Gerry Ahern 366 Posted April 18, 2015 My xb coupe has a factory am radio cassette. Cassette doesn't work but am does. So I need some other source of music, either FM, iPod or usb etc. the catch is, I don't want to change the radio as it looks great. Is there a specific maple way to have a hidden source that is very simple? Others must have done this. Thanks. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted April 18, 2015 Not maple, simple! Share this post Link to post Share on other sites
Olive Xm 34 Posted April 19, 2015 Is the glove box all part of the dash in this model? I had a friend that in his HR, the inner glove box was a plastic insert that could be removed. So then he made a a board to hold a cd player and installed it in there, so you opened the glove box to access the cd player Something like these. https://www.google.com.au/search?q=ipod+in+radio&espv=2&biw=1920&bih=965&source=lnms&tbm=isch&sa=X&ei=ofIyVfKOEOOymAWAsIDQDA&ved=0CAcQ_AUoAg#tbm=isch&q=radio+in+glove+box . Share this post Link to post Share on other sites
deankxf 20,290 Posted April 19, 2015 you also might be able to fit a mechless one (no moving parts for cd/tape etc) in the console or another part of the dash(or in console tray section if it was an XF.. just saw XB so dont cut it up.) they are very compact in depth particularly. one here for example http://www.fusionentertainment.com/car/products/head-units/ca-ml650 actually on ebay from supercheap, go check one out maybe? http://www.ebay.com.au/itm/Fusion-Digital-Media-Player-with-USB-CA-ML650-Super-Cheap-Auto-/201278410452?pt=LH_DefaultDomain_15&hash=item2edd20ced4 i will sus one out myself for the same reason Share this post Link to post Share on other sites
Gerry Ahern 366 Posted April 19, 2015 Yeh thanks, it is possible. Will look in to it. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted April 19, 2015 I like the fusion thing. Share this post Link to post Share on other sites
tpak addict 1,909 Posted April 19, 2015 I have a mechless one in my Fairlane, I was going to hide it in the glovebox but just mounted mine in the normal spot. They are very compact and you can just chuck your music on a USB (Period correct music hehe), no need to have CD's lying around the car either.... Share this post Link to post Share on other sites
Gerry Ahern 366 Posted April 19, 2015 And only $99 at Supercheap! Share this post Link to post Share on other sites
VDO 124 Posted April 19, 2015 Just use an FM adapter. They attach in line on your aerial wire and just connect to accessory power, very simple. Then you tune to a specific frequency on the AM radio and you will pick up the FM band which is adjusted on the FM adapter. Quite small and can hide in the glove box very easily. Here's one: http://www.ebay.com.au/itm/Vintage-Audiovox-FM-Converter-Model-FMC-1C-/261857169026?pt=LH_DefaultDomain_0&hash=item3cf7e74e82 Share this post Link to post Share on other sites
wagoon 2,429 Posted April 19, 2015 You may also be able to mount it in the centre console especially if its a mechless one. So you dont have to run a heap of wires to it use an amplifier then just 3 small wires go the unit (power,ground and amp trigger wire). All the speaker wires then come from the amp Share this post Link to post Share on other sites
Gerry Ahern 366 Posted April 19, 2015 Yeh, another great idea! Thanks! Share this post Link to post Share on other sites
XFChris 126 Posted April 19, 2015 Here is another option you could consider http://www.ebay.com.au/itm/AU-Red-Mini-2CH-Digital-Audio-HI-FI-Stereo-Amplifier-AMP-For-Ipod-Car-Motor-MP3-/181182467393?pt=LH_DefaultDomain_15&hash=item2a2f510d41 I doubt audio quality would be great, and I'm not sure the FM band would be correct for Australia, as these are a chinese product. But on the plus side, they would be small enough to conceal if you wanted to retain a factory look. I'm actually putting one of these (Non FM model) into one of my cars, just need to get around to wiring it up. Share this post Link to post Share on other sites
SweetXF 291 Posted April 19, 2015 https://lh6.googleusercontent.com/proxy/xVOredg1l4fUU-Jp4UfnMyjEDJz9l2iXSGKoXCUbXc5-wfY4NBLZslY9R3Gbq_mGM3IiviAipOMSCUMn3yiVIkjko-cxQxMllOspW-N-UMBU4s-yrR4tWy2AhSNhO_oMaNqP1py3Y7TDbTzLm6A8ZBIvSds3Beeq-4sPYw=w384-h384-nc Here is another idea if you can get working cassette. You can stream almost any Australian radio station through your phone with an app called 'tunein radio', and plug your phone into the 'cassette'. Only thing you would have to be careful with is your data usage on your phone, but you can circumvent this by just playing your own music collection instead of the radio of course. Never actually used one of these cassette thingos though, so cannot tell you how well they actually work. Sent from my Galaxy Note 4........FAKE! Admit it, you thought I had money for a second didn't you? Share this post Link to post Share on other sites
tpak addict 1,909 Posted April 19, 2015 Misses had one years ago in her AU... Worked OK Share this post Link to post Share on other sites
broken-wheel 659 Posted May 3, 2015 This fit's the X series and has bluetooth, mp3 streaming via bluetooth, hands free bluetooth, change illumination to any color you want etc. They are not cheap but they are simply awesome and keep it looking period Mustang depot has them, http://www.mustangdepot.com/OnLineCatalog/Audio/am_fm_cassettes.htm Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 10, 2015 Found Redirad on eBay. Small hidden unit that sits in between aerial connection and has iPod connection. So no cutting at all and get full music. Cool. If they are no good, don't tell me. I've already bought it for $150! 1 Nath reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted July 10, 2015 Let me know how it goes, might get one myself. I'm actually re-locating my head unit to the centre console box this weekend because all the lights are giving me the shits and it looks really out of place. So glad I didn't do any butchery to fit it. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 10, 2015 Yeh it's really important to have an original looking radio. The redirad installs in 5 minutes and nothing is changed 1 Nath reacted to this Share this post Link to post Share on other sites
LJDB 103 Posted July 10, 2015 i unpluged the original am radio in my cortina and ran wires off the plug to a cd player in the glove box. pretty easy really, drill a hole big enough for the wires in the corner of the glove box and run them threw to the back of the cd player. Mine has a remote that i use that to change stations ect and close the glovebox when its parked or playing. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 10, 2015 Yeh good option. Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 10, 2015 I have one of those cassette things with a lead that hangs out, can connect whatever ya want to it via mini stereo jack. Buy a decent one will cost ya a whopping $20. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 10, 2015 Three problems Jack. The cassette player is stuffed, I am lazy and one of my hobbies seems to be paying way more than I should have for parts! Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 12, 2015 Your farked then. Lol Share this post Link to post Share on other sites
