winton 399 Posted January 12, 2019 Hi All, So my engine has develop a noise which I would describe as a chatter from around 3000 rpm. Normal driving I change gear around 3000 and the engine produces the chatter noise. If I put my foot down the engine make more of a rattling noise from 3000 up but it's not as noticeable. Im thinking valve train so I checked and adjusted the lash at .020, no change. I thinking possibly harmonic vibration, hope not. Anyone have any ideas or what else it could possibly be? Cheers Share this post Link to post Share on other sites
gregaust 319 Posted January 12, 2019 Sure it's not pinging?? Lash @ .020" . Is it a solid cam? Share this post Link to post Share on other sites
winton 399 Posted January 12, 2019 Yeah solid and def not pinging Share this post Link to post Share on other sites
Grimmy 312 Posted January 13, 2019 Is your flywheel still attached? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted January 13, 2019 check tailshaft and diff bolts ect. Share this post Link to post Share on other sites
winton 399 Posted January 13, 2019 2 hours ago, Grimmy said: Is your flywheel still attached? this is a possibility but it's not noisy at idle. Share this post Link to post Share on other sites
winton 399 Posted January 13, 2019 1 hour ago, CHESTNUTXE said: check tailshaft and diff bolts ect. Yeah def tight Share this post Link to post Share on other sites
gerg 10,871 Posted January 13, 2019 Is it only while driving or can you pop the hood and free-rev it to make the noise? Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted January 13, 2019 Is it only while driving or can you pop the hood and free-rev it to make the noise? Sent from my CPH1607 using TapatalkLoose converter or flexplate?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,292 Posted January 13, 2019 On 12/01/2019 at 3:18 PM, winton said: Hi All, So my engine has develop a noise which I would describe as a chatter from around 3000 rpm. Normal driving I change gear around 3000 and the engine produces the chatter noise. If I put my foot down the engine make more of a rattling noise from 3000 up but it's not as noticeable. Im thinking valve train so I checked and adjusted the lash at .020, no change. I thinking possibly harmonic vibration, hope not. Anyone have any ideas or what else it could possibly be? Cheers My gemini has made some horrible noises from oddball things. one was loose alternator making a knocking noise and vibration.. the most recent(now you've reminded me) is air cleaner lid has a cracked weld (that i did) that has it vibrating at about 3000 ish rpm falcons over the years have had the heat sheild do similar over the exhaust flange, clutch cable spring missing making the fork rattle and BELTS.. try tipping some water over the fan belt, see if it goes away Share this post Link to post Share on other sites
winton 399 Posted January 13, 2019 3 hours ago, gerg said: Is it only while driving or can you pop the hood and free-rev it to make the noise? Sent from my CPH1607 using Tapatalk You know what didn't try this, just did and its not making the noise. 1 gerg reacted to this Share this post Link to post Share on other sites
winton 399 Posted January 13, 2019 3 hours ago, CHESTNUTXE said: Loose converter or flexplate? Sent from my SM-G570Y using Tapatalk Possibly loose flexplate but its not making noise at idle. I am going to pull the trans to check when I have a chance. Share this post Link to post Share on other sites
winton 399 Posted January 13, 2019 2 hours ago, deankdx said: My gemini has made some horrible noises from oddball things. one was loose alternator making a knocking noise and vibration.. the most recent(now you've reminded me) is air cleaner lid has a cracked weld (that i did) that has it vibrating at about 3000 ish rpm falcons over the years have had the heat sheild do similar over the exhaust flange, clutch cable spring missing making the fork rattle and BELTS.. try tipping some water over the fan belt, see if it goes away Yeah I don't think its any bolt ons, and auto. Pretty sure if it was a fan belt issues the belt would liberate it's self but I'll check it out 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted January 13, 2019 34 minutes ago, winton said: Yeah I don't think its any bolt ons, and auto. Pretty sure if it was a fan belt issues the belt would liberate it's self but I'll check it out check the noise out on mine at 1.18. (naturally it was much worse at bigger revs) was alternator bolt missing Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted January 13, 2019 i was just watching this video while listning to black sabbath Share this post Link to post Share on other sites
deankxf 20,292 Posted January 13, 2019 1 hour ago, CHESTNUTXE said: i was just watching this video while listning to black sabbath paranoid? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted January 13, 2019 paranoid?Nah the mixture of Sabbath and deans engine was perfect the song was lost in the wheels of confusion Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
