CHESTNUTXE 7,310 Posted November 16, 2019 why are you pulling it apart? are you planning to make any changes to it? if you want to use a larger cam you need to retrofit the e series dog bones as the plastic lifter guides have a limited amount of space for lifrtIt wasn't stored that well after 12 months in a shed and just needs a clean up with rings n bearings Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 Yeah if you do a cam you really need to watch PTV clearance, anything over about .520 lift is getting into dangerous territory. However I know someone with .544 with no issues in a roller 302w with stock P heads and pistons. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 i noticed the pistons in this engine dont have the small dish as in the EB 5.0L Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 The first of the EB series Windsor’s had factory forged pistons. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 does anyone know the factory comp ratio with the GT40 P heads ? and or cc volume ? i found some basic info but not exactly the comp ratio Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 Hey one thing i noticed was the timing chain had hardly any slack in it. Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 Basically 9.0:1 Comp and 60-62cc cambers. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 ok cheers,so i figure to put this thing back together looking ol school with single v belt,so i need a 50 oz weight balancer i guess but will the eb style balancer fit the original stlye pulleys ? or is there a special balancer for this app ? Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 The EB is V belt from memory. The gt40p heads could flow 200cfm from factory, best factory ford Windsor iron head produced.Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 did you see how clean inside of the rocker covers are ,like new,but it needs a freshen up as plenty off dirt and gunk got all over the motor,im looking at timing covers i guess im gunna need an older style one with the dipstick hole,and what water pump suits the older way ? is it r/h or l/h out let ? Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 You can buy various timing covers to suit, depends on the application and whether you want to run a mechanical fuel pump. I have one which can take a crank angle sensor, mechanical fuel pump and standard rotation water pump. The outlet for the water pump is on the passenger side. What is this going into? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 You can leave the dipstick in the sump. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 Sent from my iPhone using TapatalkMy sump is fkd i was gunna buy just a std falcon one Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 This is what I run, standard rotation with mechanical fuel pump for the carb. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 My sump is fkd i was gunna buy just a std falcon one Sent from my SM-G570Y using TapatalkJust buy another standard efi sump. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 Just buy another standard efi sump. Sent from my iPhone using TapatalkBut i dont have any dipstick someone took itSent from my SM-G570Y using Tapatalk 1 NZXD reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 16, 2019 If you're looking for decent street cams, the Ford Motorsport E303 and B303 are good, proven units that won't mess up the EFI. The B is a bit more cam than the E.Sent from my CPH1903 using Tapatalk 2 Thom and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 16, 2019 from what i have read about the gt40p heads is that they have a piss weak valve spring that is only good for the std cam, Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 17, 2019 from what i have read about the gt40p heads is that they have a piss weak valve spring that is only good for the std cam,Just took no 1 rod n piston out for a general look Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 17, 2019 The E303 has a very nice choppy idle, very popular in the US, .498 lift and 220 degrees@.50Yeah the factory springs aren’t much chop, but you would be fine running the E303, might get some valve float around 6k rpm. Sent from my iPhone using Tapatalk 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 17, 2019 The E303 has a very nice choppy idle, very popular in the US, .498 lift and 220 degrees@.50Yeah the factory springs aren’t much chop, but you would be fine running the E303, might get some valve float around 6k rpm. Sent from my iPhone using TapatalkFirst lil clean up off piston and bearings look a little worn Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 17, 2019 Compare that to a 1970 302 Windsor rod and piston. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 17, 2019 im just gunna slowly clean everything and re asemble with new rings n bearings,bore looks great ,no lip,no scratches,still has hone criss cross,will give the block a clean then deciding on a colour,might go an old school ford light blue maybe or windsor blue,keeping cam stock ,got my eye on a rpm air gap just for good looks,or weiand ,last time bought a edelbrock performer looked good. 1 gerg reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted November 17, 2019 What is it going into?Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
