Gaz 1,085 Posted April 13, 2014 I've always used a small flat screw driver and some gentle persuasion. A smack on the edge to create a dimple and then use that to tap it around. Once you've gone about 1/2 a turn it will be finger tight 3 Crazy2287, XFute-1JZsoarer and steve mcqueen reacted to this Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted April 16, 2014 That sounds simple, I'll give it a go. Thinking I might wire the XF ign in just to test that it turns over and all that, then find a new one to put in properly. Was kinda thinking of stashing the XF barrel under the dash somewhere and use a start button on the dash. But that's just a thought at the mo. Share this post Link to post Share on other sites
SLO247 1,713 Posted April 16, 2014 I think the plugs are the same for the switches. Just fit the smartlock bypass/j3 and plug in the xf ign switch. Done! 1 XFute-1JZsoarer reacted to this Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted April 22, 2014 Awesome, thanks SLO247 Share this post Link to post Share on other sites
