SPArKy_Dave 8,892 Posted January 6, 2017 My money is also on vacuum leak. Share this post Link to post Share on other sites
djbxr 18 Posted January 7, 2017 ok so turns out it was the red wire with the green stripe and the black plug that had come of the male spade connector on the carby and was just sitting on the end of the spade so i pushed it on properly and away it went. thanks for the suggestions Share this post Link to post Share on other sites
dex 2,065 Posted January 7, 2017 Anti dieseling switch Share this post Link to post Share on other sites
deankxf 20,320 Posted January 7, 2017 yeah won't idle with that switch not connected(or broken) it cuts fuel of in the carby when you turn the key off to prevent the engine run on(or dieseling if you prefer) its only on the idle circuit, you can remove the solenoid thing, cut the end off i think if you ever break the connector (i have in the past) Share this post Link to post Share on other sites
djbxr 18 Posted January 7, 2017 ok thanks for the info, i replaced all the black vacuum hoses around, to and from the carby while i was at it anyway just to be sure as some were getting bit cracked 2 SPArKy_Dave and deankxf reacted to this Share this post Link to post Share on other sites
