Nato of Falcons 23 Posted April 19, 2023 So yeah Ive got this panel van 1984 with a crossflow 250 in it carby, im restoring and the bloke who had it before me says he only took the line from the tank and stuck it in a bottle because of rust in the tank. Well Ive gotten rid of the bottle flushed the tank and hooked up the hoses, but, it doesnt start, if I take the hose off and stick it back in the bottle it works. Fuel filter is on, kicks over fine and It kicks over if I put petrol down the carby. Im kind of stumped now, is it possible a wiring thing? Im kind of stumped now because its got gas, its got the connections all in and it should start sucking fuel but doesnt? Please and thank you's as always Share this post Link to post Share on other sites
deankxf 20,347 Posted April 19, 2023 1 hour ago, Nato of Falcons said: So yeah Ive got this panel van 1984 with a crossflow 250 in it carby, im restoring and the bloke who had it before me says he only took the line from the tank and stuck it in a bottle because of rust in the tank. Well Ive gotten rid of the bottle flushed the tank and hooked up the hoses, but, it doesnt start, if I take the hose off and stick it back in the bottle it works. Fuel filter is on, kicks over fine and It kicks over if I put petrol down the carby. Im kind of stumped now, is it possible a wiring thing? Im kind of stumped now because its got gas, its got the connections all in and it should start sucking fuel but doesnt? Please and thank you's as always if it had a rusty tank, it's could have plugged up the fuel lines with rust or rusted them also (metal lines) there's also a hose join under the passenger side footwell/sill area where 2 steel hoses join with a rubber hose . if this hose is cracked it will suck AIR rather than fuel (easier) and therefore no fuel to the carby. check the hose join first the hoses are 40yrs old nearly if original. (stuffed) had many 10yrs ago with this issue. 1 omgwizards reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 19, 2023 Deano coming back to help me again, much appreciated, I will check this tomorrow morning, it looked good from what I could tell when I first checked but I didnt check if there was a blockage. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,347 Posted April 19, 2023 34 minutes ago, Nato of Falcons said: Deano coming back to help me again, much appreciated, you'll need to rely on @SPArKy_Dave in 12 days time, I'm taking a break for an unknown time. few other members on the ball but many have been slowly stepping back also. the information is here, and you'd probably read about fuel line blockage in the gregorys manual also 3 Fingers, Nato of Falcons and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 19, 2023 Yeah Ill hopefully find some stuff in there about it, well I appreciate the help, safe travels in whatever you do mate! 1 deankxf reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted April 19, 2023 If there is a blockage (and you've checked the rubber hose isn't cracked suckin air like Dean said) in the line or pickup you can usually clear it by blowing compressed air backwards through the fuel line to clear it, unfortunately that will dump whatever is in the lines in the tank, its probably a good idea to pull the sender out of the tank and clean it and clean the fuel line while the sender is off 2 Nato of Falcons and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted April 19, 2023 Blocked vent in the fuel cap.?? Try running it without the cap on. Sounds like a blocked filter, maybe one under the car where you can't see it.? 3 Nato of Falcons, deankxf and Thom reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 19, 2023 7 hours ago, bear351c said: Blocked vent in the fuel cap.?? Try running it without the cap on. Sounds like a blocked filter, maybe one under the car where you can't see it.? I did take the cap off thinking it was going to be something like this maybe but the same thing. Thanks for all the help team, im going to be working on it in an hour or two and will keep you all updated! 2 omgwizards and deankxf reacted to this Share this post Link to post Share on other sites
omgwizards 13 Posted April 20, 2023 How did it go? I'll probably be in a similar situation soon (Crossflow with carby - works fine when using a jerry can, but soon to be reconnecting gas tank) So I'm thinking, try a fuel pressure gauge at various places along the line. A working fuel pump provides 24 - 35 kPa at idle. Between the fuel tank and the fuel pump there needs to be negative pressure. If there is a leak or a blockage you'll see a change in pressure on either side. Share this post Link to post Share on other sites
deankxf 20,347 Posted April 20, 2023 27 minutes ago, omgwizards said: How did it go? I'll probably be in a similar situation soon (Crossflow with carby - works fine when using a jerry can, but soon to be reconnecting gas tank) So I'm thinking, try a fuel pressure gauge at various places along the line. A working fuel pump provides 24 - 35 kPa at idle. Between the fuel tank and the fuel pump there needs to be negative pressure. If there is a leak or a blockage you'll see a change in pressure on either side. if you are handy you can try some whipper snipper cord into the fuel line, if its' free it should go a fair way on the straight runs (not sure on the bends) the blockages i had were close to the pipe ends within 50cm from the ends at least Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 20, 2023 12 hours ago, omgwizards said: How did it go? I'll probably be in a similar situation soon (Crossflow with carby - works fine when using a jerry can, but soon to be reconnecting gas tank) So I'm thinking, try a fuel pressure gauge at various places along the line. A working fuel pump provides 24 - 35 kPa at idle. Between the fuel tank and the fuel pump there needs to be negative pressure. If there is a leak or a blockage you'll see a change in pressure on either side. Sorry ive been sick (bit by a spider and it really rocked me hahha) ill be working on it this arvo and will def keep you posted to what happens. 1 omgwizards reacted to this Share this post Link to post Share on other sites
deankxf 20,347 Posted April 20, 2023 11 minutes ago, Nato of Falcons said: Sorry ive been sick (bit by a spider and it really rocked me hahha) got to watch out for redbacks working on old cars, My cars have them from sitting a long time, definitely get the surface spray out if it was from the car. and also a flea bomb type (i've had them in the air vents, in the wiper plenum, under the mudgaurds and bumpers (places you reach into to undo stuff) tip for redbacks, the web is STRONG, if you are brushing a web with a screwdriver and the web seems strong, it's likely a redback so go to town with the spray ( 2 people i've met had been bitten by them working on cars, one needed the hospital) 2 omgwizards and Nato of Falcons reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 20, 2023 2 minutes ago, deankxf said: got to watch out for redbacks working on old cars, My cars have them from sitting a long time, definitely get the surface spray out if it was from the car. and also a flea bomb type (i've had them in the air vents, in the wiper plenum, under the mudgaurds and bumpers (places you reach into to undo stuff) tip for redbacks, the web is STRONG, if you are brushing a web with a screwdriver and the web seems strong, it's likely a redback so go to town with the spray ( 2 people i've met had been bitten by them working on cars, one needed the hospital) Yeah def a good tip, I threw a few bug bombs in there a few weeks ago and they must have come back, got me on the leg and I tell you what, the itchiness was insane and yeah just had a bit of a nap haha all good just got real tired no life and death. Ill be on the lookout though a bit more now. 2 deankxf and omgwizards reacted to this Share this post Link to post Share on other sites
deankxf 20,347 Posted April 20, 2023 10 minutes ago, Nato of Falcons said: Yeah def a good tip, I threw a few bug bombs in there a few weeks ago and they must have come back, got me on the leg and I tell you what, the itchiness was insane and yeah just had a bit of a nap haha all good just got real tired no life and death. Ill be on the lookout though a bit more now. itchy sounds like Bullant or Wasp or white tail spider. redback = PAIN.. and lots of it. 1 Nato of Falcons reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 24, 2023 On 4/20/2023 at 8:24 PM, omgwizards said: How did it go? I'll probably be in a similar situation soon (Crossflow with carby - works fine when using a jerry can, but soon to be reconnecting gas tank) So I'm thinking, try a fuel pressure gauge at various places along the line. A working fuel pump provides 24 - 35 kPa at idle. Between the fuel tank and the fuel pump there needs to be negative pressure. If there is a leak or a blockage you'll see a change in pressure on either side. So I blew a bunch of old gas out of the line and some laquery kind of brown stuff but its flowing now. The problem is now it doesnt seem to be draggin up the fuel, im thinking the module in the fuel tank might be busted or perhaps a fuse/electrical part might not be working? Do these have a controller on them? Share this post Link to post Share on other sites
deankxf 20,347 Posted April 24, 2023 1 hour ago, Nato of Falcons said: So I blew a bunch of old gas out of the line and some laquery kind of brown stuff but its flowing now. The problem is now it doesnt seem to be draggin up the fuel, im thinking the module in the fuel tank might be busted or perhaps a fuse/electrical part might not be working? Do these have a controller on them? that laquery goop is what old fuel does when it goes rancid(or crusty crystals with the recent fuels) the tank pick up has a plastic screen on it that can plug up with the same gunk. there's nothing in it after that, just a pipe. i'd also check it still pulls from the bottle so you can confirm it's not blocked from goop since initially running. did you have a filter in the system for the bottle setup? i'd pull the tank sender/pick up out and have a look again. BARN FIND ADDS VALUE ... NOT! (maybe if you like working on crusty fuel lines, brake lines, perished rubber everything.) there's also hose leak potential (sucking air) from rusty metal lines and or other rubber sections to the tank. really need to treat it as 5 different sections now and rule out any issues in each one 2 Thom and Nato of Falcons reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 24, 2023 36 minutes ago, deankxf said: that laquery goop is what old fuel does when it goes rancid(or crusty crystals with the recent fuels) the tank pick up has a plastic screen on it that can plug up with the same gunk. there's nothing in it after that, just a pipe. i'd also check it still pulls from the bottle so you can confirm it's not blocked from goop since initially running. did you have a filter in the system for the bottle setup? i'd pull the tank sender/pick up out and have a look again. BARN FIND ADDS VALUE ... NOT! (maybe if you like working on crusty fuel lines, brake lines, perished rubber everything.) there's also hose leak potential (sucking air) from rusty metal lines and or other rubber sections to the tank. really need to treat it as 5 different sections now and rule out any issues in each one Stinks too! But im glad its not stuck now, I took both ends off the fuel line to check the air flow and it seems fine now with no blockages hey so thats a plus, but still wont pick up. Ive taken the fuel filter off now just to make sure it wasnt interfering but the damn battery died (im having suck a good luck day today haha) What ive done while its charging though, is take out the filter, run the pick up line straight from the fuel pump into a bottle of petrol and will try to kick it over tomorrow when its got some charge. Just to make sure its still goes good like it did before I got into the fuel tank side. 1 deankxf reacted to this Share this post Link to post Share on other sites
omgwizards 13 Posted April 24, 2023 Stinks too! But im glad its not stuck now, I took both ends off the fuel line to check the air flow and it seems fine now with no blockages hey so thats a plus, but still wont pick up. Ive taken the fuel filter off now just to make sure it wasnt interfering but the damn battery died (im having suck a good luck day today haha) What ive done while its charging though, is take out the filter, run the pick up line straight from the fuel pump into a bottle of petrol and will try to kick it over tomorrow when its got some charge. Just to make sure its still goes good like it did before I got into the fuel tank side.Are you testing flow with positive pressure? Because the line flows using suction. Could the suction be collapsing the line somewhere?Sent from my SM-F936B using Tapatalk 1 Nato of Falcons reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 24, 2023 4 minutes ago, omgwizards said: Are you testing flow with positive pressure? Because the line flows using suction. Could the suction be collapsing the line somewhere? Sent from my SM-F936B using Tapatalk It very well could be, I am going to test the line a bit more tomorrow because the wife can assist in a couple of tests haha. Also helps that the battery will be charged as well. I certainly will keep you posted but over all the steel lines seem fine so far, the rubber seems ok? But for sure will test pressure tomorrow. 1 deankxf reacted to this Share this post Link to post Share on other sites
Fingers 466 Posted April 24, 2023 On 4/19/2023 at 8:11 PM, deankxf said: you'll need to rely on @SPArKy_Dave in 12 days time, I'm taking a break for an unknown time. few other members on the ball but many have been slowly stepping back also. the information is here, and you'd probably read about fuel line blockage in the gregorys manual also I have been keeping an eye on here more since you expressed your intention. I will try to help out 1 1 2redrovers and deankxf reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted April 25, 2023 The problem is now it doesnt seem to be draggin up the fuel, im thinking the module in the fuel tank might be busted or perhaps a fuse/electrical part might not be working? Do these have a controller on them?Only thing electric in the tank is the fuel gauge sensor, rest of the fuel system is purely mechanical on a carby xflow (unless the car was put on LPG at one point in its life then there will be a lock off solenoid in the fuel line somewhere), there is a mesh screen on the end of the fuel sender in the tank that could have rotted off or collapsed and keeps blocking the fuel sender, your best bet would be to pull the fuel sender out and inspect it 2 deankxf and Nato of Falcons reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 25, 2023 Ill take it out and take a good look at it, thanks for letting me know, I was super worried the wiring was busted or perhaps a component was busted. Time to get a little dirty and look at it while the battery is still charging back in the house! Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 26, 2023 So I had to hook the bottle back up and it had to feed down toward the engine, the fuel pump cant suck up enough if I sit the bottle underneath it. Im thinking its the fuel pump hey? I have to fix up a coolant line because it busted itself while I was testing. Share this post Link to post Share on other sites
deankxf 20,347 Posted April 26, 2023 26 minutes ago, Nato of Falcons said: So I had to hook the bottle back up and it had to feed down toward the engine, the fuel pump cant suck up enough if I sit the bottle underneath it. Im thinking its the fuel pump hey? I have to fix up a coolant line because it busted itself while I was testing. better the coolant issue now than cooking an engine later. this is why i recommend changing all hoses on a "barn find" the cast alloy fittings in the manifold can go crusty is this what broke? i bypassed the manifold coolant flow on one of my cars for this reason, but also another car due to a welsh plug rusted out on the back side of one. sounds like the pump is weak, it could be full of crud. i'd be inclined to run the engine wherever the bottle works for a bit and see if fresh fuel cleans up that issue. 1 omgwizards reacted to this Share this post Link to post Share on other sites
Nato of Falcons 23 Posted April 26, 2023 Huston... we have a problem... At this rate all the bolt ons and the radiator & Fuel pump are going to have to be scratched and new ones done. I like learning and experiencing this engine but damn ive opened up a can of worms on this one fella's. 1 omgwizards reacted to this Share this post Link to post Share on other sites
