magik88 0 Posted April 3, 2014 Hey guys wants to put 351 clevo and c10 box in my 85 xf wagon jjust want to see if anyone has redirected hoses properly without bashing or cutting pipes etciif u have done it I'd love to c some pic's cheers magik Share this post Link to post Share on other sites
Thom 6,655 Posted April 3, 2014 does your car have aircon? are you going to use it? if not use the aircon core instead as a heater core Share this post Link to post Share on other sites
Scottee XDFwreck 42 Posted April 3, 2014 Ive done it but 25 years ago and no pics. Turn the heater core upside down, Drill new 30mm holes in the case & firewall, plug the old holes, done... 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 3, 2014 does your car have aircon? are you going to use it? if not use the aircon core instead as a heater core I tried this, only problem was air was always hot, never cold, regardless of temp position. Went back to proper outlets, and cold air worked again. Share this post Link to post Share on other sites
Thom 6,655 Posted April 3, 2014 did you still use a heater tap? I've seen it done on an xg with a 5.0 in it and it worked a treat Share this post Link to post Share on other sites
SLO247 1,713 Posted April 3, 2014 You still need a tap on it. Haha. Should work fine with a tap. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 3, 2014 Yeah, had a brand new tap. Same one it has now. Â Maybe I have a dodgy A/C core or something? Or the tap was in the wrong hose? Â If you want to connect heater hoses to A/C core you need to reduce the hose size down for one of the hoses. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 3, 2014 Ive done it but 25 years ago and no pics. Turn the heater core upside down, Drill new 30mm holes in the case & firewall, plug the old holes, done... Â Just the core, not the whole box? Where does that relocate the holes to? Share this post Link to post Share on other sites
bear351c 10,276 Posted April 4, 2014 I thought the Clevo fit, with a slight massage of the firewall, behind the right hand side rocker cover. ? 2 Stevemack and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
magik88 0 Posted April 4, 2014 No I'd like to keep it nice no bashing etc just redirecing Share this post Link to post Share on other sites
scottly 475 Posted April 4, 2014 ford the heater use 90 degree elbows where it exits into the bay Share this post Link to post Share on other sites
Scottee XDFwreck 42 Posted April 6, 2014 The heater core only not the case! the tubes come out at the top of the firewall, just like the XD & XE does... Share this post Link to post Share on other sites
