deankxf 20,288 Posted May 20, 2018 if there is enough length still on the line(probably is) you can just put a new nut and have it flared on the end also.. (cut off with hack saw etc) i've had that done before when i've fitted E series diffs to XE XF before the adapter was known about(fitting X series nuts on E series brake line to the T hose block) was probably $10 for the nuts and flares done 3 jca25, Free.51 and Outback Jack reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted May 20, 2018 Where would i get the nut from Dean? Share this post Link to post Share on other sites
deankxf 20,288 Posted May 20, 2018 5 minutes ago, Free.51 said: Where would i get the nut from Dean? the brake mob doing the flare again should have them in stock.. it's a double flare on brake lines, i've never done one Myself(needs a special tool, and is a pain in the ass to do apparently ) Share this post Link to post Share on other sites
Free.51 2,717 Posted May 20, 2018 Just remembered i have a flaring kitSent from my SM-A520F using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted May 20, 2018 i have one of those it's not correct for brake lines 3 Outback Jack, Free.51 and jca25 reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted May 20, 2018 No worries, brake shop it is then 👍 1 deankxf reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted May 21, 2018 I rang up highway clutch and brake & they dont work on cars just a wholesaler Share this post Link to post Share on other sites
deankxf 20,288 Posted May 21, 2018 thought they must retail also, as i bought the clutch from there and had my drums and discs and flywheel machined and shoes rebonded and radius ground... although, i know someone who works/worked there.. so next bet has to be an ABS brake joint would be my next stop.. Share this post Link to post Share on other sites
Free.51 2,717 Posted May 21, 2018 I know Mark works there but i spoke to a Jo & if they dont work on cars then i dont care anymore Share this post Link to post Share on other sites
Free.51 2,717 Posted May 26, 2018 Finally got the hardline nut undone today using vice grips & 19mm spanner & the flid pissed out which is a good thing then put on another hose & bled the caliper & all 4 brakes are working nowSent from my SM-A520F using Tapatalk 2 deankxf and jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted May 26, 2018 Glad u have all fixed 1 Free.51 reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted May 26, 2018 Thanks mate👍 1 jca25 reacted to this Share this post Link to post Share on other sites
gregaust 319 Posted May 26, 2018 Good result . So the old hose was blocked once you removed it ??? Share this post Link to post Share on other sites
Free.51 2,717 Posted May 26, 2018 I didnt check it when i took it off i just saw fluid dripping out the hardline & was excited, im guessing the flex hose was blocked cos it was bone dry at both ends & i did the job at my brothers cos my trolley jack is fucked too now & i just threw it in the bin 1 deankxf reacted to this Share this post Link to post Share on other sites
