78xcgxl 241 Posted June 15, 2014 Hi all, I'm running a EF T5 with the standard EF T5 gear shifter behind an AU engine in my XC and the problem is the shifter does not sit perfectly centered in the console in the neutral position because of the curve in the EF shiftier. Now since XCs and XFs both run single rails with the same shifter i was thinking that a XF T5 shifter will fix the problem. So does anyone have a picture of a XF T5 shifter or able to shed any light on this matter? Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted June 15, 2014 2 steve mcqueen and 78xcgxl reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 15, 2014 If you want it more to the drivers side, just mount the shifter lever on the other side of where it is now, Thats what they did in XG utes to bring the stick closer to the driver. Other than that mate or one off another model, I have seen shift kits with an adjustable shift lever position, about 300 bucks from memory. Jack. Share this post Link to post Share on other sites
gerg 10,871 Posted June 16, 2014 Don't try and bend the alloy lever... And don't ask me how I know Share this post Link to post Share on other sites
78xcgxl 241 Posted June 16, 2014 hmm many thanks for the pictures, looks like i will run into the same problems as with the EL shifter, ideally i would need one that is straight but a XF shiftier does look like it would make an improvement, if i can source a cheap one, i'll test it out. I was thinking that when a i install a short shifter it will make it less noticeable. Share this post Link to post Share on other sites
gerg 10,871 Posted June 17, 2014 You can run a spacer between top and bottom parts of the gear lever to get it over closer to you, with longer bolts to suit. Share this post Link to post Share on other sites
78xcgxl 241 Posted June 17, 2014 That could work actually, may give it a go. The shifter is center in terms of driver to passenger but sits too far back. When the it is in neutral it looks as if it is in 4th gear and when the shifter is in 3rd it looks as if it is in neutral ( if that makes any sense, if i remember, i'll take some pics of it tomorrow). Not that this effects the drive-ability i just don't like the look of it. Share this post Link to post Share on other sites
