XFGHIA747 76 Posted April 13, 2015 Can you fit a au live axle lsd diff centre in the early e series housing running the e series axles? Have a mate just brought a ex cop au and it has a really nice lsd im keen on if it will fit in a ea diff housing. As my standard xf diff is 2.77 the lsd wont fit in my housing right? I want to chance to 3.08 or 3.23.. Share this post Link to post Share on other sites
deankxf 20,326 Posted April 14, 2015 as far as i know they will fit as i was going to go from EF into AU housing for same reasons. (sold project before doing it though) Share this post Link to post Share on other sites
78xcgxl 241 Posted April 14, 2015 You have to be careful as i know that some early E sereis diffs have a different spline count on the axles than the later model ones. I can't remember the exact figures, not 100% if only on EAs or whether the difference is between whether the early diffs are 2 pinion compared to the later 4 pinion ones. Hopefully someone here knows. Share this post Link to post Share on other sites
broken-wheel 659 Posted April 14, 2015 EF/EL/AU same guts inside the centre if not IRS, never looked at IRS Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted April 25, 2015 You have to be careful as i know that some early E sereis diffs have a different spline count on the axles than the later model ones. I can't remember the exact figures, not 100% if only on EAs or whether the difference is between whether the early diffs are 2 pinion compared to the later 4 pinion ones. Hopefully someone here knows. Eb2 went to 28 spline. 1 78xcgxl reacted to this Share this post Link to post Share on other sites
