CHESTNUTXE 7,312 Posted November 22, 2016 yeah if you look at a block with pistons in it you think man that thing is warped,today coming home from the shop a tool fell of the back of a ute so i grabbed it and i am making a top deck zero finder tool to measure roughly how much down the hole my builds are,im sure there is pro tools out there but hey i have to make use of what is here,gerg down the hole will be a thing of the past ,block in the picture is a dummy block. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 27, 2016 Question,what would be the better option,to buy 2 MLS 060 gaskets to keep the comp around 10.1 or releave the chambers on the 302 heads ? cost is around the same so what option would be the best. Share this post Link to post Share on other sites
gerg 10,871 Posted November 27, 2016 Relieving the chambers would let you remove a bit around the inlet valve to de-shroud, but you'll have to cc the heads after that. Going thicker in gasket would require re-calculating pushrod length and checking valve geometry once it's all together, but most importantly, defeats the purpose of zero-decking because your quench area is being opened up back to where it was when the piston was down the hole (assuming you're zero decking it of course). Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 27, 2016 no all my blocks are factory down the hole,so achiveing 10.69 with std 040 gasket and 58cc 302 heads and approx 0.037 down the hole,but if i use a 066 MLS gasket it comes to 10.1 Share this post Link to post Share on other sites
bear351c 10,270 Posted November 27, 2016 I'd stick with 10:1 with todays shit fuel......... Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 28, 2016 The bearings turned up getting close now to assembly just waiting on the block Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 28, 2016 bought my self some ring pliers and gloves about time too. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 29, 2016 Every time i go to old mates workshop he seems to have something stashed in a cabnet or under a heap of parts,i went there thismorning to check on the block and should be finished by friday,he says i have a bargin for you,and pulls out this box with dust all over it and its a set of 1.73 roller rockers suit clevo or ford BB,with the 7/16 stud size,im not sure what brand they are possibly pro-comp but are definatly not the crappyest ones available,i got them for a steal so old mate will mill the heads to suit,should be fine on a mild set up ,i might put them on my pillow block engine and up the cam a bit to a roller or solid. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 29, 2016 quality is ok ,im stoked Share this post Link to post Share on other sites
deankxf 20,292 Posted November 29, 2016 all the parts people have had him order then not payed for perhaps over the years.. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 29, 2016 10 of the posilocks were missing as he used them for other stuff,but promised to get some more. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 1, 2016 while down at old mates the block is ready later today or tomorrow,i also picked up a set of clevo factory covers that he cleaned,i will paint them soon for the engine because i sold the orange ones for the 302 build,these will be xd-xe silver or xa-c blue which ever i decide. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 1, 2016 i will probly do a xe 351 black engine Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 the block is ready in a few hours,when i got there old mate was honing it. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 ready for cam bearings Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 rings just turned up too Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 this weekend i will start with a warm soapy wash of the block then dry.followed by painting these buggers start rusting straight away 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 ok the block is back still needs a final clean Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 on the stand Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 new cam bearings Share this post Link to post Share on other sites
bear351c 10,270 Posted December 2, 2016 Sweet.......love building engines. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 ok wash is done Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 2, 2016 let it dry for an hour or 2 b4 continuing to paint later 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 3, 2016 ok all masked up lets paint it. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 3, 2016 will do about 3 coats with waiting time inbetween Share this post Link to post Share on other sites
