Simmo74 0 Posted April 28, 2019 Hi im looking for striker plates for xg falcon ute 1995 cant find anywhere does anybody know where i can buy some from Share this post Link to post Share on other sites
Ando81 2,950 Posted April 28, 2019 Maybe Eb falcon are the same mate, I know the latch mechanism inside an xg door is the same as eb. I didn’t know xg strikers were different to the xf ones, never looked closely. Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Its just the holes to line up the bolts are different its just one of those head fucks Share this post Link to post Share on other sites
Ando81 2,950 Posted April 28, 2019 Oh what a pain in the arse, hopefully someone on here will be able to help you out or show you where to find some. Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Thanks mate appreciate ur input Share this post Link to post Share on other sites
deankxf 20,339 Posted April 28, 2019 use E series Rear ones(fronts are same, but worn out) if you go to wreckers. so EA EB ED EF EL.. the latch assy is same as the E series fronts i think also in the door other than the rods that attach 1 Ando81 reacted to this Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Thanks deankdx but the holes are different they dont line up but thinking of modifying other striker plates just hoping to find somewhere i can purchase new ones cause its one of things that wears Share this post Link to post Share on other sites
Ando81 2,950 Posted April 28, 2019 Check your door hinges and pins mate, I’ve always kept a small amount of grease on the striker and they seem to do a lot of work and don’t show big signs of wear Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Ok thanks for the tip just that the doors keep coming open around corners sometimes just want to sort this cause its friggin dangerous Share this post Link to post Share on other sites
deankxf 20,339 Posted April 28, 2019 5 minutes ago, Simmo74 said: Ok thanks for the tip just that the doors keep coming open around corners sometimes just want to sort this cause its friggin dangerous 12 minutes ago, Simmo74 said: Thanks deankdx but the holes are different they dont line up but thinking of modifying other striker plates just hoping to find somewhere i can purchase new ones cause its one of things that wears got a photo? sure there's not a left and right version.. must either not be adjusted right or the mechanism in the door is dodgy. Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Ive got it this panel beater who is really good with falcons knows his stuff but cant find new striker plates he is having teouble too so i got on here hoping someone knew someone or somewhere to buy them new Share this post Link to post Share on other sites
deankxf 20,339 Posted April 28, 2019 1 minute ago, Simmo74 said: Ive got it this panel beater who is really good with falcons knows his stuff but cant find new striker plates he is having teouble too so i got on here hoping someone knew someone or somewhere to buy them new when i needed to buy them for My XG, i went to wreckers and got E series ones. from rear doors (less worn) 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted April 28, 2019 I’m wondering if a spring in the inside mechanism might be stuffed and not making it properly latch onto the striker when the door shuts onto it. Share this post Link to post Share on other sites
Simmo74 0 Posted April 28, 2019 Will check all the advice given thanks guys if none of these tips dont work ill be back here having a whinge lol Share this post Link to post Share on other sites
Ando81 2,950 Posted April 28, 2019 Just see if the door locks ok from inside, I fixed a door mechanism on my brother’s xg a few years back and the door locking part wasn’t right when his mechanism was playing up. Share this post Link to post Share on other sites
deankxf 20,339 Posted April 28, 2019 there is a spring that breaks in them, usually will see it won't lock or locks itself with the snipper button. i don't think it will affect the door latching.. the mechanism could be full of dusty grease, i washed mine out in petrol and the door worked as new on the side with the good spring, i swapped a spring from an e series one on the other. 1 Ando81 reacted to this Share this post Link to post Share on other sites
2redrovers 21,404 Posted April 28, 2019 Sounds like the striker needs to move outwards slightly. It's likely to be a door/hinge alignment problem, get him to check the door for fatigue cracks while he's messing around with things. If the door is cracked at the hinge it could make the self opening worse.If he's good I'm sure he'll sort it for you but these days may not be familiar with older models. Can't say I ever saw an x series come through the smash shop while I was working that side and that was a few years ago now. 1 deankxf reacted to this Share this post Link to post Share on other sites
Demmo 295 Posted April 28, 2019 I had a similar thing happen on the van and the passenger door would open if left unlocked while driving locking the door seemed to stop it from memory the mechanic changed the door mechanism but I don't think he changed the pillar striker plate. that's handy to know that the striker plates are same as rear sedan doors I have only owned utes and vans in the e series so I will have to have a look next time I am at Tipmart cheers demmo Share this post Link to post Share on other sites
JimmyG 0 Posted May 21, 2019 Hey Guys, will the EB workshop manual help me with my XG? Seems like many parts are the same. Share this post Link to post Share on other sites
Gravelrash 36 Posted December 30, 2021 anybody still after striker plates? i`m about to recondition a batch. Share this post Link to post Share on other sites
