CHESTNUTXE 7,312 Posted May 22, 2016 First undo everything and take cluster out. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 22, 2016 Then take the speedo out so that you can get to the tiny adjustment slot. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 22, 2016 I made the fatal mistake of trying to adjust the slot while keeping the speedo in and broke mine.Just to the right you can see the small silver adjusting slot for the rpm's.Plug your cluster back in and calibrate with a tiny screwdriver . Share this post Link to post Share on other sites
Jestr75 41 Posted May 22, 2016 Photo is a little blurry, but good job, I always thought it was a resistor that had to be changed to convert from a 6 cyl to v8 tacho?? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 22, 2016 gerg say's hold your rev's at 2000 then turn the slot down to 1500 and that should be about right,but if you have a good multi meter then get someone to call out the rpms and adjust to be more precise . 1 Jestr75 reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted May 22, 2016 Cheers, That's handy to know Share this post Link to post Share on other sites
scottly 475 Posted May 23, 2016 Cool thread mate, first one on this topic with detailed pics. I have Been told it is still not 100% accurate this way but it is very close I think there needs to be some thing else changed maybe resister as mentioned as above. I will still be using this method tho Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 23, 2016 ok i am using my old resister off the crossy,i thought that was just for bad radio interferance,???? Please any more info please add because mine is still all out and waiting to re asemble. Share this post Link to post Share on other sites
VDO 124 Posted May 23, 2016 There is no resistor to change. It's a calibration done by adjusting the small trim pot as shown in the pic above. To do it correctly and accurately, it should be done using a sine wave generator, with 12V square wave. If you're in Brisbane, I can do it for you, no charge. Send me a PM. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 23, 2016 ok sounds good m8,also i have read so many times in diff forums that your speedo can be adjusted the same way if your still out after changing the plastic tooth drive,well im still looking for it on the speedo ? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 23, 2016 ok i wonder will it work mine is 19km over,tomorrow i will put the rear end up on stands and adjust the speedo . Share this post Link to post Share on other sites
VDO 124 Posted May 23, 2016 The trim pot in the speedo is only for very fine calibration, not for correcting an error of 19 Kph. If you try that, then the odometer will register incorrectly. You need to fit the correct gear on the transducer on the gearbox. How many teeth does your current gear have..? You say you are 19 Kph over, then you will need to get a gear that has 4 more teeth than your current one, and you will be a lot closer to correctness then. For example, if your current gear is 15 tooth, then you will need a 19 tooth gear. Ford parts still carry them. 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 23, 2016 ok cheer's i have a 20 tooth in the fmx that i imagine had a 2.75 ratio and i am running 3.27 ,the same thing happend when i had the b/w 35 in there i upgraded the gears from 2.77 to 3.27 and used a green 21 tooth but it was still about 10km out so i suppose im looking for a 23 and then use the trim pot,i cannot find a tooth for a fmx bigger than 21 on e bay so ? Share this post Link to post Share on other sites
SLO247 1,713 Posted May 23, 2016 If theres no suitable tooth available you could use a speedo corrector? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 24, 2016 i think c4 and fmx are the same i will do some more searching ,i might have read somewhere that TCI do a 26 or 24 tooth for short gearing. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 24, 2016 Look at this just coincidence 351 ? on the VDO cluster ? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 24, 2016 Latest option (lol) Share this post Link to post Share on other sites
NZXD 2,328 Posted May 24, 2016 i think c4 and fmx are the same i will do some more searching ,i might have read somewhere that TCI do a 26 or 24 tooth for short gearing. I have 3:45 diff gears and a 1:1 top gear ratio in the gearbox, same as C4/FMX, I run the grey 22 or 23 (out of a AU XR6), and my speedo is bang on at 50 and is 3km/h out at true 100. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 24, 2016 ok but the b/w teeth go in the opoisite way ,i found this out in my bw-35 unless the au tranny tooth is on the passenger side ? I had a look ,the au is a left hand tooth so i dont no how long its going to hold up in your box but if it works ,well done,the fmx box have right hand teeth and an extended nose ,where others are shorter. Share this post Link to post Share on other sites
scottly 475 Posted May 24, 2016 Hey mate are you going to plastic polish your clear Perspex whilst the cluster is apart? This is some thing I have been thinking about as I have one I am currently bringing back to life. Maybe vdo could shed some light on how to do this he seems be the man with this gear Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 24, 2016 While its out why not if it needs it,but I'm leaving mine because it scratches so easy and finding another ghia perspex is hard. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted June 3, 2016 ok i got another taco bell off another member (thanx m8) here is a picture of the adjuster slot i will try not to break it this time ! Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted June 4, 2016 ok its all working exactly as gerg said just de-tune it 500rpm and it will be pretty close to true. 1 SLO247 reacted to this Share this post Link to post Share on other sites
