slydog 7,873 Posted October 17, 2013 I'd love to send my A0016 over bro but till I get a spare that can't happen unfortunately.I know Jase use to move his carb closer to the head mounting side on the Cain/Redline style units for a even plug colour burn which worked for him.But like everything I belive there is gains to be had in the A0016 with some tweaks to suit my combo.The base unit carves the Cain/Redline unit over 5000ish revs but by how much and if it could be improved is unknown. Ideally I'd spin it around east/west style with the primary's on the shock tower side and square jet the carb first off then work on the rest.But the 1 thing I have found 4 barrel xflows seem to like is a mountain of carby spacers,no less than 2" but can't tell ya if it's the same for Methanol.Sorry dude brain is spinning ATM and just had to get it out as I have a skid party coming up in Easter and I reckon I'll bang a slapper xflow together for it using my old 4 barrel and A0016 on Methanol...just need a car to do it to now seeing as the ute will be too pretty now 1 Clevo120Y reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted October 17, 2013 Never to pretty to skid - especially when you could fit some au 16's and they would tuck right in. Clevo I'll send a manifold down once I get my stuff together. Just waiting for the other new one to arrive and then I'll be out playing. 1 Clevo120Y reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted October 18, 2013 Well my first plan to fill the voids was to do this, But that was a big FAIL, the cast alloy and ally sheet don't like to be welded together when the sheet is so thin, if the ally sheet was nice and thick it could be done, so I just filled the whole void with filler rod instead, here is a pic of it filled and roughing out the shape, after the pic I filled the little bits left over and cleaned up the inside of the runners again. Now I have mounted the sections to a head ready to weld the sections together, after I have done that I will blend everything all nice into the runner sections and then start the middle section/plenum, I don't work weekends so Monday I will get back into it. Share this post Link to post Share on other sites
deankxf 20,341 Posted October 18, 2013 might need to boil up some rusty dirty water to give it the "lived in a wreckers yard" look spray on "affected areas" pics are awesome.. its like the sleeper equivalent of engine parts 2 Clevo120Y and Thom reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted October 18, 2013 One method I have used to achieve the "as cast" look is to grind the surface smooth the use a very low grit sand paper and hammer it over the surface many different ways untill ti looks like a legit factory part, a second method I have used (but doesn't work as well) is to use crinkle black paint as a primer then rough it up (again using a low grit sand paper) and paint with the closest colour you can find to match aluminium in its raw state 2 Clevo120Y and deankxf reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted October 19, 2013 I'm going to try that one, thanks Thom Share this post Link to post Share on other sites
Clevo120Y 815 Posted October 27, 2013 Not the crossflow manifold but here is an ecotech manifold I've been working on, picked up over 4% of flow through out the lift range, this manifold is to suit a stock headed mild cam ecotech engine, it will make good gains right across the rev range. Just need to sell it now LOL. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,341 Posted October 27, 2013 does it fix the horrible noise that comes out the exhaust pipe on them? 3 Lord_fahrquhar, Clevo120Y and slydog reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted October 27, 2013 Nah sorry, thats more the shit coming out of the driver that you can hear LOL 2 Ando81 and slydog reacted to this Share this post Link to post Share on other sites
