Hi, I have an 1994 XG Xr6 Ute. I have just put new headlights, with surrounds in. I wired it all up. Now my lights flicker when the high beams are on.  I have replaced the relays. Also put in lower wattage globes and it is still doing it. What would you suggest is the problem? All wiring seems good, no breaks or frayed wire.
Cheers Mik.
beside the relays in the xg theres a little metal box ,this is a biometalic strip ,this gets hot and it has like contacts inside ,so when you put a lot of power through it ,it shuts the lights down ,
simple fix ,cut it out ,and add a power switch etc
il find some piccis   oh yeah welcome
Welcome!
Probably best moving this to the electrical section.
It sound like your circuit breaker playing up. It sits next to the relays on the drivers side. As Revhead stated, looks like a little metal box, yellow/ purple wires from memory?? it only has two wires going into it.
