Max Payne 1 Posted February 12, 2018 Hi All, My diff is offset in my ol girl and and one wheel pokes out about 5 mm more than the other so I was thinking about putting a 5 mm spacer on that side to make it look the same, Would this be safe still? Any info would be appreciated. Cheerin Share this post Link to post Share on other sites
bear351c 10,270 Posted February 12, 2018 A common issue with older Fords. Most boys in blue frown on the thin plate style, multi stud spacers, but you can buy a better quality set, (dearer of course) that actually bolt to your existing hub, and have 5 studs mounted on the actual plate. Unsure of the sizes, though. Maybe fit a 235 on the left and a 245 on the right.. Share this post Link to post Share on other sites
deankxf 20,288 Posted February 13, 2018 i wouldn't run different size tyres, no good for the diff for starters.. what car is it? if it's got stuffed bushes it might sit that way Share this post Link to post Share on other sites
bear351c 10,270 Posted February 13, 2018 Jesus....don't take me seriously.!!! I was joking 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted February 13, 2018 25 minutes ago, bear351c said: Jesus....don't take me seriously.!!! I was joking there's been some weird posts lately.. pays to check 1 bear351c reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted February 13, 2018 I heard you can run a 17" wheel on the drivers side and a 16" on the passenger side to compensate for the weight of the driver so the car sits level. Also better for turning left at speed. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
