Panko 2,502 Posted November 21, 2019 Hi Guys, simple question. Is an early E series (EA/B) flywheel the same as an XF crossflow flywheel (84DA block) Cheers 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,688 Posted November 21, 2019 i know the ea 1 is,with borgy auto,not sure about the later ones.but 84da has the larger bolts is only difference Share this post Link to post Share on other sites
Panko 2,502 Posted November 21, 2019 Just now, CHESTNUTXE said: i know the ea 1 is,with borgy auto,not sure about the later ones. cool. as part of my engine build, im thinking of replacing my flywheel which has been machined plenty of times, with a brand new one. cant seem to find brand new crossflow flywheels, but can find EB ones brand new. I maybe pedantic, but i figure if the rest of the engine and driveline, inc. gearbox and diff is new/recoed, why not start with everything new? so if you know anywhere i can purchase brand new flywheels, that would also help Share this post Link to post Share on other sites
CHESTNUTXE 7,688 Posted November 21, 2019 are you saying flexplate or flywheel for manual ? Share this post Link to post Share on other sites
Panko 2,502 Posted November 21, 2019 flywheel. for manual. not flexplate. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,688 Posted November 21, 2019 flywheel. for manual. not flexplate. Mine is a el drilled out to suit 84ds boltsSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Panko 2,502 Posted November 21, 2019 8 minutes ago, CHESTNUTXE said: Mine is a el drilled out to suit 84ds bolts Sent from my SM-G570Y using Tapatalk cool, so centre bore that locates on the crank is the same ? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,688 Posted November 21, 2019 YEAH ,you have got more chance of bying a new e series than the older flywheel size but not impossible Share this post Link to post Share on other sites
Mustardxf2 310 Posted November 24, 2019 NPC do a lightened flywheel for the crossflow, which I believe is a 4l flywheel drilled to suit crossflow, accepts 10.5” clutch with 6 bolt pattern and dowels instead of 3 bolts. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Panko 2,502 Posted November 25, 2019 On 11/24/2019 at 11:45 AM, Mustardxf2 said: NPC do a lightened flywheel for the crossflow, which I believe is a 4l flywheel drilled to suit crossflow, accepts 10.5” clutch with 6 bolt pattern and dowels instead of 3 bolts. Sent from my iPhone using Tapatalk thanks mate. legend. I will check it out. Share this post Link to post Share on other sites
Mustardxf2 310 Posted November 25, 2019 RNF44 is the flywheel part number, you’ll need to make them aware that it willBe bolting to a crossflow.Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Mustardxf2 310 Posted November 25, 2019 This is the package I just got from NPCSent from my iPhone using Tapatalk 1 Panko reacted to this Share this post Link to post Share on other sites
