gerg 10,871 Posted February 27, 2020 I have seen 1 nigari in sydney a long time ago red with 4v engineSent from my SM-G570Y using TapatalkMight be this guy's. Or he might have owned it at some stage, definitely would know the owner regardless. He's into them. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 27, 2020 Might be this guy's. Or he might have owned it at some stage, definitely would know the owner regardless. He's into them. Sent from my CPH1903 using TapatalkThis was 23 years ago in the croydon area he was a mechanic Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 27, 2020 This was 23 years ago in the croydon area he was a mechanic Sent from my SM-G570Y using TapatalkAnother bowel i have seen was at my school freinds house in 1981 it was blue and sported a holden 202Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 27, 2020 Another bowel i have seen was at my school freinds house in 1981 it was blue and sported a holden 202Sent from my SM-G570Y using TapatalkA 202 in someone's bowel Seriously though, that would be a Bolwell Mk 7, a kit car that looked very similar to the Nigari (I like them more actually) and most had Holden 6s. Some may have had Windsors or Ford 6s. The Nigari was their first turn-key, factory built car you could buy off them complete, with Ford 302C or 351C running gear.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 27, 2020 A 202 in someone's bowel Seriously though, that would be a Bolwell Mk 7, a kit car that looked very similar to the Nigari (I like them more actually) and most had Holden 6s. Some may have had Windsors or Ford 6s. The Nigari was their first turn-key, factory built car you could buy off them complete, with Ford 302C or 351C running gear.Sent from my CPH1903 using TapatalkTrue story i nearly wrecked the car we were clowning around in their garage and i thought the roof was steel and i jumped up on it and it folded down the fucker was fiberglass and left me nearly buying them a another i had no idea it was fiberglass Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 27, 2020 True story i nearly wrecked the car we were clowning around in their garage and i thought the roof was steel and i jumped up on it and it folded down the fucker was fiberglass and left me nearly buying them a another i had no idea it was fiberglass Sent from my SM-G570Y using TapatalkFucking dumb stuff we used to do as kids... I used to walk across the roof of the coupe when I was a kidSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 28, 2020 Fucking dumb stuff we used to do as kids... I used to walk across the roof of the coupe when I was a kidSent from my CPH1903 using TapatalkFukn hell this thing is coming together quicker than i can last in bed i also used and reco the 77 water pump will fit after lunch i showed the machine shop the bearings and he reckons they are fine date on them were 2006 so i will sell just as a good runner but new if ya no what i meanSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 28, 2020 Did you need to clean up that crank? Looks a bit average in that shot. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 28, 2020 Did you need to clean up that crank? Looks a bit average in that shot. Sent from my CPH1903 using TapatalkBelieve it or not the crank is better than the one i picked up after it was linished,been at it since sun up now sun down doin heads now but no pistons or rodsSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 28, 2020 Believe it or not the crank is better than the one i picked up after it was linished,been at it since sun up now sun down doin heads now but no pistons or rodsSent from my SM-G570Y using TapatalkThat will do today not much else i can do until tomorrow Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 28, 2020 Looking fresh mate, would be great to see this runningSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 28, 2020 Looking fresh mate, would be great to see this runningSent from my CPH1903 using TapatalkI picked up the pistons and they are std but 1 is broken you can see the dish is a bit smaller on my ones compard to the bigger dishSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 29, 2020 What are the differences in pin height? The rings on yours seem to sit lower on the margin from the top ring to the face is thicker on yours, possibly pointing to a taller deck height compared to the other ones you pulled out. If you stand them up on the rod end, you can compare compression heights roughly  Sent from my CPH1903 using Tapatalk    1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 29, 2020 What are the differences in pin height? The rings on yours seem to sit lower on the margin from the top ring to the face is thicker on yours, possibly pointing to a taller deck height compared to the other ones you pulled out. If you stand them up on the rod end, you can compare compression heights roughly  Sent from my CPH1903 using Tapatalk    Looks identical to meSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 29, 2020 Looks identical to meSent from my SM-G570Y using TapatalkGerg yur right about a service or warranty engine some of the rods have been re stamped,also need 010 big ends and std rings coming along ok pistons clean and does anyone have a clevo dizzy gear for the std dizzy ?Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 29, 2020 Looks identical to meSent from my SM-G570Y using TapatalkSorry my bad, looked different to me in the first photoSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted February 29, 2020 there is a slight difference in piston bowl depth,im just gunna put 1 of my other pistons on the rod to replace the broken one,probly only about a few cc ,slight difference between 1971 and 72/3,just goes to show that red devil 400 is rare with 8cc dish and 9.2.1,this motor would be 8.5.1 approx circa first unleaded i reckon. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 29, 2020 I can't remember if Ford played with dish size or piston height or both to get the lower compression in the smog motors. Sad times... So much potential for that motor but it never had its chance to shine in factory form Sent from my CPH1903 using Tapatalk 2 Thom and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted March 1, 2020 17 hours ago, gerg said: So much potential for that motor but it never had its chance to shine in factory form  As was the case with most of the Ford engines............ 3 CHESTNUTXE, gerg and Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted March 1, 2020 i ordered new rings,rod bearings,rocker covers,and stock 24kg 2v intake almost ready for paint. 1 Boingk reacted to this Share this post Link to post Share on other sites
Boingk 865 Posted March 1, 2020 Wait, which intake are you using, the Weiand job or the stocker? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted March 1, 2020 this is another 400 i got and cheap rebuild for sale soon 1 Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted March 1, 2020 this is another 400 i got and cheap rebuild for sale soonStarting to take shapeSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted March 1, 2020 Interesting that they don't have that big gaping hole hacked out at the front of the valley (above the dizzy drive) like a clevo does. It seems to rely on the oil drain back holes in the valley itself.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,319 Posted March 1, 2020 nah it has it,im sure Share this post Link to post Share on other sites
