CHESTNUTXE 7,331 Posted October 3, 2017 Does any one know if the later e series and xh door lock buttons can be converted onto a xf lock system,i had a look at the wreckers today and it seems a bit difficult,but maybe someone has done it,the snibber buttons have a red rod that goes down into the door ??? here is a picture of my dummy fit of an xh square lock button trim ,thats going onto a xf door. Share this post Link to post Share on other sites
Defective 1,692 Posted October 3, 2017 I'm running xh trims in my xf, and tried for about 3 minutes to marry the two different systems up and gave up. I now have round door lock pins in a square hole lol 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted October 3, 2017 yeah if worst comes to it i will do the same,or glue the sqaure button on the old rod and then see if that works Share this post Link to post Share on other sites
deankxf 20,313 Posted October 4, 2017 central locking will be needed to unlock the door again.. need an unlock button on the dash.. this MIGHT do the trick? i cant brain it right now.. http://www.ebay.com/itm/Polarity-Reverse-DC-Motor-Control-Rocker-Switch-30-Amp-12V-DPDT-Momentary-/231403233561 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted October 4, 2017 Thats getting a bit tricky,i will just leave the std buttons i think that poke thru the square,i might try to thicken them up a bit so at least it looks the part,or use the square buttons and manipulate them onto the std rod,(might work) Share this post Link to post Share on other sites
jca25 1,034 Posted October 4, 2017 Keep trying u can make anything work with time i run ef inner door handles on a xd Sent from my SM-G950F using Tapatalk 3 Valvebouncer, dex and deankxf reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted October 5, 2017 I know the locks in the XG are a pain in the fucking arse....that is all. Share this post Link to post Share on other sites
Defective 1,692 Posted October 5, 2017 I can't remember why but I couldn't even leave the Square recess thingy in the trim on mine, had to remove it completely. They didn't survive being removed lol. Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted October 5, 2017 Curse of the xh Share this post Link to post Share on other sites
Stuart Vigilante Campbell 0 Posted August 15, 2022 On 10/4/2017 at 8:01 PM, jca25 said: Keep trying u can make anything work with time i run ef inner door handles on a xd Sent from my SM-G950F using Tapatalk Messaged you about this man! Check email Share this post Link to post Share on other sites
