xhadyboy 492 Posted May 10, 2016 Back in the day we used to use a paint called birdshit to freshen up ute tubs. I have a project that need lots of welding in the tub and want cover up a million sins. Its just a work hack but need to present it for a roadworthy. Is this stuff still around or is there something else that's taken its place ? Share this post Link to post Share on other sites
gerg 10,871 Posted May 10, 2016 I made up my own brew when I was younger and less inhibited by common sense. If it's a work hack it's just fine. I used some grey primer mixed with body deadener as a base, and to that added some water-based acrylic house paint. The idea is that the two dissimilar paint bases won't mix, so they go on with a splatter effect. It worked quite well actually but won't be anywhere as durable as the legit stuff. Just don't use a nice spray gun, in fact the cheapest, roughest gun out there will give the best results. Ozito makes a domestic one for 39 bucks and it's awesome (painted a ceiling in a Cafe recently with one). When spraying, you have to keep shaking the pot regularly to keep the two paints from separating. 1 judgetread reacted to this Share this post Link to post Share on other sites
judgetread 758 Posted May 11, 2016 Is it color fleck? Its a sprayable multicolor fleck paint that everyone used in ute tray to cover up everything http://www.ebay.com.au/itm/Cam-Flek-Paint-ute-tray-or-boat-texture-coat-/261232847548?hash=item3cd2b0eabc:g:dqcAAOxyTZVR5ioS Share this post Link to post Share on other sites
bear351c 10,277 Posted May 11, 2016 I made up my own brew when I was younger and less inhibited by common sense. If it's a work hack it's just fine. I used some grey primer mixed with body deadener as a base, and to that added some water-based acrylic house paint. The idea is that the two dissimilar paint bases won't mix, so they go on with a splatter effect. It worked quite well actually but won't be anywhere as durable as the legit stuff. Just don't use a nice spray gun, in fact the cheapest, roughest gun out there will give the best results. Ozito makes a domestic one for 39 bucks and it's awesome (painted a ceiling in a Cafe recently with one). When spraying, you have to keep shaking the pot regularly to keep the two paints from separating. Bwah ha ha ha hahaaaaaaa Love it. Share this post Link to post Share on other sites
hendrixhc 10,923 Posted May 11, 2016 Yeah i recon i used that in the boot of the Cortina about 25years ago. Was called splatter coat or something like that. Share this post Link to post Share on other sites
