blackxt 699 Posted August 16, 2013 Hi all. I'm thinking about changing my xg to 5 speed . I have a ea with a t5 can I just use a xf Manuel pedal box with all the rest from the ea Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 16, 2013 Cant see why not. I used an XF pedal box in my XD, It has an XG dash, has an EF donk and I used the box and clutch from an EA, All bolted up no probs. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 17, 2013 X series, EA and EB series 1 used the 3 bolt clutch 240mm dia clutch, EB series 2-AU including the XG and XH commercial vehicles used the 6 bolt 255mm dia clutch. you'll want to get hold of a flywheel thats post EB series 2 (april 1992 onwards) the XG (XF hybrid from factory in other words) shares bits n peices from the EB series 2 and ED falcon. Share this post Link to post Share on other sites
deankxf 20,336 Posted August 17, 2013 X series, EA and EB series 1 used the 3 bolt clutch 240mm dia clutch, EB series 2-AU including the XG and XH commercial vehicles used the 6 bolt 255mm dia clutch. you'll want to get hold of a flywheel thats post EB series 2 (april 1992 onwards) the XG (XF hybrid from factory in other words) shares bits n peices from the EB series 2 and ED falcon. the ea flywheel should fit the XG motor and work fine with the EA clutch Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 17, 2013 the ea flywheel should fit the XG motor and work fine with the EA clutch the bigger 255mm dia clutch has more clamp load than the 240mm dia clutch, also i forgot to say that XG clutch cables are the same as unleaded XF Share this post Link to post Share on other sites
Thom 6,654 Posted August 17, 2013 Ea-Ed clutch cables fit xf unleaded bell housings (single rail and t5) pre unleaded clutch cable goes in the divers side, unless goes in the passenger side (I did this today when I put a t5 in my xe ) Share this post Link to post Share on other sites
deankxf 20,336 Posted August 18, 2013 the bigger 255mm dia clutch has more clamp load than the 240mm dia clutch, also i forgot to say that XG clutch cables are the same as unleaded XF which means it if it worked ok with an EA towing a caravan it will be ok with a ute Share this post Link to post Share on other sites
ZC-Cruiser 0 Posted August 29, 2014 So the EA Flywheel will bolt up to the XG engine OK? What size are the Flywheel Bolts? Do I need to buy special bolts or can I get them from the bolt shop? Share this post Link to post Share on other sites
