bear351c 10,273 Posted July 12, 2021 OK, Clevo fans...... Question : Mates 351 2V Top Loader XA. Won't idle below 1500-1700 rpm. Initially, the fuel was causing rough running, (rust in tank) so we pulled the tank, replaced the rubber lines, new fuel pump, new fuel filter. Blew all the hard lines backwards. Changed carby 3 times. (2 Holleys and a TQ.) Changed dissy, then New distributor. New leads. New plugs. New coil. She fires up fairly easily, revs sweet and hard above 1500, but wont run below this. Coughs and backfires. Checked for vacuum leaks quickly (carb cleaner while running), all ports on carby blocked or connected. Chased a few wires that looked dodgy, changed out alternator, new earth lead.......... Thoughts, Ideas...?? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 12, 2021 OK, Clevo fans...... Question : Mates 351 2V Top Loader XA. Won't idle below 1500-1700 rpm. Initially, the fuel was causing rough running, (rust in tank) so we pulled the tank, replaced the rubber lines, new fuel pump, new fuel filter. Blew all the hard lines backwards. Changed carby 3 times. (2 Holleys and a TQ.) Changed dissy, then New distributor. New leads. New plugs. New coil. She fires up fairly easily, revs sweet and hard above 1500, but wont run below this. Coughs and backfires. Checked for vacuum leaks quickly (carb cleaner while running), all ports on carby blocked or connected. Chased a few wires that looked dodgy, changed out alternator, new earth lead.......... Thoughts, Ideas...?? Firing order ?Sent from my SM-G610Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 12, 2021 My mate's XB coupe had similar issues and I think I've described them before on here, and after pretty much doing everything you did (throwing parts like grenades at it), turned out to be the supply to the electronic dizzy coming from the old points 9v resistor wire. Went direct from the battery and vroom! Started first kick.Sent from my CPH1920 using Tapatalk 2 bear351c and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 12, 2021 1 hour ago, CHESTNUTXE said: Firing order ? Checked it 5 times. Pulled No.1 plug and made sure we had compression stroke, made sure balancer hadn't slipped. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 12, 2021 19 minutes ago, gerg said: My mate's XB coupe had similar issues and I think I've described them before on here, and after pretty much doing everything you did (throwing parts like grenades at it), turned out to be the supply to the electronic dizzy coming from the old points 9v resistor wire. Went direct from the battery and vroom! Started first kick. Pretty sure we've rigged up a jumper wire already, thinking the rodents had got in. She starts OK, runs sweet with revs, but won't idle. Sat there with the carb idle screwed in for 10 minutes, ran like a top. Kitted out the 600 Holley vac sec, so acc pump works, butterflies are closing/opening when they should, sealant on adaptor plate. etc, etc... Doing my head in...... Maybe electrical.? Would have thought it would cough under heavy load, but seems the opposite. 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 12, 2021 The exhaust crossover hasn't rusted through? Brake booster failed? Is there fuel dripping out the boosters?If it only idles above 1700, the throttle will be open so far that the idle screws will do nothing anyway, seeing as that circuit won't be working at that amount of opening.Is the EGR connected? Is the passage blocked off?I dunno, just clutching at straws here mateSent from my CPH1920 using Tapatalk 2 CHESTNUTXE and bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 12, 2021 Yeah me too.!! The brain bucket is nearly dry.......... Nothing dripping as far as I can see, but revving it to 1500 rpm, and sticking your face over the carb is highly dangerous, if the rvs drop she backfires and fuel/air/smoke come spewing out. I already go no hair, but, like my eyebrows. LMAO. Hadn't thought of the exhaust crossover.......hmmmm.. Told my mate we would prob pull the manifold/valve covers off next time. just to reseal them. She doesn't get driven very often, so sits for months at a time. Not a new engine, been in there 15 years, cast iron manifold. 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 12, 2021 Yeah me too.!! The brain bucket is nearly dry.......... Nothing dripping as far as I can see, but revving it to 1500 rpm, and sticking your face over the carb is highly dangerous, if the rvs drop she backfires and fuel/air/smoke come spewing out. I already go no hair, but, like my eyebrows. LMAO. Hadn't thought of the exhaust crossover.......hmmmm.. Told my mate we would prob pull the manifold/valve covers off next time. just to reseal them. She doesn't get driven very often, so sits for months at a time. Not a new engine, been in there 15 years, cast iron manifold.Bear you need my reco 2vs lolSent from my SM-G610Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 13, 2021 Bear you need my reco 2vs lolSent from my SM-G610Y using TapatalkI bought a drill and small bench grinder ,made life a lot easyer clening up the valves,also the machine shops are charging $90 per head to clean them up ? I thought that was a bit steep what do you reckon Sent from my SM-G610Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,316 Posted July 13, 2021 for $90 a head, what are they doing? just hot tanking? i'd be more concerned with the valve seats, guides and the valve condition Myself.. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 13, 2021 for $90 a head, what are they doing? just hot tanking? i'd be more concerned with the valve seats, guides and the valve condition Myself.. Nah just per head mill $90 tanking is $50 a pairSent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,316 Posted July 13, 2021 5 minutes ago, CHESTNUTXE said: Nah just per head mill $90 tanking is $50 a pair Sent from my SM-G610Y using Tapatalk surface grind? not able to do that with a bench grinder(can do it on a sheet of glass or a big stone for LOTS of work?) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 13, 2021 hmmmm,i might give it a go ,2 x sheets of 100 grit,but what about to finish ,i think a saw 400 Share this post Link to post Share on other sites
gerg 10,871 Posted July 13, 2021 Nah just per head mill $90 tanking is $50 a pairSent from my SM-G610Y using TapatalkHead mill is fair enough. There's quite a bit of setup work involved, especially if the valve hardware gets in the way of the spacers, getting the head sitting square to the table, the labour needed to do the cut itself (most shops are over $100 an hour just for that), plus wear and tear on machinery, overheads, rent, it's a tough gig doing your own business.If it's just a plain surface grind, that should be a lot cheaper. They just pass the head over a rotating wheel to basically put a new surface on it, but that really won't correct any warpage it might have.Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 13, 2021 ahh i see ,it just sounded way to much to me,i can understand $90 for both. Share this post Link to post Share on other sites
deankxf 20,316 Posted July 13, 2021 1 hour ago, CHESTNUTXE said: hmmmm,i might give it a go ,2 x sheets of 100 grit,but what about to finish ,i think a saw 400 said 120 then 240 from what i saw. on a thick sheet of perspex(that's probably where the $50 went?) i guess it would depend what you are building but if i was spending thousands on a GOOD engine, $180(2 heads) to be done right is a drop in the ocean. are they also doing the intake and exhaust surfaces for that? if so, even more bargain. i reckon you'd get sick of pushing a head back and forth pretty soon. i'd more likely do it just to see IF it's got uneven patches.. if not i'd possibly use it just clean, otherwise i'd be getting it machined 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 13, 2021 said 120 then 240 from what i saw. on a thick sheet of perspex(that's probably where the $50 went?) i guess it would depend what you are building but if i was spending thousands on a GOOD engine, $180(2 heads) to be done right is a drop in the ocean. are they also doing the intake and exhaust surfaces for that? if so, even more bargain. i reckon you'd get sick of pushing a head back and forth pretty soon. i'd more likely do it just to see IF it's got uneven patches.. if not i'd possibly use it just clean, otherwise i'd be getting it machinedI never get sick of pushing my head backwards and forwardsSent from my SM-G610Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,316 Posted July 13, 2021 3 hours ago, CHESTNUTXE said: I never get sick of pushing my head backwards and forwards Sent from my SM-G610Y using Tapatalk i got sick of banging my head against the wall at most jobs i worked at 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 15, 2021 i got sick of banging my head against the wall at most jobs i worked at1 of the 82 black heads is back and olm8 said its ok but the other 1 needs 2 k line guides and 2 seats as he is doing this later and pick up tomorrow but im stoked with condition out of the tank even surfaces look goodSent from my SM-G610Y using Tapatalk 1 1 deankxf and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 15, 2021 i orderd a set of 400 mounts today that suit xa to xg $280 and bolt to our v8 chassis plates,castlemain rod shop do em,and he was surprised how many sets they have sold,its gunna take 2 weeks cause he is out of stock,sure beats mucking around with spacers and crap,i will post a pic as soon as i get em.outback jack would like the fact that they fit a xg 2 FORD_MAN and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 16, 2021 i orderd a set of 400 mounts today that suit xa to xg $280 and bolt to our v8 chassis plates,castlemain rod shop do em,and he was surprised how many sets they have sold,its gunna take 2 weeks cause he is out of stock,sure beats mucking around with spacers and crap,i will post a pic as soon as i get em.outback jack would like the fact that they fit a xgOk i cleaned up even more just one head and now get it ready for some ford dark blue then go and grab my other head that has been fixedSent from my SM-G610Y using Tapatalk 1 1 gerg and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted July 16, 2021 Ok i cleaned up even more just one head and now get it ready for some ford dark blue then go and grab my other head that has been fixedSent from my SM-G610Y using TapatalkThe clevo heads are painted i also found a new smoke called cleveland Sent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,316 Posted July 16, 2021 cleveland's are bad for your health going by that picture.. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 16, 2021 cleveland's are bad for your health going by that picture.. No I think it's actually the other way around... Having a clevo takes you from being on your your death bed to happy face, healthy mullet and 'stacheSent from my CPH1920 using Tapatalk 1 1 CHESTNUTXE and bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 17, 2021 I actually look like the guy in the "after" photo, but 50 kgs heavier. Frikkin nightshift............ 1 1 deankxf and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
