XTREME KARTS XF 1,212 Posted October 30, 2013 The ignition barrel in my XD ute is wornout (you can take the key out in ACC and ON postions) and i was woundering if the XG ignition barrel will fit the XD steering column? And will the XG door locks work with the XD-XF door mechanism's? Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted October 30, 2013 all bot straight on mind you xg barrels aint the easiest to find Share this post Link to post Share on other sites
Tyler06 266 Posted October 30, 2013 all bot straight on mind you xg barrels aint the easiest to find We sell em new. Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted October 30, 2013 the whole barrel? or just the key part? cause 12 months ago when i wanted one no one could help Share this post Link to post Share on other sites
Tyler06 266 Posted October 30, 2013 The internal barrel and key lol but we have 3 xgs with barrels ;-) 1 Jonathan Mark Davidson reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted October 31, 2013 Awesome, thanks guys Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted October 31, 2013 The internal barrel and key lol but we have 3 xgs with barrels ;-) ok cool will keap that in mind also the internal barrel dont fit in the non smart lock outer barrel the locking pins are slightly out remember seans blue ute? Share this post Link to post Share on other sites
Tyler06 266 Posted October 31, 2013 Yeah finally got rid of the exhaust to it the other day lol 1 Jonathan Mark Davidson reacted to this Share this post Link to post Share on other sites
dusty_ben 143 Posted October 31, 2013 I need new locks and keys for my new xf. Xg may be the way to go Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 31, 2013 Door locks use different cam style to x series, the fit straight in but you cannot use them to open the doors. The ign barrle fits and works but you need the xf style shroud. The low profile shroud wont fit ovee as the mechanisms body is larger Share this post Link to post Share on other sites
Gaz 1,085 Posted October 31, 2013 Door locks use different cam style to x series, the fit straight in but you cannot use them to open the doors. The ign barrle fits and works but you need the xf style shroud. The low profile shroud wont fit ovee as the mechanisms body is larger You can grind all the excess casting off and they fit nicely. Or use an XG column-auto shroud (look like XD/XE style) 2 XTREME KARTS XF and Jonathan Mark Davidson reacted to this Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted March 30, 2014 Is it possible to use an XG column and ignition, but use the XF barrel, so that the smart lock works and the XF locks match the ignition. This is for a XG into XF engine & driveline swap. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 7, 2014 IMO... Horrible idea. You do not want to keep the XF ign barrel if you have a choice. They are TOOOOOO easy to pick. Tibbi locks are a lot safer/harder to pick. Use the XG barrel. To actually answer your Question, I have never done it. But if you can put an XG barrel on an XF column, then you should be able to fit an XF barrel to an XG column. Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted April 7, 2014 Is it possible to use an XG column and ignition, but use the XF barrel, so that the smart lock works and the XF locks match the ignition. This is for a XG into XF engine & driveline swap. no wont work the key its self is part of the smart lock system Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted April 7, 2014 I know how bad they are, but don't really have a choice, the key I got with the XG ignition is stuffed, so doesn't work. Besides, a kill switch is already installed for that reason (guess it works, it's been broken into, never taken though) I found brand new XG ignition barrels (with 2 keys) on eBay for $44 shipped, but doesn't come with door locks And I don't really want to change all the door locks to match a new key if I don't have too. If smartlock is disabled with a J3 chip (ordering one this week), do you think it would work? Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 8, 2014 Go to ford and get a new ign barrel + key. They are like $20 or something fkn cheap like that. I got both doors, boot and ign barrel with 2 keys as a kit for like... $70? Was ages ago but give that a try. If not go to a wreckers and get a second hand one for $10. I'm not going to say how for obvious reasons, PM if you wanna know, but seriously. If you change the barrel to the X series barrel then there is about a 50/50 chance someone could get in and drive off with your car faster than you could using your actual key. It don't work with all of them but it did with all mine so mine both have Tibbi locks now. Share this post Link to post Share on other sites
Tyler06 266 Posted April 8, 2014 100% obsolete now. We are still waiting on a new manufacturer. 1 Crazy2287 reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 8, 2014 Well that's no fkn good. Disregard what i said about new ign barrels then. Is that right through ea-ef as well as i think they barrels are interchangeable?... Share this post Link to post Share on other sites
Tyler06 266 Posted April 8, 2014 I only know that the xg/ h stuff is obsolete. Unsure on other barrels. Share this post Link to post Share on other sites
Ando81 2,950 Posted April 8, 2014 Don't want to sound negative but has someone previously said that xg locks won't work in xf doors as they have different internals? Not 100% sure but I thought I had read it on another thread. I have been caught out trying to fix an xg door internal latch as they are like an eb ed setup which I different to xf. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 8, 2014 That is correct. This is for the IGN barrel only. 1 Ando81 reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted April 11, 2014 Don't want to sound negative but has someone previously said that xg locks won't work in xf doors as they have different internals? Not 100% sure but I thought I had read it on another thread. I have been caught out trying to fix an xg door internal latch as they are like an eb ed setup which I different to xf. Correct, a lot of fuckin around to make it work. Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted April 11, 2014 An ED barrel should go in shouldn't it? I didn't think anything from ford would be that cheap! Lol And how do I take the ignition off the column, it looks like it uses one of those break-away bolts? (You know the ones where the bolt head snaps off when it's torqued up) Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 13, 2014 Yes, You have to rig something up to get it undone Sometimes you can hit the edge of the bolt head with a chisel and hammer to turn it. Or you gotta drill, cut or grind it or tack weld something to it and turn it out. Share this post Link to post Share on other sites
