GoofyBuddah 10 Posted March 22, 2018 G'day folks I'm a noob here. But heres my problem. I own an xg falcon longreach (i think its a longreach)(nov' 93) i bought it as a project. I've stumbled into a problem with the radiator. I ordered a replacement but its not wide enough; nor does it have the mounting pins at the corners. (The rubber bungs are set 750 mm apart.) But every radiator I've found has this issue of being not wide enough. Any ideas as to why? Share this post Link to post Share on other sites
bear351c 10,270 Posted March 22, 2018 Hi mate, Do you have the correct radiator? Is it original? Maybe you could scan a wreckers yard and see what is 'normal' for your model? Got any pics of the car and the radiator? Bit hard to diagnose over the Internet. ....and Welcome. 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 For some reason i can't share my photos that i have, grrrrrrr. I hate my phone lol. Already done the wreckers thing and there are none here in tasmania. Coz ppl are snaveling them up for projects. And like said this is the only radiator that is for a longreach. Are there any differences with the longreach, tradesman, and xr6 radiator wise. I was lookingbat an AU it has the corner pins in the radiator. Not sure if an Au one would fit though. Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 copper ones are expensive, https://www.ebay.com.au/itm/Radiator-Falcon-XG-Ute-Longreach-1993-96-Auto-Or-Man-H-Duty-Copper-3-Row-NATRA/200625729527?fits=Make%3AFord|Plat_Gen%3AXG&hash=item2eb639aff7:g:5J8AAOSwrklVRqqb i'd first buy an alloy one and make sure the car is even worth investing $500 odd on a copper one if so.. Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 this is what i bought for mine, they are cheaper at even $100 if you look https://www.ebay.com.au/itm/FORD-FALCON-XG-UTE-RADIATOR-1993-1996/320482843647?fits=Make%3AFord|Plat_Gen%3AXG&epid=902223126&hash=item4a9e441bff:g:UVwAAOxy79VRfRxf another for $113https://www.ebay.com.au/itm/Radiator-For-Ford-Falcon-XG-Ute-Longreach-6CYL-1993-1996-Auto-Manual/112482363556?hash=item1a3078a8a4:g:dPIAAOSwd3dZaby9 Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 wrecker ones will all be crap, unless changed recently .. the XG takes a one off radiator, doesnt fit any other cars..u Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 22, 2018 wrecker ones will all be crap, unless changed recently .. the XG takes a one off radiator, doesnt fit any other cars..uI fitted xg rad into xe using original xe brackets top and bottomSent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 3 minutes ago, Mark Bretherton said: I fitted xg rad into xe using original xe brackets top and bottom Sent from my HUAWEI Y360-U03 using Tapatalk the EF(XH) one fitted My XE better than XG, can't remember why i chose it.. may have just been due to the thermo's being easier to mount Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 22, 2018 the EF(XH) one fitted My XE better than XG, can't remember why i chose it.. may have just been due to the thermo's being easier to mountCheck photo see brackets see if it helpsSent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 G'day folks I'm a noob here. But heres my problem. I own an xg falcon longreach (i think its a longreach)(nov' 93) i bought it as a project. I've stumbled into a problem with the radiator. I ordered a replacement but its not wide enough; nor does it have the mounting pins at the corners. (The rubber bungs are set 750 mm apart.) But every radiator I've found has this issue of being not wide enough. Any ideas as to why?This is her. We wiped out a roo moving here. Ill upload the other photos directly.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 22, 2018 Check photo see brackets see if it helpsSent from my HUAWEI Y360-U03 using TapatalkI have sent XE shroud away to a just to fit rad Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 12 minutes ago, GoofyBuddah said: This is her. We wiped out a roo moving here. Ill upload the other photos directly. Sent from my SM-G930F using Tapatalk this lower part looks home made or modified from another model, can see the lower strap from the XG part below it 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 this lower part looks home made or modified from another model, can see the lower strap from the XG part below it Thats what I'm thinking. Bought it for an emergency move and it seems a bit frankensteinish.Lol Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 5 minutes ago, GoofyBuddah said: Thats what I'm thinking. Bought it for an emergency move and it seems a bit frankensteinish.Lol Sent from my SM-G930F using Tapatalk got a pic of the old radiator? could even be a commodore one? i think AU had the stake pins at the bottom also, but i didn't think they were wide like that is(unless it's offset to the left?) Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 Thats what I'm thinking. Bought it for an emergency move and it seems a bit frankensteinish.Lol Sent from my SM-G930F using TapatalkOther photosSent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 got a pic of the old radiator? could even be a commodore one? i think AU had the stake pins at the bottom also, but i didn't think they were wide like that is(unless it's offset to the left?)No photo of the old oneSent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 i'd be taking that lower brace off, looks like the lower radiator rest is there(missing rubber, you may be able to buy still? or use radiator hose rubber ?) how was it mounted at the top area? check your radiator hose size matches the water pump and thermostat and radiator outlets as different models at least had different water pump hose size(EF was smaller) Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 got a pic of the old radiator? could even be a commodore one? i think AU had the stake pins at the bottom also, but i didn't think they were wide like that is(unless it's offset to the left?)The holes are 750mm apart.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 i don't have any reference of that, i don't even have a ford currently.. could probably ring a radiator mob and ask if that makes sense to them, or just try fit the new radiator which looks like it should fit with that bodge removed? 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 i'd be taking that lower brace off, looks like the lower radiator rest is there(missing rubber, you may be able to buy still? or use radiator hose rubber ?) how was it mounted at the top area? check your radiator hose size matches the water pump and thermostat and radiator outlets as different models at least had different water pump hose size(EF was smaller) It was held by two mounts tech screwed on lol... it was a farm ute with rego and a canopy. The previous owner was pretty dodgy lolSent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 22, 2018 they are not the XG top mounts.. so you need to decide if you can bodge it back with what you have or chase up all the bits to put it back how it was originally (hard to do in Tassie i bet, unless you can find someone wrecking an XG) 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 22, 2018 It was held by two mounts tech screwed on lol... it was a farm ute with rego and a canopy. The previous owner was pretty dodgy lolSent from my SM-G930F using TapatalkLooks like commodore rad to meThose brackets look bodgy look around for wreck and strip parts off.Sent from my HUAWEI Y360-U03 using Tapatalk 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 they are not the XG top mounts.. so you need to decide if you can bodge it back with what you have or chase up all the bits to put it back how it was originally (hard to do in Tassie i bet, unless you can find someone wrecking an XG)Its going back to stock.......ish. and do you know what this is from. Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
macman 774 Posted March 22, 2018 Someone has fitted an AU radiator. Those are butchered AU top radiator mounts and that is an AU bottom radiator support beam which has been chopped short. 2 SPArKy_Dave and GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted March 22, 2018 Someone has fitted an AU radiator. Those are butchered AU top radiator mounts and that is an AU bottom radiator support beam which has been chopped short.Thanks mate.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
