RAWDEAL 222 Posted February 18, 2014 Hi guys i am picking up a new daily , an nc, i want to drive it home but the ac pump/pulley seized and snapped the belt off of it lol so i wanna buy a belt that bypasses the ac anyone got a part number? AFAIK the length of the belt is 2460mm (minus a bit so that it can tension) Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted February 19, 2014 You can get AC delete pulleys and brackets, but dunno if shorter belts work. One of the joys of serpentine belts.... Share this post Link to post Share on other sites
SLO247 1,713 Posted February 19, 2014 Shorter belt will work on a 5L. Cut the belt, wrap it around how you want to run it and measure how much you need. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted March 1, 2014 Shorter belt will work on a 5L. Cut the belt, wrap it around how you want to run it and measure how much you need. i used some string and a serpentine belt measurer device pole thingo? and came up with this the lhs idler could be deleted while im at it .. same with that top idler Share this post Link to post Share on other sites
judgetread 758 Posted March 1, 2014 I suppose the water pump runs backs wards to normal Windsors, else id say just stick a stock crank and pump pully on it to get home. But ud have to change the water pump too Share this post Link to post Share on other sites
RAWDEAL 222 Posted March 2, 2014 I suppose the water pump runs backs wards to normal Windsors, else id say just stick a stock crank and pump pully on it to get home. But ud have to change the water pump too yeah thought about that but i dont have any early windsor stuff! this should get it home though Share this post Link to post Share on other sites
