gerg 10,871 Posted April 25, 2021 Hope the bores and jackets are okSent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 25, 2021 who ever pulled it apart many moons ago put thick grease on the bores and cyl head chambers ,the motor has definatly been rebuilt before,im hoping the heads got a bit of a rebuild as well ,i also found a little bit of lip on the bore ,the further i get into this 400 im not feeling to throw massive money at it,probly just a re builder ,im finding quite a few of these now,and when the right one comes along then do it up big,he said it came out of a f truck and it probvly did in its 2nd life as there is a pilot bearing in the crank for a manual,original was in the galaxie. 2 1 Outback Jack, gerg and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 26, 2021 i broke one of the pistons today trying to free up a pin on the rod,all the rest were fine ,so no choice now its gunna need new pistons ,once olm8 measures it up after tanking we will see if it needs a rebore or maybe we can get out of it with just a ridgecut if anything and keep std bore size as i dont wanna get into to deep in this one,std cheap replacement pistons with the big dish will keep it in 8 to 1 region or so ,fine for a std rebuilder. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 27, 2021 i broke one of the pistons today trying to free up a pin on the rod,all the rest were fine ,so no choice now its gunna need new pistons ,once olm8 measures it up after tanking we will see if it needs a rebore or maybe we can get out of it with just a ridgecut if anything and keep std bore size as i dont wanna get into to deep in this one,std cheap replacement pistons with the big dish will keep it in 8 to 1 region or so ,fine for a std rebuilder.In that case, you could bump the compression up a bit of you have a set of 302 heads available. Sent from my CPH1920 using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 27, 2021 In that case, you could bump the compression up a bit of you have a set of 302 heads available. Sent from my CPH1920 using TapatalkThe heads are 2v open huge 78cc chambers,interesting note our opens were 72ccSent from my SM-G610Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 27, 2021 The heads are 2v open huge 78cc chambers,interesting note our opens were 72ccSent from my SM-G610Y using TapatalkPictureSent from my SM-G610Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 29, 2021 here is a picture of a rare vintage holley street dominator 2v 400 manifold. 2 gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted April 29, 2021 Wow...! Deep Throat. 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 29, 2021 weiand also made one for the 400 in single plane but very few were ever made ,just a couple of years and another 400 holy grail part. Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 29, 2021 weiand also made one for the 400 in single plane but very few were ever made ,just a couple of years and another 400 holy grail part.Ok i have cleaned and oiled up some parts n bolts plus pushrods and block is ready for the machine shop i hope its good news ,also note hammer on table that is the only tool needed to fix a 400 also need to bring that manifold up to scratch by wet or some type of blasting and also the crank ,note load spreader ,would this be used on a manual as well as a flexplate ?Sent from my SM-G610Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2021 The manifold came up pretty good, what did you use on that?Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 29, 2021 i garantee you that manifold looks worse i think after i lightly degreased it ,i really want it to look clean and shiny,i looked on that wet blasting ,on you tube,differance between dry and wet blast. Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2021 i garantee you that manifold looks worse i think after i lightly degreased it ,i really want it to look clean and shiny,i looked on that wet blasting ,on you tube,differance between dry and wet blast.I only got that kit because I have a Karcher already. It does a pretty good job and makes a lot less mess and noise than air blasting, and the fine sand particles once they've impacted the job are captive in the water as opposed to floating around in the air and screwing people's lungs.Sent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 29, 2021 what about just using my sand blaster its only a small kit,i have left over used fine garnet from the xd build. Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2021 what about just using my sand blaster its only a small kit,i have left over used fine garnet from the xd build.Sure that would work, it won't make it shiny though. It will give a dull, "as cast" finish.Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted April 29, 2021 Agreed. Prime it and wheel silver paint. Easier to wipe oil stains off too.... 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted April 30, 2021 Hey Chestnut, try this Ali cleaner, it's a phosphoric acid.Brings up cast Ali like brand new.Use a spray bottle, and spray it on neat or 50/50 with water.But remember to add the acid to the water if you mix it, not the other way around or it will splatter and burn you. Ali gearbox from this...... To this..... Notice it worked best on the cast extension housing. I spray it on, let it sit for 10-15 minutes then spray again and scrub with a brush.Wash off with water.Will come up like new. Sent from my S21 using Tapatalk 3 CHESTNUTXE, gerg and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 30, 2021 Hey Chestnut, try this Ali cleaner, it's a phosphoric acid.Brings up cast Ali like brand new.Use a spray bottle, and spray it on neat or 50/50 with water.But remember to add the acid to the water if you mix it, not the other way around or it will splatter and burn you. Ali gearbox from this...... To this..... Notice it worked best on the cast extension housing. I spray it on, let it sit for 10-15 minutes then spray again and scrub with a brush.Wash off with water.Will come up like new. Sent from my S21 using Tapatalk Varkin hell that looks good ,here is the balancer cleaned up a bit 72da numbers matching block n headsSent from my SM-G610Y using Tapatalk 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted April 30, 2021 this kit looks good ,just about has everything for about $750 landed,if i bought all these bits seperaterly it would be at least $1500 from e bay australia.https://www.ebay.com/itm/171114954649 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted May 1, 2021 this kit looks good ,just about has everything for about $750 landed,if i bought all these bits seperaterly it would be at least $1500 from e bay australia.https://www.ebay.com/itm/171114954649Just starting to run the taps thru all the threads nothing bad so far considering its been sitting for yearsSent from my SM-G610Y using Tapatalk 2 gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted May 1, 2021 Just starting to run the taps thru all the threads nothing bad so far considering its been sitting for yearsSent from my SM-G610Y using TapatalkHuston we have a problem it has a hole in the bottom of the bore maybe it can be sleeved or welded ? Other than that it came up good ,this thing definitely needs boringSent from my SM-G610Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 1, 2021 Is it just me or has that had a sleeve already?Sent from my CPH1920 using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted May 1, 2021 nah thats std bore,the other pic is the lip on the block,if its just 1 sleeve the cost is not to bad and worth fixing,but lets see what he says come next week. Share this post Link to post Share on other sites
CHESTNUTXE 7,339 Posted May 1, 2021 here is another good question that i cant find the answer on the internet,will a 351c main girdle fit a 400 i know the bolts are the same but what about the rest ? Share this post Link to post Share on other sites
gerg 10,871 Posted May 1, 2021 here is another good question that i cant find the answer on the internet,will a 351c main girdle fit a 400 i know the bolts are the same but what about the rest ?I'm guessing no unless they're made to also fit stroker cranks.Sent from my CPH1920 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
