CHESTNUTXE 7,354 Posted August 20, 2018 so i guess i should chuck em ? might be good 4 a makeshift engine start up stand. Share this post Link to post Share on other sites
SPArKy_Dave 8,895 Posted August 20, 2018 13 hours ago, Thom said: this stock headers flow worse than cast iron manifolds 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 21, 2018 Hey can anyone tell me why 5.0L rings are double the price of normal 302w rings ? Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted August 21, 2018 Hey can anyone tell me why 5.0L rings are double the price of normal 302w rings ?Sent from my SM-G570Y using TapatalkMoly-faced? Thinner? Low-drag? Dunno.... Interested myself. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 21, 2018 Says oddball metric size $150 just wondering will normal older 302w rings work Share this post Link to post Share on other sites
Thom 6,654 Posted August 21, 2018 Says oddball metric size $150 just wondering will normal older 302w rings workNo not without older style pistons, also you have to use a svo timing set in these engines 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 21, 2018 What about the std chain it comes with like the morse style single replacement Share this post Link to post Share on other sites
Thom 6,654 Posted August 22, 2018 What about the std chain it comes with like the morse style single replacement I've never seen them, but also I've never looked 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 22, 2018 does the alloy timing cover have anything to do with what chain you use ,eg,early cover fits double roller chain ? or doesnt really matter. Share this post Link to post Share on other sites
Thom 6,654 Posted August 22, 2018 does the alloy timing cover have anything to do with what chain you use ,eg,early cover fits double roller chain ? or doesnt really matter.It doesn't really matter I've been lead to believe 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 24, 2018 hey i have heard that you can put new roller lifters on an old cam ,because they are not turning is this correct ? Share this post Link to post Share on other sites
Thom 6,654 Posted August 25, 2018 hey i have heard that you can put new roller lifters on an old cam ,because they are not turning is this correct ?You can provided the cam has no scoring pitting or any of the hardness flaking off, same goes for the lifters, they can even be used with aftermarket cams (providing they are still in serviceable condition), while the factory cam is ok in the roller engines there a many better/ more modern grinds available 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 thom can you use link bar roller lifters instead of using the dog bone and spider or its no benifit ? Share this post Link to post Share on other sites
Thom 6,654 Posted August 25, 2018 thom can you use link bar roller lifters instead of using the dog bone and spider or its no benifit ? No real need the spider setup is pretty decent and quieter than the link bars, the link bars were mainly developed as a way retrofit roller cams into non roller engines Share this post Link to post Share on other sites
gerg 10,871 Posted August 25, 2018 You can provided the cam has no scoring pitting or any of the hardness flaking off, same goes for the lifters, they can even be used with aftermarket cams (providing they are still in serviceable condition), while the factory cam is ok in the roller engines there a many better/ more modern grinds available I've read that the E303 motorsport cam is a popular, all-round, ECU-friendly unit. Slight lope at idle, 220@ 0.050", 110 lobe sep. Probably not far off what you have in your crossy Chestnut. Sent from my CPH1607 using Tapatalk 3 Thom, CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 I've read that the E303 motorsport cam is a popular, all-round, ECU-friendly unit. Slight lope at idle, 220@ 0.050", 110 lobe sep. Probably not far off what you have in your crossy Chestnut. Sent from my CPH1607 using TapatalkYes i looked at that thismoring,i got the pump off i had to just grind one bolt thru now just the timing housing remains it looks factory i will try not to kill itSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 heads are off ,rollers out,worlds smallest pushrods,just think these are the std heads,bore looks good no lip. Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 25, 2018 What are the casting numbers on the heads? It’ll be underneath the rockercover in amongst the rockers 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 What are the casting numbers on the heads? It’ll be underneath the rockercover in amongst the rockersOk i will look it only has this on the crank bearing size is factorySent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 Ok i will look it only has this on the crank bearing size is factorySent from my SM-G570Y using TapatalkHead numbers ,double chain,roller camSent from my SM-G570Y using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 Head numbers ,double chain,roller camSent from my SM-G570Y using TapatalkLooks like std bore pistons but how do you tell if its the forged ones ? Sent from my SM-G570Y using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 im no expert but i would say these have had fair ware on them but maybe still usable ? the dog bones look all good. Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 25, 2018 im no expert but i would say these have had fair ware on them but maybe still usable ? the dog bones look all good.That lifter looks like it has some nasty scoring at the top. It’s hard so see but that lower part above the roller could be overheated?? What do the lifter bores look like? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted August 25, 2018 The pic of the head casting shows "CF", or Cleveland Foundry. It's a clevo Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted August 25, 2018 im frightend by the price of roller cams for a 302w ,in the states the price is not to bad but here OMG. Share this post Link to post Share on other sites
