gerg 10,871 Posted October 23, 2016 I just made the (possibly wrong) assumption that they changed over along with the introduction of the crossflow in 76, to meet ADR 27a when the XC came out. This included stuff like retarded cams, lower compression, EGR valves, etc that weren't present on the blue motors. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 23, 2016 I have only ever seen 1 xc fairmont coupe 5.8 auto 1978 model with a black engine,i dont no if it was reco or factory but it looked very factory. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 24, 2016 The manifold turned out to be the rare 2 barrel one that is cone shaped ,pretty sure this one came on the 1974-75 351 cleveland,ford was looking for some better fuel consumption. 2 deankxf and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 24, 2016 The block de-codes to 13th june 1977 cast 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 24, 2016 After cleaning the timing cover i could see someone butcherd it where it meets the oil pan,for first timers that take the cover off it just unbolts and a few wacks she comes off,but you are supposed to undo the sump about 1/4 inch so it will come out easy,i no this cause i fooked mine the first time i changed cam and couldnt get it back on ,so i will go the wreckers tomorrow and grab a good one. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 24, 2016 Tomorrow i will drop the block, sump,rocker covers,manifold off to the machine shop to clean them right up b4 painting,also expecting rings and bearings to show up. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 25, 2016 I took apart the heads and apart from the soot inside looks good,seats look ok,but will need new stem seals these ones are hard as a rock. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 25, 2016 More stuff to get hot tanked,also the rods were 020 and mains 010,all coming along at full steam. 1 bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 25, 2016 Maybe you could get a price on bronze guides and press-on seals. If I had my time over, I'd have saved up a bit more and done that instead of keeping with the shitty umbrella seals. The engine started leaking oil through the guides at less than 30,000k. The local cylinder head guy reckons it's modern fuels that do it. Causes the seal to crack in no time. 2 bear351c and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 25, 2016 yeah those teflon seals are good as well,i have a felpro set of normal seals they will be fine in this application,im also thinking of putting these heads on my 351 engine,i have done the math's on the compression calcuator and comes in at 10.64.1 thats if i leave the chambers at 58 odd cc. Share this post Link to post Share on other sites
bear351c 10,273 Posted October 26, 2016 Yeah, agree with Gerg, those umbrella seals are shite. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 I found an original factory replacement chain (lol) the old timing gear was in such good condition ,just the chain had a small amount of play so instead of paying $140 for a double roller i got this one for $14 yee haa. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 new old stock Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 Got a fair bit done today ,cleaned 4 pistons ,4 valves,re-co the water pump (looks better than new),cleaning those ring grooves is the most time consuming thing to do . Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 You saw how much caked on soot was stuck on these valves,spent about 1hour just on these 4 but well worth the time doing it.They are the std 2.05 intake and 1.65 exhaust. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 Also old fuel pump came up nice,water pump was cleaned-painted silver then 2 coats of clear,looks fine to me. 2 gerg and bear351c reacted to this Share this post Link to post Share on other sites
Free.51 2,727 Posted October 27, 2016 Like like like Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 27, 2016 This motor is gunna be gangsta from what it was,i will be selling it when its finished in a few weeks,it wont be expensive if you need a nice engine to replace your old 302. 1 Free.51 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 28, 2016 i got the parts back from the wash tank,i have wd 40 the things that are not ready yet,and will paint the rocker covers tomorrow and the block. 1 deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 28, 2016 Nothing like a rebuild in a can Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 28, 2016 Here is a picture of the last 302 i built ,a 1972 xa fairmont engine. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 28, 2016 Painted the covers and clear coated them. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 29, 2016 Spent most of the day cleaning the dizzy came up ok,single point bosch,i also replaced the rubber seal around the housing. Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 29, 2016 Old mate came up from sydney today and popped in to pick up a flywheel and he spotted the ford 4643-3 2 barrel 375 cfm holley that came on the engine,since he no's his stuff he offerd to re-co it for free if he can have the throttle shaft as it was a rare one he said,so when it comes back it will be perfect and clean ready for running. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,335 Posted October 30, 2016 starting to get in order of assembly 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
