xd-mako 1 Posted April 10, 2013 Hi, Im nearly finished wiring up my XD 351 and want to get all my standed dash gauges working again. The only problem I have is that the Oil pressure gauge. I had a mechanical oil pressure gauge and want to change it to the standed electric gauge.Now what type of sender do I require. I have been told by diffrent people that a switch sender is for the gauge.But im sure that the gauge sender is much larger than a switch sender?? Can someone help me!! ThanksMark Share this post Link to post Share on other sites
SJG351 6 Posted April 11, 2013 Yep, the original sender is a large can looking thing and they were a bit pricey last time i got one too, Ripco i think it was Share this post Link to post Share on other sites
hendrixhc 10,921 Posted April 11, 2013 This would be the one Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 11, 2013 You can get shiny oil pressure senders?? Haha. Are Clevo ones the same as xflow or are they different? To avoid future confusion Mark, you have a pressure switch for an oil light, or if its got an oil gauge, then you'd need a pressure sender. At least i think that's the right terminology. Share this post Link to post Share on other sites
gerg 10,871 Posted April 11, 2013 My S-Pak wagon had a 6 in it had the oil gauge in the instruments. I just transferred the sender across to the 302, so the old sender is still talking to the old gauge. I'm pretty sure that Ford would use the same ones for V8s anyway. Dunno why someone would think that a switch would give a variable, analog signal for a gauge to work. That's what a sender does. A switch is either on or off, and an oil pressure switch just turns off the red light on your dash as soon as it sees a couple of psi. Share this post Link to post Share on other sites
xd-mako 1 Posted April 12, 2013 Thanks!! Is the part number 360-003?? As repco only has that part number for a 5.8 and no listing for a 5.8 Xd only the 4.1 Share this post Link to post Share on other sites
hendrixhc 10,921 Posted April 12, 2013 ill check tonight when i get home Share this post Link to post Share on other sites
hendrixhc 10,921 Posted April 12, 2013 Ok so its a VDO 10945. 0 .7 bar or 0 -700Kpa. Share this post Link to post Share on other sites
