assembly will fit an XF perfectly By whole assembly you mean the barrel and steering lock together right? The whole part that clamps around the steering column? Just curious, that would be a good way to improve security I imagine. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 20, 2014 Don't suppose that the door locks fit though? Share this post Link to post Share on other sites
deankxf 20,319 Posted August 20, 2014 Don't suppose that the door locks fit though? they are different on the doors, i was oneday going to see if the XG/XH ute/pano spare wheel lock would work? as i had a feeling they are same as the XD-XF door locks.. needs investigationing one day. you could fit XG/XH doors, but they are rarer and would need to fit the striker too which mounts a bit different. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 20, 2014 they are different on the doors, i was oneday going to see if the XG/XH ute/pano spare wheel lock would work? as i had a feeling they are same as the XD-XF door locks.. needs investigationing one day. you could fit XG/XH doors, but they are rarer and would need to fit the striker too which mounts a bit different. XH uses a winch to hold the spare tyre in place, XG spare wheel door lock is like the XA-XF, just a door lock, cant remember if its a left or right hand one?? Share this post Link to post Share on other sites
deankxf 20,319 Posted August 20, 2014 XH uses a winch to hold the spare tyre in place, XG spare wheel door lock is like the XA-XF, just a door lock, cant remember if its a left or right hand one?? i thought left and right door locks are same? just swap over the doover thingy.. the XG spare wheel lock should work then? what are the pano barn door locks like? if same, could get enough for 2 doors and ign with same key Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 20, 2014 Thought I'd read before they're different. But Mark is it a old fashioned key lock or XG lock? Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 20, 2014 Barn doors have there own lock and key. Spare wheel lock is the door lock so it uses the door/ignition key. XG uses the E series style key. But the mechanism that bolts to the spare wheel door i would think that'll be the same from XA-XG. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 20, 2014 So it could be adaptable to a door, but then you'll never get two locks the same, and as you mentioned the spare wheel door is only left or right, not both. EDIT: Just checked, is a passenger lock. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 20, 2014 So it could be adaptable to a door, but then you'll never get two locks the same, and as you mentioned the spare wheel door is only left or right, not both. EDIT: Just checked, is a passenger lock. Cheers mate, couldnt remember what side lock it was, i had to replace mine when i bought my XF. Share this post Link to post Share on other sites
deankxf 20,319 Posted August 20, 2014 Cheers mate, couldnt remember what side lock it was, i had to replace mine when i bought my XF. are you sure the locks are different left and right? i swapped mine over when the drivers one got butchered(by Me) the circlip comes off and swap the lever over from memory. Share this post Link to post Share on other sites
xfish 20 Posted August 20, 2014 By whole assembly you mean the barrel and steering lock together right? The whole part that clamps around the steering column? Just curious, that would be a good way to improve security I imagine. Yes, the whole assembly. You have to cut a wire harness off the steering lock of the XG, but everything else bolts up the same. Looks cleaner,.....i've had a few people not belive me that they fitted. Got a few cartons that way.... Share this post Link to post Share on other sites
