wok 205 Posted May 25, 2021 Gday, just wondering if an XG ute canopy will fit XH ? im assuming the plastic trim around the XH rear window may foul ?? and if the XG one wont fit, anyone got a white XH canopy in good condition without roof rack holes ? cheers Warren 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted May 25, 2021 Should fit no worries Wok.XG and XH have the same rear section. Its pretty much E series from the front of the doors forward on an XH.XF, XG and XH all share a common design in the rear section.p Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
wok 205 Posted May 25, 2021 ThanksGot sent this from a mate I askedThis seller says roofs are different and won't fithttps://www.ebay.com.au/itm/Canopy-to-suit-Ford-XD-XE-XF-XG-Falcon-ute-/293869151574?_trksid=p2349624.m46890.l49286Sent from my Pixel 4a using Tapatalk 1 Fingers reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 25, 2021 ThanksGot sent this from a mate I askedThis seller says roofs are different and won't fithttps://www.ebay.com.au/itm/Canopy-to-suit-Ford-XD-XE-XF-XG-Falcon-ute-/293869151574?_trksid=p2349624.m46890.l49286Sent from my Pixel 4a using TapatalkXD/XE/XF/XG have a very square trim around the rear window.XH has a very rounded trim, I reckon that's the difference.This is the XH trimhttps://www.ebay.com.au/itm/233767221482 1 Fingers reacted to this Share this post Link to post Share on other sites
wok 205 Posted May 25, 2021 I wonder if I remove that trim if the XG canopy might fit ?Sent from my Pixel 4a using Tapatalk Share this post Link to post Share on other sites
Outback Jack 6,352 Posted May 27, 2021 That shouldn't make any difference, there's a rubber sealing strip across the front and the canopy sits on top not butts up to the rear of trim. Should be fine.Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
wok 205 Posted May 27, 2021 45 minutes ago, Outback Jack said: That shouldn't make any difference, there's a rubber sealing strip across the front and the canopy sits on top not butts up to the rear of trim. Should be fine. Sent from my S21 using Tapatalk ahhh ok, perfect, now i cant go buy it due to damn lockdown.... 1 Outback Jack reacted to this Share this post Link to post Share on other sites
wok 205 Posted May 27, 2021 one more question how does it affix to the top of the tub ? / can i still use the XH tub liner ? Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted May 27, 2021 XH utes got given a domed roof, to increase vehicle head-room inside the cab. I believe there is a difference. 2 Outback Jack and Fingers reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted May 29, 2021 XH utes got given a domed roof, to increase vehicle head-room inside the cab. I believe there is a difference.Maybe I stand corrected.....Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
Demmo 295 Posted March 6, 2023 a wok. did you get the xg canopy and does it fit the xh ok if so what brand of canopy is it an could you throw up a couple of pics showing acrooss top of car roof please thanks demmo Share this post Link to post Share on other sites
