Demmo 266 Report post Posted January 27 ok people I would like to know if anyone has repaired splits/cracks in front bumpers successfully using a glue or two pac product. as a local bouncy kick boxer used his head to ram me the other night. the impact folded the bumper upwards causing the plastic corner to split I believe there is plastic welding repair places in the metro area but I am hoping I can repair it at home any thoughts or advice appreciated o and this time the ford won cheers demmo Share this post Link to post Share on other sites
2redrovers 14,313 Report post Posted January 27 At the smash shop I used to use fusor brand 2part glue for plastics or weld it back together with the soldering iron or combination of whatever worked for the specific repair at the time. The glue works best with a rough surface to grip and needs to be spotless clean, also some sort of mesh like fibreglass tape or fly screen to reinforce the join helped where suitable. I have read that acetone will melt abs and weld itself back together but you would have to try it out on some scraps before the real thing becomes I haven't done it personally. If I knew back then it would have saved a lot of time and effort if it works. 1 gerg reacted to this Share this post Link to post Share on other sites
Demmo 266 Report post Posted January 27 is this the go FUSOR 101EZ PLASTIC PANEL REPAIR ADHESVE - TRADE / WORKSHOP USE its on eflay Share this post Link to post Share on other sites
2redrovers 14,313 Report post Posted January 27 Yep that's the stuff we used. I recommend any of the fusor products when you are looking for trade quality adhesives, pricey but excellent quality. Share this post Link to post Share on other sites
2redrovers 14,313 Report post Posted January 27 You should be able to get the data sheets for it and double check that it will do what you want and to see exactly how to use it properly. Share this post Link to post Share on other sites
Demmo 266 Report post Posted January 27 thanks for that have just ordered it from fleabay hope postal services have pulled there finger out now vic boarder is open lol cheers Demmo 1 2redrovers reacted to this Share this post Link to post Share on other sites
