xebruce 50 Posted July 3, 2013 got an xe with a 302 in it. when I got it it would start rough when cold the go good once warmed up. condensation out the exhaust. assumed gasket leak. gave it a hiding the other day when I went to start it next it went like shit. pulled the heads off and they look pretty new. no noticeable gasket leaks but got a bent push rod????? taking the heads to get checked tomorrow. any ideas where else to look? Share this post Link to post Share on other sites
revhead 1,392 Posted July 3, 2013 if youve bent a push rod look at your valve springs ,also check the cam ,pull out a couple of lifters if the pitted on the bottom there buggered , Share this post Link to post Share on other sites
xebruce 50 Posted July 3, 2013 thanks will check the lifters out tomorrow Share this post Link to post Share on other sites
slydog 7,873 Posted July 3, 2013 Old clevo's bend pushrods a bit so I would have put a new one in that hole and it would have been fine.Done a few of em... 1 Jonathan Mark Davidson reacted to this Share this post Link to post Share on other sites
Trevor 326 Posted July 3, 2013 Some lifters will go hard, so probably best to replace them all Share this post Link to post Share on other sites
bear351c 10,273 Posted July 3, 2013 If the base of the lifter is cactus, so is the lobe on the cam........ 1 revhead reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted July 4, 2013 dw i bend mine all the time, pull them out, put them in a vice and vwoalla, more 6500rpm abuse nah seriously get hardened ones. 1 bear351c reacted to this Share this post Link to post Share on other sites
Trevor 326 Posted July 4, 2013 we run anti-pump up lifters and chrome molly rods As an aside, do you have a high flow oil pump on it? 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted July 4, 2013 new stage 2 cam lifters ,new double row timing set ,or pete jackson gear set, new lifters, case hardened rods, all set to rev again Share this post Link to post Share on other sites
ILIED 316 Posted July 4, 2013 Soft valve springs equals valvefloat. Valve float equals bent pushrod. You can replace the rods with better ones, which you should, but prob be advantageous to put some decents springs in it. 2 Trev Vaa and revhead reacted to this Share this post Link to post Share on other sites
xebruce 50 Posted July 11, 2013 Just got the heads cleaned and tested and they are all good. but nothing on them is. new valves, springs, seats, guides , retainers fitted. $1100 later. Share this post Link to post Share on other sites
bear351c 10,273 Posted July 11, 2013 Wow.! But still, you'll get years and years out of them. Share this post Link to post Share on other sites
Trevor 326 Posted July 11, 2013 Don't forget to replace your lifters while you have the heads off, you will be sorry if you don't And shit that was a lot of money, but hell if it is better, then all good Share this post Link to post Share on other sites
xebruce 50 Posted July 11, 2013 Live right at the bottom of nz so theres not a lot of options when it comes to places to do the work. I guess they can really charge what they like. suck Share this post Link to post Share on other sites
xebruce 50 Posted July 11, 2013 Just priced some lifters $120 for the set? and getting a price for some hardened push rods what should I expect to pay for these. Share this post Link to post Share on other sites
Trevor 326 Posted July 11, 2013 we paid $10AU each about 5 years ago for chrome molly pushrods My grandfather came from Invercargill Share this post Link to post Share on other sites
gerg 10,871 Posted July 11, 2013 Just priced some lifters $120 for the set? and getting a price for some hardened push rods what should I expect to pay for these. Precision International - 17 bucks for a set of 4 US-made Johnson HiLift Hydraulic type. That's 68 bucks for a V8, Probably 90 bucks to your door. Get a cam while you're at it, their Dynotec cams are only $121 and are the same blanks as Crow. Good insurance, otherwise your old cam has to break in all over again with the new lifters.... Ask me how i know. Share this post Link to post Share on other sites
xebruce 50 Posted July 11, 2013 we paid $10AU each about 5 years ago for chrome molly pushrods My grandfather came from Invercargill I think its a great place to live. Bit cold for you Aussies though brother inlaw moved here a couple of years ago from noosa. Finding the winters a bit chilly. Share this post Link to post Share on other sites
xebruce 50 Posted July 11, 2013 Precision International - 17 bucks for a set of 4 US-made Johnson HiLift Hydraulic type. That's 68 bucks for a V8, Probably 90 bucks to your door. Get a cam while you're at it, their Dynotec cams are only $121 and are the same blanks as Crow. Good insurance, otherwise your old cam has to break in all over again with the new lifters.... Ask me how i know. Go on then, how do you know? Share this post Link to post Share on other sites
gerg 10,871 Posted July 11, 2013 Go on then, how do you know? here's my thread on crook cams and lifters: http://www.ozfalcon.com.au/index.php?/topic/962-Best-camshaft-brands---Aussie-preferred Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted July 12, 2013 try crower lifters dude, absolutely top notch components. Share this post Link to post Share on other sites
xebruce 50 Posted July 21, 2013 Put it all back together. Started it up and it ran mint. Had it running for about half an hour. Turned it off and when I went to drive it home a couple of hours later it was running like shit when I started it doing excactly the same thing it was before I pulled it apart. Share this post Link to post Share on other sites
revhead 1,392 Posted July 21, 2013 so did you change the cam and valve springs and push rods,this is a must to solve your problem. if you only did a short cut,it will keep buggering up! Share this post Link to post Share on other sites
xebruce 50 Posted July 22, 2013 did pushrods and the heads got a recon. new everything. Cam and lifters seemed fine Share this post Link to post Share on other sites
