Mustardxf 29 Posted September 11, 2015 Hey guys,Wanting everyones options on whats a good strong, reliable clutch for a beefy crossflow with a t5? 3.45 diff gearing. Share this post Link to post Share on other sites
slydog 7,873 Posted September 11, 2015 Xr6 6 bolt unit. Share this post Link to post Share on other sites
Xelisty 366 Posted September 11, 2015 I just got a etreme heavy duty so called rated to 400hp plus. It feels good under foot. I'm Heading to the drags tomorrow so I will let you know. Has a good take up without too on/off feel. I ended up going a machined flywheel instead of new or newer model Flywheel. It's a t5 and crossflow turbo 310rwhp at 16 pound boost and 2.92 gear 2 XTREME KARTS XF and slydog reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted September 11, 2015 ATM i'm using an Exedy sports organic and it's been good. 220rwhp and 3.23 gears. Been to drags and a few trips to wakefield park. Using Nitto invo 245's on the back. a few sneaky burnouts with 245's also. Has not skipped a beat since i got the issues with the hydraulic throw out sorted a couple years ago. If your making more power then you'll probably need something more substantial? Sly's right the 6'bolt presure plates put down more clamping force so they are the way to go if your running big power. You will most likely have to drill and tap 3 more holes into the flywheel to suit if you go that way. Something to consider is using a less aggressive clutch will be easier on the gearbox so i would not be going to a fully hectic clutch unless you need to. 2 slydog and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted September 11, 2015 A nice sprung 5 puck organic will be fine for your engine this is a more street race clutch and a very positive take up but will last a long time, I feel a 6 bolt pressure plate is a must so you don't pull the pressure plate off 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 12, 2015 I got my stock EA flywheel lightened, machined, drilled & tapped for 6-bolt h/duty exedy and it worked great. I think 6-bolt ones came in utes, not 100% though. Now with a decent clutch your T5 is the next fuse in the circuit.... Or the axles (with those 3.45 gears) Share this post Link to post Share on other sites
PRO250 1,506 Posted September 12, 2015 If breakage keep occurring revise driving style better yet auto Share this post Link to post Share on other sites
Mustardxf 29 Posted September 14, 2015 ordered a RPM CI level 3, 5 puck ceramic button clutch. $363 Share this post Link to post Share on other sites
