SXE357 91 Posted July 9, 2015 Hi Guys, Now I have the heater hoses sorted, I have to fix the last big problem I have with putting a ZL Fairlane Interior into an XE with a 351.Before the engine went in, it looked so easy to bolt the air con compressor to the lower left hand side of the 351. All looked great, fitted well. But when I dropped the 351 into the engine bay I found the compressor to be hitting part of the engine bay. I was wondering if there would be any problems I remove the section that the compressor is hitting?Or if anyone else has a better setup they would like to share? I don't want to use the original 351 compressor. Cheers Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 9, 2015 Subscribing because I want to know how you get on as I would love to have A/C in my XF when I Clevo it. And don't want to mount the A/C where it is from factory on Clevos. Share this post Link to post Share on other sites
bear351c 10,271 Posted July 9, 2015 Is that the shortest vee belt, you could fit.? How much would you have to cut the steelwork, to get it to fit.? Share this post Link to post Share on other sites
SXE357 91 Posted July 9, 2015 Yeah Im going to have to rethink this, as is I wouldn't have to remove too much at all, only a small triangular piece just above the bolts, but this is no good, as seeing Im going to have to move the engine forward about an inch, the compressor will be too far forward.Got a bit smart for myself, back to the drawing board. Share this post Link to post Share on other sites
revhead 1,392 Posted July 9, 2015 why not put the compressor up on the left side where it belongs another problem you cant cut a little off as the motor lifts from the left to the right ,and youl find the compressor smashing into the sway bar mount all the time , 1 SXE357 reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 9, 2015 why not put the compressor up on the left side where it belongs Because they look like absolute shit sitting on top of the motor? One thing I hate about Clevos is when they have a A/C fitted, pop the bonnet to look at a nice old V8 and BAM! massive ugly compressor in your face. 1 SXE357 reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted July 9, 2015 Can't help you with the a/c but damn that's a nice looking donk. Giggity. 2 SXE357 and Outback Jack reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 9, 2015 Change the compressor to an ef el type - more compact, but you need to go serpentine belt. Ir try a commodore sanden 507 unit. Little more compact with the ports on the top of the unit. 1 SXE357 reacted to this Share this post Link to post Share on other sites
SXE357 91 Posted July 9, 2015 Yeah as I said earlier, as Im moving the engine forward as suggested by Revhead, Im going to have to find another solution with the Air con Compressor, and its location.I totally agree with Mr Polson, the Old XE air con compressor set up on top, looks shite, has to be a far nicer way to do it. Share this post Link to post Share on other sites
SXE357 91 Posted July 9, 2015 Cheers Nath-25, It was a very worn out engine when I got it, I stripped it right down, got it cleaned up and a rebore, and rebuilt it using all new stuff, owes me about $3500, worth every cent, and I loved building it, so looking forward to seeing it run, hopefully before Christmas. 1 Nath reacted to this Share this post Link to post Share on other sites
SXE357 91 Posted July 9, 2015 Thanks Lord Far Quad, will look into this option. Cheers Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 10, 2015 Look up high gate car aircon they have a pdf manual to download 1 SXE357 reacted to this Share this post Link to post Share on other sites
SXE357 91 Posted July 10, 2015 Lord Far Quad, can you let me know where to find the PDF Manual to download, had a look through their site, didn't come across anything. Cheers Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 10, 2015 http://highgateair.com.au/images/stories/products-pdf/Compressors.pdf Share this post Link to post Share on other sites
Mr Polson 10,214 Posted February 21, 2016 Falcon with low mount air con at AFD 2016. Used a universal compressor with custom hoses and custom brackets. Bolts into the head somewhere and just in front of the engine mount. And couple of other places I think. Hard to take photos of. 1 XFtoXE reacted to this Share this post Link to post Share on other sites
