Mevans12
Wheel/Rim Identification Help Required
Hi all,
I am trying to get a positive ID on this wheel, which i believe is originally from a Ford Falcon.
The specs are as follows: 14" rim, 5 studs, stud diameter 12.7mm or 1/2", centre of adjacent studs 66.675mm or 2 5/8", PCD 114.3mm or 4 1/2", Hub Hole Diameter 60mm.
Any suggestions/opinions would be greatly appreciated.
Looks like a small center hub.
It is too, anything pre xc then? Pretty sure the larger 70mm centre started on the XC, so previous to that so XW through to XB? I don't think these came out on XR/T, but maybe XW/XY? Not sure.
Hi again.
So i had a closer look at that rim and YES as ReVhEaD had suggested i found a stamp on the outside face of the rim that said
"ROH MADE IN AUSTRALIA".
So does this along with the small (60mm) centre hub hole confirm it as XA or earlier??
Your thoughts and comments would be greatly appreciated.
Thanks in advance.
