Sign in to follow this
xfish
Footwell lights...
HI folks
I'd like to install footwell lights in my ELXR8, and have read that the best source is to tap into the ignition switch light. Is there somewhere else closer that i could tap into.....? to help illuminate the floors.
Im assuming you only want it lit at night?
Couldnt you pull 12v from any light bulb source eg shifter light or cigarette lighter illumination.
Why do you want to light the floors? Im an old fart and no understand!
The big plug for the centre console under the radio has the interior light trigger wires too. That's where the rear console light plugs in. For that one you can even use the console loom from a fairmont etc. Just swaps over but has a globe holder too. Then the lense replaces the blank cover. There or the column light are fine.
Hook it in to the door switch wiring behind the kick panel. Remember the door switches switch earth so youll need a 12v supply to power the other side of the lamp. You can get that from any 12v circuit.
