XF EDDIE 248 Posted January 14, 2025 3 days ago I learned the meaning of if its flooded forget it and my fg falcon got the engine flooded with water. I pulled the plugs out and got the water out of the cylenders but it wont run now and the engine sounds very lumpy. Im planning on running a compression test but what kinda damage am I gonna be in for. Im already suspecting bent con rods or bent valves but I dont know how to check that apart from just pulling the head and looking at it. Any help would be much appreciated! 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
deankxf 21,501 Posted January 15, 2025 bent con rods are likely. there might be a way to check by dipping something down the spark plug holes and rotating the engine by hand. if one or 2 are lower on each top of the stroke position then bent conrod is confirmed. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 15, 2025 Ill give that a try. If con rods are fked what else needs doing or could I get some rods and go? Share this post Link to post Share on other sites
deankxf 21,501 Posted January 15, 2025 55 minutes ago, XF EDDIE said: Ill give that a try. If con rods are fked what else needs doing or could I get some rods and go? depends i guess. if it was mine i'd probably chuck another engine in. @Thom may know if a bore could crack from it, i'd expect it possible, so therefore having the engine block crack tested might be something to do. i wouldn't expect anything else, but i also don't know heaps about this issue. Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 15, 2025 1 hour ago, deankxf said: depends i guess. if it was mine i'd probably chuck another engine in. @Thom may know if a bore could crack from it, i'd expect it possible, so therefore having the engine block crack tested might be something to do. i wouldn't expect anything else, but i also don't know heaps about this issue. That probably would be the go, although if most of the guts are ok I was maybe thinking of doing a turbo build (nothing too crazy just put some stock xr6t parts on it if i can find them cheap) Share this post Link to post Share on other sites
SPArKy_Dave 9,427 Posted January 15, 2025 7 hours ago, XF EDDIE said: 3 days ago I learned the meaning of if its flooded forget it and my fg falcon got the engine flooded with water. How did that happen - a flooded road? Yeah, water doesn't compress, although I wouldn't have thought bent conrods, would make the engine run poorly? An inspection camera down each bore, could be helpful maybe? A leakdown test, would show any bent valves. Plus as @deankxf says, measuring each cylinder stroke with a plastic stick or similar, would be useful! Did you replace the oil too - I imagine that would be full of water also? Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 15, 2025 42 minutes ago, SPArKy_Dave said: How did that happen - a flooded road? Yeah, water doesn't compress, although I wouldn't have thought bent conrods, would make the engine run poorly? An inspection camera down each bore, could be helpful maybe? A leakdown test, would show any bent valves. Plus as @deankxf says, measuring each cylinder stroke with a plastic stick or similar, would be useful! Did you replace the oil too - I imagine that would be full of water also? The oil has no water in it as I got to the other side before it died. Yeah flooded road with overgrown depth markers, water was only about 30 cm deep but this car is too low for almost any water and so it went over the bonnet and flooded the intake. Im worried if maybe the main bearing caps would have been damaged, if the block and head are salvagable ill put some new rods in it and do it up to xr6t spec. Also might be a dumb question but would el rods fit? I got an el bottom end in the scrap heap and it would be nice to get something out of it Share this post Link to post Share on other sites
Thom 6,716 Posted January 15, 2025 depends i guess. if it was mine i'd probably chuck another engine in. [mention=43]Thom[/mention] may know if a bore could crack from it, i'd expect it possible, so therefore having the engine block crack tested might be something to do. i wouldn't expect anything else, but i also don't know heaps about this issue. The oil has no water in it as I got to the other side before it died. Yeah flooded road with overgrown depth markers, water was only about 30 cm deep but this car is too low for almost any water and so it went over the bonnet and flooded the intake. Im worried if maybe the main bearing caps would have been damaged, if the block and head are salvagable ill put some new rods in it and do it up to xr6t spec. Also might be a dumb question but would el rods fit? I got an el bottom end in the scrap heap and it would be nice to get something out of itCompression test will show if the engine is mechanically damaged, all cylinders within 5-8% of the same reading should still run smoothly, a bent rod or valves will show lower compression on that cylinder, cylinder walls can crack from hydrolocking but you would most likely bend rods firts (and possibly damaged the skirt on a few pistons if the rod hes bent far enough to let the piston hit the crank, alternatively if the rod twisted it could have bent far enough the valve reliefs dont line up any more, in that case you would have bent valves too) and if the cylinder wall was cracked you would have water in the sump, main bearings will be totally fine unless you've managed to bend the crank but it would probably not run if you managed to do that, e series rods are shorter than au-fgx except el hybrid engines they are the same length as au-fgx, the bigger problem for swapping rods on anything but a factory turbo 4.0 is they use a press fit gudgeon pin and are quite difficult to change without the proper equipment,.you also can't put sohc pistons in a barra as the valve reliefs are in the wrong position for the barra head 1 deankxf reacted to this Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 15, 2025 40 minutes ago, Thom said: Compression test will show if the engine is mechanically damaged, all cylinders within 5-8% of the same reading should still run smoothly, a bent rod or valves will show lower compression on that cylinder, cylinder walls can crack from hydrolocking but you would most likely bend rods firts (and possibly damaged the skirt on a few pistons if the rod hes bent far enough to let the piston hit the crank, alternatively if the rod twisted it could have bent far enough the valve reliefs dont line up any more, in that case you would have bent valves too) and if the cylinder wall was cracked you would have water in the sump, main bearings will be totally fine unless you've managed to bend the crank but it would probably not run if you managed to do that, e series rods are shorter than au-fgx except el hybrid engines they are the same length as au-fgx, the bigger problem for swapping rods on anything but a factory turbo 4.0 is they use a press fit gudgeon pin and are quite difficult to change without the proper equipment,.you also can't put sohc pistons in a barra as the valve reliefs are in the wrong position for the barra head The engine dosent sound too fucked up (no knocking or scraping) just sounds like it has a dead battery. So if the rods are bent could I still run a leakdown test to see if the valves are still good? Im just thinking if just the rods are bent can I just get some used rods and just slap it back together? Share this post Link to post Share on other sites
Thom 6,716 Posted January 15, 2025 The engine dosent sound too fucked up (no knocking or scraping) just sounds like it has a dead battery. So if the rods are bent could I still run a leakdown test to see if the valves are still good? Im just thinking if just the rods are bent can I just get some used rods and just slap it back together?If its winding over slow that's a good indication of bent things, unfortunately you won't know what you need to replace until you do a bit more investigation, a leak down test will show if the cylinders are still sealing, but if you've got to pull the head off anyway to change rods+ whatever else is damaged you may as well inspect the valvetrain while it's off Share this post Link to post Share on other sites
SPArKy_Dave 9,427 Posted January 16, 2025 Does the compression sound even, when cranking (even slowly?) Does it crank faster, with the spark plugs out? The starter could be shorting internally, due to to water ingress? I'd try measuring the current draw, if you have a clamp style ammeter. 1 the miracle stick mechanic reacted to this Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 18, 2025 Well ive done a compression test and everything is bad. First off the tips of the plugs were all wet with water so there have been more water hiding in the intake and second the readings arent great with all cylinders being zero except for for number 1 which was 30. I could hear compression when I put the gauge in and this gauge has been very dodgy before so im going to rerun the test with a new gauge. However if these readings are correct what does this mean? Bent valves across the board? Share this post Link to post Share on other sites
the miracle stick mechanic 131 Posted January 18, 2025 11 hours ago, XF EDDIE said: Well ive done a compression test and everything is bad. First off the tips of the plugs were all wet with water so there have been more water hiding in the intake and second the readings arent great with all cylinders being zero except for for number 1 which was 30. I could hear compression when I put the gauge in and this gauge has been very dodgy before so im going to rerun the test with a new gauge. However if these readings are correct what does this mean? Bent valves across the board? Is it auto or manual transmission ? If auto, the torque converter would slip before the engine is bending the conrods. Did the rear wheels skid when it happened ? Share this post Link to post Share on other sites
Thom 6,716 Posted January 18, 2025 Well ive done a compression test and everything is bad. First off the tips of the plugs were all wet with water so there have been more water hiding in the intake and second the readings arent great with all cylinders being zero except for for number 1 which was 30. I could hear compression when I put the gauge in and this gauge has been very dodgy before so im going to rerun the test with a new gauge. However if these readings are correct what does this mean? Bent valves across the board?Sounds like it's autopsy time, if the gauge is correct, it means that every cylinder has damage, you won't know without pulling the head off or using a bore scope to assess what went wrong, but if I were a betting man I would say you have more than your fair share of bent rods and valves, and if it is really that bad you may be better of financially to just swap the whole engine Share this post Link to post Share on other sites
the miracle stick mechanic 131 Posted January 19, 2025 19 hours ago, Thom said: Sounds like it's autopsy time, if the gauge is correct, it means that every cylinder has damage, you won't know without pulling the head off or using a bore scope to assess what went wrong, but if I were a betting man I would say you have more than your fair share of bent rods and valves, and if it is really that bad you may be better of financially to just swap the whole engine How exactly does water in the engine bend a valve when it would just pump the water through an open valve ? He hasn't even done a compression test with a decent compression gauge . I disagree . Share this post Link to post Share on other sites
Thom 6,716 Posted January 19, 2025 How exactly does water in the engine bend a valve when it would just pump the water through an open valve ? He hasn't even done a compression test with a decent compression gauge . I disagree . Rod bends and twists, valve pocket is no longer below valve, flat of the piston hits a valve and bends it Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 22, 2025 Just wondering what engines can I put in a fg? I saw a bf barra come up for cheap near me and was wondering if it would work? Share this post Link to post Share on other sites
deankxf 21,501 Posted January 22, 2025 1 hour ago, XF EDDIE said: Just wondering what engines can I put in a fg? I saw a bf barra come up for cheap near me and was wondering if it would work? in case no one else jumps in before you find the answer. i believe the dipstick location could be an issue, (block or sump may need drilling) sump and might be different, definitely look it up before buying. (i only vaguely remember Street Machine's turbo taxi being a pain for similar reasons. ) Share this post Link to post Share on other sites
XF EDDIE 248 Posted January 23, 2025 17 hours ago, deankxf said: in case no one else jumps in before you find the answer. i believe the dipstick location could be an issue, (block or sump may need drilling) sump and might be different, definitely look it up before buying. (i only vaguely remember Street Machine's turbo taxi being a pain for similar reasons. ) Ahh great Share this post Link to post Share on other sites
XF EDDIE 248 Posted February 10, 2025 Ok so Ive got my new compression tester and got some new results Cylinder 1: 90 psi Cylinder 2: 90 psi Cylinder 3: 50 psi Cylinder 4: 55 psi Cylinder 5: 30 psi Cylinder 6: 25 psi I'm thinking bent con rods at this point but I'll do a leak down test before I start the autopsy. Got any other thoughts on what I should do before I crack the head off? Share this post Link to post Share on other sites
SPArKy_Dave 9,427 Posted February 10, 2025 1 hour ago, XF EDDIE said: Got any other thoughts on what I should do before I crack the head off? I'd check for bent conrods, using a straw, plastic stick or similar, down the spark plug holes. Share this post Link to post Share on other sites
Thom 6,716 Posted February 11, 2025 Ok so Ive got my new compression tester and got some new results Cylinder 1: 90 psi Cylinder 2: 90 psi Cylinder 3: 50 psi Cylinder 4: 55 psi Cylinder 5: 30 psi Cylinder 6: 25 psi I'm thinking bent con rods at this point but I'll do a leak down test before I start the autopsy. Got any other thoughts on what I should do before I crack the head off?You may as well just pull it apart, with that much variation it's not going to be fixed without at least the head coming off so you'd as well do it to know what your up against 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,501 Posted February 11, 2025 4 hours ago, Thom said: You may as well just pull it apart, with that much variation it's not going to be fixed without at least the head coming off so you'd as well do it to know what your up against that's what i was going to say, surely with 100psi lost in each cyl, it's got some serious issues.. taking the rocker cover off might show some gnarly carnage alone. 1 Thom reacted to this Share this post Link to post Share on other sites
XF EDDIE 248 Posted June 5, 2025 Well I have finally returned to this now that I need a car for a mate, I got my hands on another xr6 that had been in a wreck for $1000 and am pulling the engine out of it today (if anyone needs fg parts hit me up). The plan is to do the swap for now and then rebuild the original engine to turbo spec and make an xr6 turbo out of it. Ill keep you posted but so far so good! Its not just safe, its 40% safe! Share this post Link to post Share on other sites
XF EDDIE 248 Posted June 5, 2025 Well with one problem down another pops up, I can't find the bloody inspection cover on this thing. Ill try rattling out the bolts and see if its just splined together but Im completely stumped about how to get at the converter bolts. Share this post Link to post Share on other sites
